Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Crossfire 2900xt 1Gb on P35 vs X38
    Nov 2006
    Jonesboro, AR
    I'd like to see anyone else's results if you have them. Here we go:
    Ok so I just got my second 2900xt and my new PSU, so I'm going to compare this GPU setup on the P5K Deluxe with the X38. I'm running the following environment:
    Vista Ultimate x64
    Catalyst full install 7.10
    In 3dmark all extra processes are killed. Other benches have the following running:
    FRAPS
    LCD studio
    Setpoint
    Rivatuner
    LCD Manager
    I have my PCI-E bus at 115 MHz.
    Here is my first run at stock clocks (825/1175) with the P5K and Crossfire:
    Here is Crysis GPU x64 bench batch file......confirmed that it doesn't support Crossfire yet. I'm going to see if I can edit the .cfg file to enable this manually...
    The first screenshot is with Crossfire. The second screenshot is with the single card. The difference is basically experimental error.
    Crossfire
    Single card:
    Ok here's an update with the Lost Coast bench. The exact same settings as above.
    X38 results will be here tomorrow or Saturday....most likely Saturday.
    Q6600 G0 @ 3.8 (475x8) 1.496V || ASUS Maximus Formula X38 || 4x2GB Geil Evo One DDR2-950 5-5-5-15 ||
    Sapphire 4870X2 857/1000 || XSPC Delrin full coverage block || MCP655 || D-Tek Fuzion Nozzled ||
    Black Ice 480GTX 8 120mm Yate Loon push/pull || Silverstone DA850 PSU 70A +12V || Auzentech Prelude ||
    Vantage P15071 in Vista x64
    Mar 2005
    Cool deal man, i've been looking for "real world" comparisons like this.... Most of teh X38 board reviews have been with 1 friggin ATI card, or a Nvidia card....
    X299X Aorus Master
    I9 10920x
    32gb Crucial Ballistix DDR4-4000
    EVGA 2070 Super x2
    Samsung 960 EVO 500GB
    4 512gb Silicon Power NVME
    4 480 Adata SSD
    2 1tb HGST 7200rpm 2.5 drives
    X-Fi Titanium
    1200 watt Lepa
    Custom water-cooled View 51TG
    Nov 2006
    Jonesboro, AR
    Well as soon as I can get the damn thing to POST with my memory I'll have some results up.....probably going to have to RMA on Monday, as I wasted 2 hours last night fiddling with it.
    Dec 2006
    Finland
    Excellent thread! Can't wait results. I've seen ONLY 2 similar comparisons in the net. I think many videocard reviews give somewhat differing results with crossfire because it depends their system setups. I'm really considering crossfire, but can't decide P35 or to wait x38 becoming more affordable.
    Here are links to two similar tests I've found:
    Bit Tech CrossFire Comparison: Intel X38 vs. P35
    OCW: Gigabyte P35 vs. x38
    Nov 2006
    Jonesboro, AR
    We'll I'll have all the info with Crysis benches. This will include the retail version come the 13th (or 14th....whichever) as well as the next set of drivers coming in a few days.
    Mar 2005
    North USA
    Awesome, thanks for doing this...
    Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
    6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
    Sapphire 5870 @ 985/1245 1.2v
    X-Fi "Fatal1ty" & Klipsch ProMedia Ultra 5.1 Speaks/Beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
    WD 150GB Raptor (Games) & 2x WD 640GB (System)
    PC Power & Cooling 750w
    Homebrew watercooling on CPU and GPU
    and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
    Windows 7 Utimate x64
    Mar 2005
    I aggree, good call man, too bad your having some issues at the moment with the damn hardware...
    X299X Aorus Master
    I9 10920x
    EVGA 2070 Super x2
    4 480 Adata SSD
    X-Fi Titanium
    1200 watt Lepa
    Nov 2006
    Jonesboro, AR
    \/\/00000000000000000000000000000T!
    I got my X38 up and running. The issue was that the mobo sets the voltage to 1.8V by default. I went by Circuit City today and bought a stick of Kingston Value RAM DDR2-667 for $45 and it booted on the first try. I then set my VDIMM to 2.2V and shut down. I then installed 2 Ballistix DIMMS and it POSTed! I set the timings and I'm good now.
    BTW I originally bought a stick of DDR2-533 and it wouldn't POST either, but the DDR2-667 would.....if anyone else is having this issue.
    I'm going to flash to the latest stable BIOS and check up on the 0701.
    Mar 2005
    Outstanding, sounds like you got lucky!
    X299X Aorus Master
    I9 10920x
    EVGA 2070 Super x2
    4 480 Adata SSD
    X-Fi Titanium
    1200 watt Lepa
    Nov 2006
    Jonesboro, AR
    Luck had nothing to do with it......all mad skills my friend
    Nov 2006
    Jonesboro, AR
    Ok here we are! 3dmark06 got quite a boost Especially considering the lower memory frequency and FSB...
    Nov 2006
    Jonesboro, AR
    Ok here are the Crysis CPU and GPU benches respectively. It seems that lowering the FSB affecting the CPU score a bit....on the minimum side of things.
    Lost Coast is next!
    Dec 2006
    Finland
    Canyon flight shows 20% improvement.
    Nov 2006
    Jonesboro, AR
    Quote Originally Posted by L7R View Post
    I know it's crazy isn't it?
    Nov 2006
    Jonesboro, AR
    3dmark06 at 3.4 GHz Getting up there!
    Sep 2007
    very nice. can't wait to see what the new 3870's are throwing down!!
    Mar 2005
    Nice, so crossfire is working in Crysis?? I know that i had heard that SLi is not...
    X299X Aorus Master
    I9 10920x
    EVGA 2070 Super x2
    4 480 Adata SSD
    X-Fi Titanium
    1200 watt Lepa
  18. #18
    Nov 2006
    Jonesboro, AR
    Quote Originally Posted by screwtech02 View Post
    No, it's not working. I'm going to try the config line :
    r_multigpu 1
    and see if that works, but I doubt it. The game has to have a profile for it, thus utilizing alternate frame rendering mode. The FPS is the same as with a single card.
  19. #19
    Nov 2006
    Jonesboro, AR
    Ok here is Lost Coast:
  20. #20
    Mar 2005
    So, so far about a 11-1200 point difference in 06 between the 2 chipsets?? That is a real marginal call for people to upgrade, although the X38 is 2.0, which is kinda "futureproof" to a extent....
    X299X Aorus Master
    I9 10920x
    EVGA 2070 Super x2
    4 480 Adata SSD
    X-Fi Titanium
    1200 watt Lepa
  21. #21
    Mar 2005
    North USA
    Quote Originally Posted by binormalkilla View Post
    I love you in a completely non-gay way. (not that there's anything wrong with that)
  22. #22
    Jul 2007
    Kentucky, USA
    Quote Originally Posted by Truckchase! View Post
  23. #23
    Jan 2005
    norway
    Does x38 got 48 pcie lanes 2*24 and p35 got 2*16 =32
    cpu:qx9650@4ghz
    ram: gskill pc8000qt 4*2gb
    MB GB X48-DQ6
    Gfx 9800gx2
    Disk:2*1tb raid0
  24. #24
    Mar 2005
    North USA
    Quote Originally Posted by hardrail View Post
    It's a joke. It's alot of work to put together those results. It was funnier when I typed it than when I read it. Long story short, thanks!
  25. #25
    Sep 2007
    i actually got a chuckle out of it.
