Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 205
Thread: New Mozart TX Dual Loop Build with Lots of Pics
    Nov 2007
    Colorado, USA
    Hi everyone, good day and welcome to my build log.
    I've found more answers and good info here than anywhere else on the 'net, so out of thanks to the great posters I'm going to document my latest build here on xtremesystems.
    My build will be based on the Mozart TX case from Thermaltake and will have the following design goals:
    a) clean clean clean - through an iterative process I intend to hide as much wiring as possible and generally keep everthing super-tidy and neat. I will cut wires to length once the build is finalized, sleeve everything, use hold-downs, etc.
    b) no major metalwork - this will be a custom build using mostly off-the-shelf stuff and modding the case will only be done when it makes sense for fitment (for instance making the doors easily removeable or adding fillports to the top)
    e) balance between silence and performance adjustable but leaning mostly toward performance as a dedicated gaming machine
    f) able to run a 30" monitor at 2560x1600 res with current games at ~60fps or better (I like vsync!)
    g) simple maintenance - fillports and drainports so I can flush it just like a car!
    h) COMPLETELY 100% internal cooling - applies to clean clean clean above
    i) visually interesting - have a couple features in mind to give it an 'oooh' factor for laypeople / bystanders
    j) lights up like a freaking carnival at the touch of a button - I've long hated LED fans and cold cathodes, I mostly find them irritating and annoying but I guess in my old age I'm relenting - but I must be able to turn off all lights/leds/blinky stuff instantly so it doesn't blind me while trying to watch movies on the projector!
    k) 100 percent stable in games - looking for a high overclock, but not at the expense of stability. This is meant to be a gaming monster, not a benchmark queen lol
    So some equipment has arrived and I did a dry build just make sure no RMAs were necessary. I've played the entirety of HL2:EP2 on it and found that just because 3DMark06 runs all night long, doesn't mean you're stable After an hour of HL2:EP2 you will find that 'stable' overclock wasn't so stable after all ...
    Here is a component list, most of it is either here or on its way:
    Thermaltake MozartTx VE1000SWA Silver Aluminum Cube Tower Computer Case
    Sunbeam RHK-S Rheobus 20W Fan Controller (Silver)
    ASUS P5N32-E SLI Plus LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard
    2x Foxconn FV-N88XMAD2-ONOC GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported OverClock Video Card - Retail
    SILVERSTONE DA750 ATX12V / EPS12V 750W Power Supply 100 - 240 V
    Intel Core 2 Duo E6420 Conroe 2.13GHz 4M shared L2 Cache LGA 775 Processor - Retail
    Atech Flash Xm-4U 11-in-1 USB 2.0 Black & Silver Internal card reader - Retail
    2x G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
    Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive - OEM
    (more drives later, probably 750GB Hitachis, nearly as fast as Raptors)
    LITE-ON Black 20X DVD+R LH-20A1S
    2x EK High Performance Full Coverage Nvidia GeForce 8800 GTX Series Water Block
    Swiftech APOGEE GTX Extreme Performance Universal Water-block
    2x Magicool Extreme Slim Profile 2X120mm Radiator - Black
    120mm rad gaskets
    2x Swiftech MCP350 12 VDC Pump
    2x Alphacool Cape Bullseye PRO [BE-II] POM reservoir
    2x Alphacool Cape Bullseye Bay Mount
    2x Alphacool Melvin Pipe
    2x EK Asus 1 Mosfet Water Block for ASUS Motherboards LGA 775
    2x EK-NB/SB ASUS 1 Chipset Block - LGA 775 ASUS Motherboards
    EK TIM Pads for FC8800 (for mosfets maybe)
    8x Scythe S-FLEX SFF21F 120mm Case Fan - Retail (push-pull on both rads)
    6x Scythe S-FLEX SFF21E 120mm Case Fan - Retail (probably replace the power supply fan with one too)
    Arctic Silver Ceramique
    Primoflex 3/8"ID x 1/2"OD
    Koolance Reusable Hose Clamp [10mm, 3/8"]
    Koolance Misc 3/8" fittings (compression, mostly)
    And finally, the moment you've all been waiting for (thanks if you read this far lol), the PICS!:
    (keep in mind this is a work in progress and will probably take me a fairly long time due to my limited schedule, I will update as I go)
    Some parts
    Case looks like a small beer fridge
    It has wings!
    Lots of room for junk
    Look ma no hands!
    Face off
    Ridiculous room
    Drive cage
    Faceplate is thick, sturdy aluminum
    Mobo stuff
    Core 2 Duo is cheap performance!
