You can do this test at home on your system, you will see how Phenom X4 perform ...
Config: RD-790FX, Phenom @default 2.4GHz, 2GB RAM, HD3870 ...
http://service.futuremark.com/compare?pcmv=3125
Q6600 @ 2.4GHz; 2GB, 8800GTX
PCMarkSuite 4973 PCMarks
Memories Suite 4445
TV and Movies Suite 4154
Gaming Suite 4706
Music Suite 4478
Communications Suite 4138
Productivity Suite 4570
HDD Test Suite 4275
Hm, very competitive scores! At the same frequencies ...
What's interesting is the "gaming" score. Any reason for this?
Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
If all people would share opinions in an objective manner, the world would be a friendlier place
Strange that memory seems so weak on phenom?
It was 128-bit mode ... This is setting before test ...
OBR thanks for the results,but couldn't you get a cas4 DDR2 ram?Today ,you can even get cheap cas4 DDR2-800 1GB modules.
As for mem. tests ,Phenom should have better mem. scores than AthlonX2.Don't know if it is BIOS setting,but your scores seem a bit low.
so its scores better then a C2D paired with a much more heavier GFX?![]()
Pwned![]()
I beg to differ, your screenshot shows "Ganged mode disabled", i.e. unganged mode enabled and that means 2x64bit not 1x128. Explanation is here:
http://www.xtremesystems.org/forums/...&postcount=343
However that should be the best option for K10, I dont care if some bandwidth benches will suffer from decreasing scores, overall performance in a multithreaded environment should be better with unganged mode.
cheers
Opteron
Everybody knows Nvidia Vista drivers are crap. I'd also like to see same graphics card used for both tests at same resolutions, and same OS environment, 32bit or 64bit.
Yep and intel's "new gen" products really pwn Conroe/kentsfield ,by a whole ~6% or so on average.
looks like its gunna be sweet!
its a little faster then the Q6600. works for me![]()
cpu- Intel I7 3930K
Asus P9x79 Deluxe
2x HD7970
32gb ddr3-1600
corsair ax1200
Corsair 800D
Corsair H100 lapped
2x 128gb M4 raid 0
Before NDA ends i can tell this: At the same frequencies are Phenom X4 and Kensfield (Yorkfield is better anyway) very close, and performance is almost the same ... BUT, Phenoms cant to overclock so easily like Kensfield ... that a problem. My max stable Phenom is about 3GHz ... and Kensfield 3.6GHz and more ...
Don't know how score the hd3870 on pcmark vantage...But you're right I've missed that it was a traditionnal AMD biased comparison... Compare a cpu with the same price, and the same number of core that a quad to a duo...![]()
But at least orb give us a clear information:"At the same frequencies are Phenom X4 and Kensfield (Yorkfield is better anyway) very close, and performance is almost the same"
Intel Core i7-3770K
ASUS P8Z77-I DELUXE
EVGA GTX 970 SC
Corsair 16GB (2x8GB) Vengeance LP 1600
Corsair H80
120GB Samsung 840 EVO, 500GB WD Scorpio Blue, 1TB Samsung Spinpoint F3
Corsair RM650
Cooler Master Elite 120 Advanced
OC: 5Ghz | +0.185 offset : 1.352v
Intel Core i7-3770K
ASUS P8Z77-I DELUXE
EVGA GTX 970 SC
Corsair H80
Corsair RM650
