Errrr..
If you're asking why not in this price category, it's because X38 has always been intended to be a high-end chipset.
Errrr..
Core 2 Quad Q6600 @ 3.81GHz (423MHz x 9) 1.47v vcore + Thermalright Ultra-120 eXtreme w/ Scythe S-Flex 120mm
2 x 1GB Crucial Ballistix PC2 6400 @ 1016MHz 5-5-5-15 (5:6)
Leadtek 8800GTS 640mb @ 650/1000
DFI LANParty UT P35 T2R
Corsair HX520
Lian-Li PC-A70b
Seagate 7200.10 320GB (primary) + Seagate 7900.9 160GB + Maxtor Plus9 160GB + Western Digital MyBook 500GB Premium ES Edition
Viewsonic VX2025wm
Looks a good board again from DFI.
But the chances of it hiiting uk soon look slim if the DFI LP UT P35-T2R is anything to go by. Only one place has it available
Intel Core 2 E8400 Q750A @ Testing
DFI LanParty UT P35-T2R
Crucial Ballistix Pc8500/Corsair Dominator Pc8500 @ ?
BFG 8800GT OC
CM Stacker 810-T01
Swiftech Apogee watercooled
Hot Chip
Took back my P5Ke for this but looks like its going to be a while for us people in Oz!
ebuyer.co.uk has the T2R.
And, Im in the market to replace my P5B-D.
This could be the board :o
Grrr! Still waiting!
I couldnt be bothered waiting and bought the LP-P35 for $199.
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
Challenge the limitation of patience waiting for this board to hit the market in "limited" quantities....
E8400
ECS 8800GT-SLI
Asus Striker II
OCZ 4GB
http://www.motherboardpro.com/DFI-La...ard-p-428.html
From the other thread - ETA 18th Dec
Anyone got it yet? Wanting that color scheme so bad..
DFI SLI-DR Expert (12/5/06)
AMD Opteron 170 (CCB1E 0550 VPMW)
2 x 1GB Team Xtreem PC4000 Samsung UCCC
Enermax Liberty 620W
Sparkle 6800GT 420/1050
Storm G4 Waterblock, MCW55, MCP655 Pump, Dangerden Asus AN8 Chipset Block
Radiical Radiator
LG Burner
2x Seagate 200GB SATAII HD @ RAID 0
CM Stacker
Taking pre-sell orders.
Gaming rig
CPU.........................Intel QX6850 @ 3800, 8x475
Motherboard.............DK P35 Dark
Video.......................8800 Ultra
RAM.........................4x1 OCZ Titanium Alpha VX2
Hard drives...............2 Raptors in RAID0
Sound card...............X-Fi Fatal1ty, Medusa 5.1 headphones
PSU.........................PCP&C 1KW(custom build)
CPU cooling..............Liquid
Hardware cooling.......Liquid cooled card and NB
Case........................Custom 22" cube by M.M.
OS...........................XP Pro
Arrived today, sooner than expected. For those concerned about the caps, they are all solid on the board I received from motherboardpro.
E8400
ECS 8800GT-SLI
Asus Striker II
OCZ 4GB
PH.II X2 545@X4 B45
Asus Crosshair III 1003
4Gb G.Skill Ripjaws
Full @ir cooling sys
The pictures aren't linked to larger version
Current setup: http://www.xtremesystems.org/forums/...postcount=1843
Waitin on mine as well! Hopefully gonna clock well with Penryn!
Was thinkin of upgradin to this... think its worth it? :P
My P5W is kinda dying on me...
[i7 4770K] [Z87 Gene VI] [8GB Sammy] [GTX780] [H80i] [AX850] [350D] [XL2720T]
Any results yet? how is the Vdroop?
Opteron 170 CCBWE 0546XPMW @ 2.8Ghz ~ DFI NF4 Ultra-D 704-2bt
Geforce 7950GT @ 1.53v 700 / 825 ~ OCZ GameXStream 700w
2 x 1G Crucial Ballistix (new 5B-F's!) 3-3-3-8@260mhz@2.65v
Western Digital Raptor 74G ~ Maxtor DiamondMax10 250G
Westinghouse 37" 1920 X 1080P
Intel E4500 (Q9450 in the new year)~TRUE 120mm~LanParty DK P35-T2RS
BFG 8800GTS (G92) with AC S1 (voltmod comin')~X-Fi XtremeMusic
4x1 Crucial Ballistix 8500~GameXStream 700w
WD RaptorX 150G 10K ~ WD SE16 500G
The northbridge has the "warranty void if removed" sticker. Seems a little odd considering the target audience for this board.
I believe the windows smartguardian system temp. to be the same as PWM/voltage regulator. They get hot, mine hit 79 celcius under full load... northbride 54, and cpu 70 at 425fsb x 8. (ambient 21, everything air-cooled)
Stock-cooling leaves something to be desired. I may have to get creative and add some small fans on the voltage regulator heatsinks, etc.
[IMG=http://img524.imageshack.us/img524/4583/http://img524.imageshack.us/img524/4583/34screenyvz7.th.jpg]
E8400
ECS 8800GT-SLI
Asus Striker II
OCZ 4GB
I just ordered mine from motherboardpro last night. Hopefully it will ship today and get here soon.
I'm replacing my DFI p965 board which has been absolutly a blast to use. It has been so far the most stable motherboard I have owned. I will be using it with an e6600 until the new chips come out and the TR-extreme 120. I also ordered an Asus PK5-e but that will be RMA'ed for this
