Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Adata DDR3-1884 CL6.6.6.13 1t
    Banned
    Dec 2006
    ADATA EXTREME DDR3-1900X
    OC@942MHZ (AFFECTIVE DDR3-1884)
    DDR3 1884MHZ 6.6.6.13 1T SUPER PI 32M
    Latency
    Mar 2005
    Maastricht, Netherlands
    Nice rams mate.. im getting them too, send next week ^^ .. cant wait ^^
    Regards
    Bench System:
    CPU:Intel core 2 duo E7400 2.8Ghz @ 3.4Ghz
    CPU:Intel core 2 duo E6400 Conroe Batch L629A7XX
    CPU:Intel core 2 quad Q9400 2.66Ghz @ 3.0Ghz
    MOBO:Asus P5Q Pro
    RAM:Corssair 2x1 GB PC6400 DDR2-800
    RAM:Corssair 2x2 GB PC6400 DDR2-800
    RAM:Avexir DDR2-1066 w/ Handpicked Elpida's
    VGA:Asus GTX 560 1GB
    HD: Westerdigital 160GB SATA
    HD: Westerdigital 500GB SATA
    PSU:Coolermaster Silent Pro 700W
    Oct 2004
    USSR
    DDR3 1884MHZ 6.6.6.13 1T that's awesome !!!
    how much volt does it require to run at that speed?
    Xtreme Guru
    Aug 2005
    Burbank, CA
    nice.......DDR3 should be better in late 08....better prices and ddr3 2000 should be nice.
    Jun 2004
    Olot (Girona)
    Impressive ! No 6-6-5 ?
    || Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
    || XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
    Banned
    Dec 2006
    Compare Conroe to Yorkfield with DDR3-1884 CL6.6.6.13 1T
    8x471,3768MHZ,conroe scores 12m21s, Yorkfield QX9650 scores 11m32s
    Yorkfield is the way to GO,hold the memory at the same Frequency,pull muliti then see ...
    QX9650@9x471,4239Mhz ,10m27s
    QX9650@10x471,4239Mhz ,9m36s
    Brotherhood
    Apr 2005
    Land Of KADISOKA
    Nice speed !!! how you use Vdim ?
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Xtreme Legend
    Mar 2005
    Australia
    my goodness hicookie that's fast and crazy good ram
    what ICs do they use
    Team.AU
    Got tube?
    GIGABYTE Australia
    Sep 2007
    Victoria, Australia
    Insane! What vDIMM was that?
    QX9650 L740A 4GHz @ 1.25V aircooled
    8GB Team Dark DDR2-1066 @ 5-5-4-15 @ 2.00V
    Asus P5E 1.41V vNB
    GTX280 1GB 600/1450/1200
    WD Raptor 150GB + 2*500GB WD
    Pioneer 212D
    Corsair HX620
    Antec P182
    Dell 2407
    Jan 2007
    Very fast, I wish I would have DDR3 2000...
    Banned
    Oct 2005
    Quote Originally Posted by dinos22 View Post
    2nd that
    Wow 39ns with ddr3 , m8 you are steping into ddr cl2 AMD territory
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    what he said X10. that is just sick...and no 1M BS, you don't mess around showing off some 32M goodness. thank you for re-affirming my belief in god, now i just have to get my hands on some sticks that do the same
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Mar 2005
    Quote Originally Posted by Computerville View Post
    You just wait then... A-Data is working on A-Data Vitesta DDR3 2000X... these run on 2.05/2.15V on the following timings: 9-9-9-24 and the kit will contain 2x1gb ddr3 sticks.. there will also be A-Data Vitesta DDR3 1900X
    Regards
    Bench System:
    MOBO:Asus P5Q Pro
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Now where's the cookie?
    But impressive, thats for certain... Are we talking D9GTR / GTS? What chip... 6 Layer PCB, 8 layer, 4 layer.... I need specs... Could be a lucky incedence, could be a killer serie...
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
    Xtreme Legend
    Mar 2005
    Australia
    they are GTRs
    fairly high vdimm but if the chips take it wellllll it's important they can
    fastest CAS6 i have ever seen that's for sure
    Team.AU
    Got tube?
    GIGABYTE Australia
    Xtreme X.I.P.
    Nov 2002
    Shipai
    this must be crazy vdimm, very nice result!
    i think its even a bit faster than what victor reached.
    Banned
    Nov 2007
    AMD-PHENOM
    great results, well done.
  18. #18
    Nov 2005
    London UK
    they are GTRs
    "fairly high vdimm"? But how high? More than 2.3v or what? Inquiring minds need to know... this is CAS 6 after all.
  19. #19
    Xtreme Legend
    Mar 2005
    Australia
    he says 2.3-2.36v
    i think that is still excellent considering the overclock in question and no less than a P35 board
    he's got some ripper sticks and any serious bencher would be very envious i'm sure
    Team.AU
    Got tube?
    GIGABYTE Australia
  20. #20
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Quote Originally Posted by x3ro View Post
    You just wait then... A-Data is working on A-Data Vitesta DDR3 2000X... these run on 2.05/2.15V on the following timings: 9-9-9-24 and the kit will contain 2x2gb ddr3 sticks.. there will also be A-Data Vitesta DDR3 1900X, they will run on the same timings but will be only 2x1gb.
    Regards
    DDR3-2000 2x2GB kit is probably a typo of the press release m8.
    It'll be 2x1GB ( a 2GB kit, not a 4GB kit )
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
  21. #21
    Xtreme X.I.P.
    Nov 2002
    Shipai
    he says 2.3-2.36v
    well its stable for superpi 32m... but for how many hours will this kit survive with volts that kill ddr2?
    But awesome for benching, the best ive seen so far was 1850 with 665 more or less but that was with "only" 2.25v. looks like i need to set up my maximizer and check out higher vdimm. but i have to say i already feel bad for even thinking about giving theese sticks 2.35v... i can already here the sticks shivering in fear the closet, they must have sensed something
  22. #22
    Moderator
    Nov 2006
    oh my God they are really nice very fast
  23. #23
    Xtreme Mentor
    May 2007
    Very nice mate.
    Their Vitesta DDR3-2000X are also very good although they ran at CAS 7 when overclocked but the rest of the timings were close by and perf better: http://oc.adata.com.tw/news_detail.asp?newsid=5
    Those volts will kill the IC's very quick, as saaya mentioned they kill good DDR2 pretty quick never mind DDR3. If I needed it so bad I'd rather pay for their 2000X at 2.15V.
  24. #24
    Mar 2007
    Italy
    Impressive memory
    Extreme Overclocker
  25. #25
    Xtreme Guru
    Dec 2002
    when 6-6-6 @ 1000MHz? lol
