Any know V Mod about this board ? ussually with V Drop ?
Ya, i would really enjoy a few mods here aswell, weres Johnny or Hipro5
--cheers--
Sub Zero Lives
Vdroop & vpll mods are sorted Will post pics soon
What other mods do you guys want ?
how about vmod for the cpu VTT max on 1,6v
love to try above it and see how it goes
Sorry for the delay guys my laptops died so I'm gonna have to host of imageshack for the time being. Both mods are tested to be working Pics up in 6-8 hours after I get home from work!
Vdroop
1Kohm variable resistor preset to 500ohms seems to do the trick!
VPLL
Not easy to solder!!! I suggest you put the VR beside the Inductor like so
thanks for the mod bro ill try the vdrop as soon as i could
anyway what is vpll?imch?
i think its ICHIO on abit since its default value is 1.5v, same as VPLL default on Asus mobo.
E8600 Q820A750
DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
Winfast 8600GT
Silverstone Olympia 1000w
andre X_X -72c CO2 Cascade
My R22/CO2 Cascade Project
Anybody tested high voltages (2V) ? Any OVP problems, vcore needed?
I don't have the board yet, but will need that soon when I do
OC-Lab.si!!
Cpu vocre max 1,9v with b02 beta bios , I need more vcore , Cpu vtt mod Jonnny and Hipro where are you
yup like i said before i would love to have more than 1,6v
but what is vpll anyway?if vpll is ICHIO why need so much?couse i try to raise mine it didnt make any effect?
1.9v oke with bios but ı need over 2V
it's really bad support with mods for this boards
it will be Asus for me next time
OC-Lab.si!!
@Brandybuck bi abit ix 38 anakartı çözemedin gitti
Liquid Nitrogen -196c
THE POWER
@johnny
on my board the max vcore is 1,9v so i think it was BIOS limitation
so could you give us some cpu vtt mod
Will sort out a cpu VTT mod - beta bios 06 and onwards offers up to 2.11volts!
CPU VTT mod figured out will test tonite then post pics
btw you'll need to take off the NB cooler in order to do the mod, don't worry it'll fit back on once it's done
hehe as long as it work (which i believe so,like always) i got no problem with that...
btw i still dont understand if we need more vpll?which andre said it was ichIO ?
