Ive have just managed to fit my full cover old waterblock designed for a 6800 onto my 8800gt
If anyone is interested i have taken a load of pics and can put a little guide on it?
please do so. I would love to reuse my ek fc7900.
Nadeshiko: i7 990 12GB DDR3 eVGA Classified *In Testing... Jealous?*
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Really? An EK fullcoverblock?
Does it have real contact with the memchips and the core?
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
That's what I'd be worried about.
Unless you flatten the whole block out and re-machine the steppings for the memory and core I don't see how this would contact properly. You might be able to mount it, but it certainly wouldn't be ideal contact on all the chips & the core without some serious reworking.
Pics?
XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
hmmm kinda interested on this one too.
Pics!!
E4400 @ 3100Mhz 1.375v // P965 DS3 rev3.3 // 4GB D9GMH
EVGA 8800GT // Antec P182 Gun Metal // Corsair HX520W
Dell E172FP 17" TFT // Logitech MX1000 // Saitek Eclipse KB
Apogee GT // Maze 4 // Laing D5 // Swiftech MCR320-QP
mATX soon...
I.m just uploading a load of pics now - ill make a post of it in the morning
Ok here is my old waterblock
Its an alphacool effort meant to be put on a 6800/7800 or 7900
As you can see this is a full cover block and would not fit the old 8800gtx or gts
However when the new 8800gt came out people were reporting it had the same mounting holes as the old 7900
Some people have even had some success mounting gpu only blocks and adding their own ram sinks
Ok next up is to mount the block
With the fitting kit for the waterclock are some small washers that were the exact same height as the gpu shim so i knew at that point the waterblock would deffinately fit - i placed these at the 4 mounting points around the gpu core and mounted the block
The gpu core lines up nicely with the waterblock part that has channels cut out for the original 7900 core and the rest of the full cover block covers the ram chips too (i think one of my ram chips pokes out the side but only by like 1mm at most
The rest of the old mounting kit on the back works fine too
URL=http://img91.imageshack.us/my.php?image=photo025vy9.jpg][/URL]
On newer block than this for 8800gtx etc they do have a small plate that comes out to the right to cool the power mosfets etc...
So for my card i just got hold of some stick on ram sinks and covered all the points that were being cooled by the original heatsink
And voila! There u have it a fully cooled 8800gt card with an old recycled waterblock covering both gpu and ram
Here it is in my rig in sli form running sweet
So, in brief, you had to use very thick thermal pads on the memorychips and you mounted the block with just 4 screws around the core?
Your pics do not show how the block makes contact.
The water block only ever had 4 mounting holes
The block is making good contact as GPU temps are around 35-40c depending on load
I dont know how to measure memory temps
im sorry but what about that IC chip thats in front of the gpu. Doesnt that need good contact?
I dont think this will work very well. :\ And my EK blocks are stepped, so you should specify it will only work with alphacool blocks, which almost no one has on this forum.
