Old Today, 08:05 AM #1
optimummind
Flashing 8800GT into GEN1 PCIE from GEN2 possible?
Hi guys,
I have a problem here with my old, yet trusty ASRock 775Dual-VSTA (VIA PT880Pro) and the new eVGA 8800GT KO GPU. It turns out that the 8800GT is not compatible with the ASRock mobo due to the GPU being PCIE "GEN2" according to ASRock tech support. They say they have the card in their lab trying to getting it to work on the 775Dual-VSTA but so far, they can't get it to work on the VIA chipset.
They did say, however, that they managed to get the Asus 8800GT card to work by flashing the GPU BIOS as a "GEN1" PCIE GPU, from its default "GEN2" PCIE GPU status.
My eVGA 8800GT KO is coming later today and I anticipate that my card won't work.
Are there any experts here with the knowledge to modify the stock eVGA 8800GT KO BIOS to set the GEN2 into GEN1 status?
Of course, you guys would need the BIOS file first. Which program do I have to use to extract the BIOS?
Help will be greatly appreciated.
-Optimummind
