Hello
I am a long time lurker here on these here xtreme forums, but this is my first post.
This weekend I am hoping to upgrade from my old and trusty Pentium 4 S478 Northwood @ 3.4Ghz to my new and troublesome QuadCore Extreme QX9650 system.
Basically this is what I have
Intel Quad Extreme QX9650 12MB Cache C0 stepping
4x1GB Patriot PC3-12800 Low Latency 1600Mhz 7-7-7-18 DDR3 (all identical)
ASUS P53E Motherboard
nVidia Geforce 8800GTS 512MB
Creative Sound Blaster X-Fi
Seagate 500GB 7200.11
Pioneer DVD RW
Enermax Infinity 720W
Initially when I plugged everything in and was ready to go I kept failing memtest (loads of horrible errors all over the place). I upped the voltage on the DIMM's to 1.80v but I was still getting errors.
In the end I dropped the speed of the RAM from 1600Mhz to 1066 and then flashed to the latest BIOS (0703). The new BIOS seems pretty good and let me pass memtest![]()
However it all goes downhill from there onwards as I cannot install Windows or Run Seagate's version of Acronis (Discwizard), both hardlock.
Finally I was able to install Windows and Run Discwizard by downlocking the RAM to 1333Mhz. and upping the voltage from AUTO to 1.74V
The system seems pretty stable and gets 15sec super pi and 142xx in 3dmark06 but I want to run the system @ 1600Mhz (as this is why I purchased that particular RAM).
Most of the settings in the BIOS are set to "AUTO" with the exception of the DRAM Volts which I have now upped to 1.80 and the Patriot spec timings of 7-7-7-18 but even with the SPD set to AUTO I cannot boot windows @ 1600Mhz (yet it pases Memtest with no problems).
Have you got any ideas or suggestions?
Thanks for your help.
John
