Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: HD3870 Bios Modding (Hex Editor - Clocks - Voltages)
    Mar 2006
    Hi,
    after someone wrote to me who sold his 2900Pro and bought a HD3870 he asked me if i could mod his bios... so i took a closer look and with the knowledge from the 2900 modding the relevant offsets were found after a few minutes...
    To understand the Basics of this modding please refer to the 2900 1st Post please... after you understood there how to proceed this should help ypu edit your own Bios...
    Open your Bios in a Hex-Editor und search for the memory clock because its the same in all Power States (Mem clock as hex value is d8 b7 01)
    after some searching i found this block:
    and after some conversions i finally could figured this out
    On one 3870 we could confirm that it worked, Here is the Bios File:
    2D: 250/1126 with 1,0v (1,241v is default)
    3D: 850/1250 with 1,327v (1,327 is the default voltage)
    http://rapidshare.com/files/73980710/test.rom.html
    What we could see, that his Overdrive didnt work afterwards, dunno why...
    In this Bios i did not correct the checksum - it worked though... but perhaps it is like with the HD2900 cards, that some need a corrected checksum. We will see.
    Oct 2007
    Virginia Beach
    I had a feeling they would use a similar format
    I hope people that actually have the cards will help refine this.
    I'm not sure you have it labeled exactly right, the 3870 uses 3dmode in windowed apps (unlike 2900) and may have a designated setting. It may be the third set of 3dclocks at the top of what you have labeled for thermals.
    I really have no idea since I'm not playing with one, but that is my suggestion.
    Mar 2006
    Quote Originally Posted by super dank View Post
    These were my first thoughts, when i saw the values... I do not have a 3870 and I can´t play around with the values. It is just as you said
    Nov 2007
    If you can modify this 3850 bios with higher volts from IAX Tech then I can try it. I checked a hex editor on it and its the same concept
    http://www.iax-tech.com/video/3800biosmod/03.htm
    Mar 2005
    Imladris
    If someone can get a working 3870 bios with 1.4v and 1.5v in 3D mode I'll be willing to try them out.
    The little air system that could.
    Jan 2007
    France
    I have tried this mod today and 900/1340 work ok for me (even 930/1340 but I go for CF and only one of my cards can do this stock) but seems you cannot raise voltage with any values of the screen only decrease
    EDIT: I can raise the 2d state voltage but 1,4v/1,45v = 1,33v multimeter (seems it's the limit)
    Bye
    p€p|n0r@ng
    ***The Overclocking Knight***
    ***www.59Hardware.net***
    ***My Facebook***
    Sep 2007
    Belgium
    Bios Vmodding doesnt work on these cards Only hardmods.
    Does 900/1340 work on both cards?
    System: E8400 // P5Q-E // Ballistix // HD3850 // HX520 http://valid.x86-secret.com/show_oc.php?id=419486
    Thermochill pa120.3 // D-tek FuZion bowed+ costum nozzle // MCW60 // EK150 // dcc1 18w w/top
    Jan 2007
    France
    Quote Originally Posted by MorGo7h View Post
    Yeah 900/1340 work 100% stable on both cards with stock cooler, I even tested 930/1340 on one card with success but the other card can't do this with stock vgpu...
    Bye
    p€p|n0r@ng
    ***My Facebook***
    The Blue Dolphin
    Nov 2004
    The Netherlands
    *HD3850 256mb all voltages to 1.327V (HD3870 3D level)
    *Extremely experimental (need PCI card or blind flash if something goes wrong)
    *checksum not fixed (most certainly not a problem)
    Test at your own risk:
    http://rapidshare.de/files/38011915/..._vmod.bin.html
    EDIT: Clock lock at 862mhz core
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Nov 2007
    Quote Originally Posted by alexio View Post
    I checked this bios on Sapphire 3850 256MB and I have 1,24V in 2D and 1,28V in 3D
    Feb 2004
    Egypt
    I think i read somewhere that BIOS V-Mods don't work, did you test that BIOS?
