Engineered and manufactured to support intense power needs, the Atomic Juice series of Power Supplies are ideal for high performance and gaming systems.
Delivering either 600 or 700 Watts of continuous power, these power supplies are perfect for dual-GPU setups, supporting the latest ATX12V v2.2 platform and are also designed to power earlier ATX v2.0 systems.
The ultra-quiet 120 mm fan corresponds with temperature sensors, offering greater RPM and airflow as needed.
With one Main MB connector (20 + 4 pin), two 12V (CPU 4 pin), one 12V (PCI-e 6 pin), one 12V (PCI-e 6+2 pin) six (SATA 15 pin), two floppy, and six (4 pin accessory) connectors, you have more than enough capacity to run the latest generation of CPU and graphic hardware on the market.
The Atomic Juice PSU's feature high-quality components, complete with a ball bearing fan, to ensure your vital hardware is supplied with clean, stable and reliable power without compromise.
The universal AC input 100 ~ 264 Vac, is automatically switched and adjusts the hardware to operate at the available input voltage. Quad 12 V rails provide independent and reliable power to your CPU(s), your video card(s) and to the other components of your rig.
With an MTBF of over 100,000 hours and an industry leading 5 year warranty, you are equipped for years of worry free operation.
This is a great power solution for your dream system - boot up today!