    Not even close to stable at factory-overclocked speeds (630/1000). Hopefully water will alleviate this, maybe even get higher
    Simple no-frills, don't-care dry build (I don't wanna hear it!)
    Nicest power supply I've seen yet (Silverstone DA750)
    Next installment whenever I find some time to tinker
    Oh btw, please comment on the size of these pictures? Originals are HUGE, is this big enough or too big? I'm doing the hosting so I can go crazy if you want ...
    Xtreme Mentor
    Sep 2007
    Monterey Bay, Calif.
    Perfect sized pics, and very nice build there! Dang, I would have sold you my P5N32-E SLI Plus for cheap... oh well, if you ever need a replacement, PM me!
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    nice... but where's the wc gear lol
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Sep 2007
    My Rad design for your reference
    PA120.3 + PA120.2 External
    [SYSTEM]TT Mozart XT - Maximus Formula - E6850 - 8800Ultra - DDR2 1066 x 4 - SAS 15K x4 Raid0(Adaptec3805) - Zalman ZM850 - Apple 30" LCD
    [Monitor]BigNG + MiniNg
    Loop1(3/8): DDC+3.2(Petra Top) -> PA120.3 -> Enzotech SCW-1 -> DD 8800GTX Block -> EK-RES250
    Loop2(1/4): DDC+3.2(Petra Top) -> PA120.2 -> MIPS RAM Freezer4 -> Asus fusion chipsets block -> Silentstar HD Block x 3-> Pumps cooled by Alphacool HDD3CU/Plexi 3.5" HD Block -> EK-RES250
    I am Xtreme
    Jul 2007
    cool ! looks sweet!
    NREMT-I
    Jul 2005
    near Atlanta Georgia (and hate it)
    love it. MOre pics
    Nothing anymore
    Aug 2007
    UK
    Quote Originally Posted by disruptfam View Post
    water!!
    looking good
    Jun 2007
    Manitoba, Canada!
    Awsome!!!! ive been waiting for a Mozart TX build! good luck!
    Q6600 @ 3.6 ghz. (9x400)1.38 vcore
    asus P5Q Turbo
    4 gig ocz 800 mgz ddr2 Platinum
    NVidia GTX 295
    Corsair 800w PSU
    2-1 TB WD drive
    1-750 GB WD drive
    1-750 GB WD External USB2 backup drive
    HK 3.0 CPU Block
    danger den maze 4 northbridge
    MCP 655-B pump, rad/res, all 1/2" stuff....
    3-19" lcd's-matrox triple head 2 go
    1-32" HDTV LCD (4th display)
    Cooler Master HAF 932 (Love it!)
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Nice case! Looking forward to more pics.
    I am Xtreme
    Apr 2005
    Upstate, NY
    /Subscribed. Can't wait to see it done.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Aug 2006
    Nice mountain bike
    Xtreme Mentor
    Sep 2007
    Quote Originally Posted by IanY View Post
    Nice mountain bike
    Expensive, yes, but it a cross-country bike... eww... Freeriding is where it's at!
    Oct 2007
    I'll be doing a very similar build. Already got the case, stock components, and some of the WC gear, just ordered the rest.
    I have an idea for a custom solution for 2x 2x120mm rad mounting though. I'll have to wait & see how badly I'd have to hack up the upper rear 2x2 fan area before I decide if I'll have to mod it or not.
    I'll have to keep an eye on your build.
    Sep 2007
    Quote Originally Posted by mcoffey View Post
    Great project and Welcome,
    I've got that case and I run a 30in at 2560X1600. But, I couldn't get a build in it that met those same requirements so I had to move to another case.
    To get a hi end system water cooled and keep everything clean and internal will be quite the under taking, so gl to you and keep the pics coming. I couldn't do it so I'm very interested in your build progess and pics.
    andyc
    You tried to do 3 loops?
    I was thinking going SLI,
    PA120.3/ 2xGPU (External)
    PA120.2/CPU (External)
    Adding PA120.1/ Chipsets,Mosfet,Ram,HDs to the Harddisk area, since all my disks will go the the left compartment, i dont need the HD case.
    SO i want to ask, is it worth it to go SLI? Big difference?
