G.Skill released a new DDR3 product for the high-end computing, the F3-12800CL7D-2GBHZ. From the productcode you can see this memory runs at DDR3-1600 (PC12800) with a CAS# latency of 7 clockcycles. The "HZ" serie stands for a high-end product from G.Skill, like the DDR1 PC4000 2GBHZ.
Last week I received one of those kits from G.Skill. As we usual expect from G.Skill this product comes with a pretty nice box.
Inside the box you can find two 1GB modules with aluminium heatspreaders.
As you also can see on the sticker, this memory is rated at DDR3-1600 with main memory latencies of CL7-7-7-18 (Tcl/Trcd/Trp/Tras) at 1.9V.
I have tested this memory on a DDR3 based platform with the following components:
-Intel Core 2 Duo E6550 ES
-Asus P5K3 Deluxe P35 (BIOS 0704)
-Enermax Liberty 620W
Now the results!
Stock testing...
I used Vista, so the benchmarks results are a little slower then on XP.
DDR3-1600 7-7-7-18 2T 1.9V
DDR3-1800 7-6-5-18 2T 1.9v
It was easy to lower the Trcd and Trp to 6 and 5. It seems it does not require more vdimm but the performance improvement compare to 7-7 is minimum.
DDR3-1850 7-6-5-18 2T 2.1V
I could achieve a maximum stable clock at DDR3-1850. I think this has todo with my mainboard because the memory controller freaks out at DDR3-1900, which results in a endless loops of errors in Memtest.![]()
[UPDATE]After switching the modules from the orange banks to the black banks, I have come to some interesting results. DDR3-1900 7-6-5-18 2T was very stable at 2.1V.
DDR3-1900 7-6-5-18 2T 2.1V
Other benchmarks and comparison...
Everest Bandwidth and Latency sheet
SuperPI 32M sheet
The F3-12800CL7D-2GBHZ clocks really well, it can scale up without any sweat and higher vdimm to DDR3-1800 with CL7-6-5-18.
