It will take a few minutes to set this benchmark up but IOmeter is a much better way to test a hard drive performance than Hdtach etc... Post also what setup you have
Here is a quick guide how to set it up:
1. Download IOmeter
http://www.iometer.org/doc/downloads.html
2. You can try opening iometer.icf file (see attachement) or set it up manually
Set target and disk size (8GB)
3. Create a new test
Access specification will look like this:
4. Last parameters
Then simply click start tests (green flag). Run time will be 5min*4=20minutes
It will save results in CSV file. Next you want to open the file in Excel and format to something like this (raptor 150GB raid0):
Here is another result from Gigabyte iRAM (1GB though):