    CPU: Intel Pentium D 925, 3.0GHz @3.82, 40/60c
    RAM: Spectek 2048MB (512x4), DDR2-533 @510, 4-3-3-9-12
    MB: Gigabyte GA-8I945P-G
    GFX: Chaintech 8800GT 600/1500MHz (1.05v) @800/2000 (1.19v), 512MB 900MHz (1.9v), Zalman VF700-Cu, 45/80c
    Monitor: IBM 21" P202 @1600/70Hz
    PSU: Task International 450 Watt, 12v/26A
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Maybe the bios vmod will work if you change the device id to "HD3870" from "HD3850". I will update shortly after I have made this mod. After all the driver is responsable for assigning the vcore so it's worth a try atleast
    It's just weird that the driver doesn't read the correct values from the bios.
    Blue Reviews:
    Blue Guides:
    May 2003
    Hopatcong, NJ
    BIOS vmodding didn't work on the 3870. It was one of the first things we tried in the unleashed thread about 3 weeks ago. I've tried modifying the voltage tables up to 1.5v, and it does not budge. The checksum changes as soon as you modify anything on the original bios, and an incorrect checksum will give you a blank device ID / info when you try flash. The -f flag forces it, but you still dont get any change in voltage. guess has a tool to modify powerplay tables / clockspeeds, but he is under NDA and that tool is likely not going to be public.
    So, pretty much if you want working vmods you either do hardware mod, or wait for w1z to get working software control in the next version of ATITool. You could probably try figuring out how to get a matching checksum and see if that makes bios modding work. But rather that wasting so much time to do that, imo you could just hardmod it and be done with it...
    'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
    'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
    'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
    Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
    HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
    The Blue Dolphin
    Nov 2004
    The Netherlands
    *edit*
    Blue Reviews:
    Blue Guides:
    Feb 2004
    Egypt
    Here's a thread talking about BIOS Checksums, in German though, the English translation below is very bad, didn't understand it well, so if anyone can take a look and tell us what he concludes?
    http://www.area3d.de/forum/showthread.php?t=2545
    http://translate.google.com/translat...hl=en&ie=UTF-8
    Thanks.
    Dec 2007
    Well it says that testing for the HD 3870 Bios can't be done because they don't have a card, they're looking for testers.
    I have two 3870's, one form Gigabyte & one from HIS running CF. I just think it's worth to wait a little until threre's a new driver version, 'cuase the latest one is as young as the card itself. Greetings from Switzerland
    Dec 2007
    anyone tested this bios yet???
  18. #18
    Dec 2007
    Quote Originally Posted by ChromeGunner View Post
    yup interested to know that as well
  19. #19
    Nov 2007
    http://rapidshare.de/files/38027384/test2.rom.html
    Checksum corrected, think it's ok now. Device id = HD3870 NEED TESTERS
    How did you take the correct checksum?
  20. #20
    Oct 2005
    Ill test it this weekend
  21. #21
    Feb 2004
    Egypt
    I tested this BIOS, it worked, i could go from 760 to 795, but why can't it go higher?
    EDIT: Also, is it normal for the thermal sensor to read 45 idle and 60 load? without any modifications to the card!
  22. #22
    Dec 2007
    Do not use this bios, i flashed my card to it and when i did the reboot Catalyst control would not work at all and Windows found a new pci device, so i installed Catalyst control again but windows kep on saying "Found new hardwar Pci Device" everytime i booted the pc, plus there was no diference on how high i could overclock, so i went back to my old bios.
    Gunner
  23. #23
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Gunner
    Might have to do with the device ID being unreadable without the checksum fix. This should be fixed with the new bios I made.
    Thanks for testing anyway
    Blue Reviews:
    Blue Guides:
  24. #24
    Dec 2007
    ""http://rapidshare.de/files/38027384/test2.rom.html
    Checksum corrected, think it's ok now. Device id = HD3870 NEED TESTERS""""
    that is the one i used and you said the checksum was fixed....just a heads up
  25. #25
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Did you flash without the -f flag? If not then can you test if it works without the -f flag? If it works I'm sure that at least the checksum is correct now
    Blue Reviews:
    Blue Guides:
