GeForce 8800 GTS 512 Mb has 3-phase power converter and I'm sure it's possible to make the same with GT.
There's also tons of SMD components missing on the backside.
I think it's possible to make it work but acquiring match parts would be a PITA and in the end, ordering the needed parts might become more expensive than shelling the extra dough for a GTS (which is 3 phase native).
You were not supposed to see this.
Q6600@3.6 GHz / GA-X48-DQ6
2x2GB Kingston HyperX DDR2-800
Asus HD 5870
Corsair TX-850
WD Velociraptor 150GB / WD Green power 500GB
Water Cooling: EK res 250 > Swiftec MCP655 > Swiftec MCR320 > EK-FC5870 > HeatKiller 3.0 LT
Proc: Q9650 9x496 @ 1.440v batch L844B703
Ram: 2x2GB OCZFlexII PC-9200 4:5 1240MHz 6-6-6-18 @ 2.12v
Mobo: Gigabyte EP45-UD3P rev 1.0 - bios F9b
Video: 2x Palit Dual Sonic HD4870 1GB in CF (840/4400)
PSU: OCZ PowerStream 520W + Thermaltake VGA 450W
HDD: 3x250Gb Barracuda 7.10 SATA2 Raid0 (ICHR10) 2x200Gb Barracuda 7.10 SATA2 Raid1 (ICHR10)
Audio: Audigy 4
Case: Dual Coolermaster Stacker; one for system rig and one for watercooling loop and cooling
[SIGPIC][/SIGPIC]
yes it is
Actually they are starting to appear on retail, here in Singapore at least.
http://forums.hardwarezone.com.sg/sh...ht=xpertvision
The G92 8800GTS samples (also 3 phase cards) are trickling in too, just waiting for the NDA to lift before hitting retail, so a little patience would be most useful.
HTH.
MC, just ask nicely and you can pick up a GTS 512 today![]()
