Results 1 to 25 of 297
Thread: Vmod 3850 through BIOS apparently IS possible....
Threaded View
    Apr 2003
    Smile Vmod 3850 through BIOS apparently IS possible....
    I was following a post in a forum and was in different language...couldnt read it UGH and I dont have the forum I was on...
    but one guy made a BIOS for the 3850 256MB that is labeled 7701000.zip and another 7701000a.zip
    the first one did not work for me as it must have not had the correct checksum cuz the vendorID and bios name and all that information was blank when I flashed it. HOWEVER I tried the 7701000a.zip one and it raises the voltage tables up from the standard 3850 to 1.33v which isnt that close to the 3870?
    Anyways, I did not take any readings with voltmeter BUT...before this bios I was only stable at 730mhz on the core and anything higher would freeze in games within minutes.
    With this bios Im able to run games all day @ 770 even crysis....
    I know its not hitting the 860mhz limit and I think a vmod via hardware is still a surefire way cuz I should get higher clocks...BUT I do think there is something to the software vmod also being that I gained 40mhz...
    Bios was unfortunately .67 version which is the locked one but....that aside...
    I think this might go somewhere....anyways leave feedback or tips or comments or whatever lol I would like to see if more can come from this.
    PS I also confirmed the correctly changed voltage tables via rivatuners information readout of the powerplay modes...and indeed its been changed from its default to 1.33v =)