    Now im going single on maximus board and mostly online FPS games in 30in LCD
    TKS``
    Nov 2007
    Colorado, USA
    Hehe, thanks for the positive vibe everyone. I'm pretty stoked on getting it together too! I just started a new job tho so things are gonna be slow. It will get done ... just be patient
    As far as gaming goes, SLI is absolutely required for a 30" monitor. The native res of 2560x1600 means you will be GPU-limited if you don't go SLI. At lower resolutions you really don't need it (yet) for good framerates in modern games, but at that high res you'll be lucky to get ~30fps in most games with a single card. Keep in mind that I'm talking about maxing all the settings cause that's what I consider true gaming. You could get away with a single GTX if you were willing to crank settings down a notch or two ... that's what I'm doing with my current in-use system and it runs most stuff ok. Just not fantastic.
    With 8800gtx SLI and this system on air, I can play COD 4 with everything, I mean EVERYTHING maxed out on my HP 30", and get a minimum of ~50fps. Most of the time it's in the hundreds, however I like to use vsync so 60fps is happyland for me. With water I'm hoping to get a minimum of 60fps in everything since I should be able to overclock it significantly higher. In retrospect I probably should have gone with the Ultras instead of GTXs since their pricing is not as ridiculous anymore. Oh well it's an easy swap
    My bike is a GIANT NRS-C1, with a carbon frame it's super light and has enough travel for my limited riding. I'm no pro lol so mad travel would just make me work harder. I ride mostly x-country in the mountains nearby, but it's too damn cold now so it will sit inside for a while and I'll get fatter
    I can't imagine how you couldn't fit even the most extreme build into this case, there is just so much ridiculous room in there! Oh well I hope what I do gives you some ideas so you can try it again.
    As far as mounting rads, after tons of online research I was unable to find out exactly what the spacing is for the holes on the back. So I just decided to buy the g0ddamn thing and find out!
    The spacing is a square, 240x240mm. In other words, you can stick 4 120mm fans up there and they will all be touching with no space in between. This of course limits rad selection tremendously, as most rads are > 120mm wide. I found the Magicool Extreme Slim Profile rad at Performance-Pcs and I think it will do the trick since it's exactly 120mm wide. We'll see, it should be here next week!
    Anyhow I will have more pics soon, I have just completed modding the Sunbeam Rheobus into the 7" drive bay. Needed the room down below (only 5 bays are exposed) plus it just looks a whole lot cleaner.
    More soon, please be patient
    Mar 2003
    The Netherlands
    Looks cool, never noticed that case before...
    Oh don't think Crysis will run @ 60 fps or more with ALL settings maxed and very high
    It tends to be VERY powerhungry
    lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
    *phone rings*
    Friend: Do you have a spare PSU lying around?
    Me: No why?
    Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
    Me: what PSU was that again?
    Friend: Antec 480w
    Me:........
    Xtreme Mentor
    Sep 2007
    Yeah, I have a Specialized Demo 7 (bike). Awesome bike, I can hit some pretty big drops on it (5-6ft. range). I also race downhill, and that's pretty fun also.
  18. #18
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Cut the back of the case, make an aluminum plate to mount two pa120s side by side and then pop rivet the plate to the case with the rads inside.
  19. #19
    Nov 2006
    A great place again
    No but I'll take some later today. I have 2 gtx240s in mine I wish I had pa120.2s instead, but if I did the fans would have to mount outside the case due to the tc rads being thicker.
  20. #20
    Oct 2006
    England, UK
    Im so tempted to get one of these Cases for an Ultimate Air cooling solution with loads of space. I would have to spray the case black though and get the version without the window as i really dont like silver cases or cases with windows.
  21. #21
    Nov 2006
    A great place again
    Mine is black with no windows but they all have the same front.
  22. #22
    Oct 2006
    England, UK
    Yea i was just going to buy it and then respray it black, i still might just get one at the end of the month because i have a couple hundred £ spare and have always looked at buying that case purely because there is so much you can do with it.
  23. #23
    Xtreme Mentor
    Sep 2007
    Quote Originally Posted by Scubar View Post
    Just get a MM.
  24. #24
    Nov 2006
    A great place again
    got any pics of that or a build log, be nice to see.
    andyc
    Here's a few pics. (I live in a dust factory)
    I cut this with a jig saw. It's kinda sloppy but I never look at this side.
    Click image for larger version.
    There's another 50z in the bottom of the 5.25 drive bays.
    It's one big loop. Pump/8800gtx/rad/cpu/pump/rad/and back to the bottom pump with a T just before each pump for fill, drain and air removal.
    The rads I have require to much airflow so I use the noisy fans.
    PA120.2s are the way to go, with quiet fans mounted outside the case.
  25. #25
    Oct 2006
    England, UK
    Not keen on Mountain Mod cases, All of them are cubes which i dont really like the look of.
