Results 1 to 25 of 35
Thread: 8800GTS with Intel Fan - 13*C temp drop
Threaded View
    Feb 2006
    Australia
    I decided i needed better cooling after doing the vmods to my 8800GTS. The vgpu is set at 1.40v, and the core was reaching ~95*C under load, in ~26 - 28*C ambients.
    I removed the stock shroud (4 screws) and then removed the stock fan (3 screws). I modded the shroud to allow 3 mounting retainers of the intel fan to slide through it, so it could be attached securely with screws. No zipties used here! Secondly i cut out the fan intake hole so it was the perfect size for the new fan.
    To cut the slots in the shroud i, sat the fan on top and carefully marked where i needed to cut. Then i used a power drill and cut a small line of holes, then joined them together. Sorta dodgey but it works I cut one tab off the fan as 3 are enough to mount it with and it would have protruded through the shroud into the airflow.
    After seating the fan onto the shroud, i marked the hole i would need to make for the new fan. I removed the fan and enlarged the hole with a hacksaw blade & drill, then filed the edges smooth(ish) - i will do it better with a dremel but didnt want to risk cracking the shroud at this stage. I remounted the fan, drilled a hole through the shroud & into each fan retainer tab. I then used ~ 2 x 10mm screws to mount the fan to the shroud.
    A good thing about the intel fan is that it increases speed as the temp rises, so at idle it quieter than the card was with the original fan, but as the case warms up it speeds right up to 3000+ rpm, and at that speed theres a lot of air rushing out the back
    The results arent amazing, but without removing the heatsink & remounting it with thermal paste, it is decent. I lost 13*C off my full load temp (now 82*C) which is not bad considering the voltage im running, and 8*C off my idle (now 63*C). Best bit is it cost me nothing and makes my card safe until i can get an HR-03 Plus.
    Here are some pics:
    Pic 1 - lower mount
    Pic 2 - upper mount
    Pic 3 - view from underside of shroud showing fan retainers protruding through & fan hole cut out
    Pic 4 - Test to check if air flow was sufficient
    Pic 5 - Installed in system. 4 slot design!
Name:	Fan Mount 1.jpg
ID:	68705   Click image for larger version.
Name:	Fan Mount 2.jpg
ID:	68706   Click image for larger version.
Name:	Fan Mounts shroud bottom.jpg
ID:	68707   Click image for larger version.
Name:	test run for air flow.jpg
ID:	68708   Click image for larger version.
Name:	Mounted in system.jpg
