XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme BIOS
Reply
Old 11-01-2007, 07:10 PM   #1
alexio
The Blue Dolphin
alexio's Avatar
8800GT bios for better overclocking! *test*
*Update*
For 1.1v vGPU instead of 1.05v just choose 1.1v for the "extra" voltage under: Voltages-->Exact Mode
The "Extra" voltage is either left bank, set to 1.05v or set to 1.1v in the stock BIOS'. In the last situation your vGPU is already set to 1.1v in the bios.
__________________
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
alexio is offline   Reply With Quote
Old 11-01-2007, 07:20 PM   #2
BenchZowner
One-Eyed Killing Machine
BenchZowner's Avatar
Send a message via ICQ to BenchZowner Send a message via AIM to BenchZowner Send a message via MSN to BenchZowner Send a message via Skype™ to BenchZowner
The voltage setting isn't working as far as I know.
The timings might help a bit, but setting tighter timings could also be beneficial ( that depends )
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
BenchZowner is online now   Reply With Quote
Old 11-01-2007, 07:31 PM   #3
dinos22
...you two characters
dinos22's Avatar
nvidia guys said these RAM sticks are DDR2000 rated but offically they run at 1800
if they are 2400 why can't i go past 2100 roughly LOL
i am definitely interested in RAM timings though
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 11-01-2007, 09:02 PM   #4
GregUMR
Whats the best tool to use for flashing these cards? I might give it a shot. My card current runs 42 idle / 58 load @ 758/1848/1040. I imagine I can push it more, but the core dies at around 775, the memory dies past 1060 and the shaders poop out past 1880.
GregUMR is offline   Reply With Quote
Old 11-01-2007, 09:06 PM   #5
BenchZowner
Maybe he's got a card with different ICs, and not the "suggested" 1ns modules from Samsung/Hynix.
__________________
Old 11-01-2007, 09:08 PM   #6
dinos22
dinos22's Avatar
pretty sure initial reference design is all Gay-monda
eerrrrrr Qimonda
__________________
Team.AU
Got tube?
Old 11-01-2007, 09:10 PM   #7
GregUMR
And so these Qimonda, what are they rated at ? 1ns? Its been a while since I did the conversion, isn't that 2ghz spec? Where is this 2400mhz spec coming from? Is that what qimonda rates the modules that come with the card at default?
Old 11-02-2007, 05:21 AM   #8
alexio
The Blue Dolphin
alexio's Avatar
Qimonda makes different bins for chips. The chips are of the exact same model, just like E6300 vs E6850, just a different speed bin. The fastest GDDR3 ICs Qimonda sells are rated 0.8ns (DDR2400) with slack timings. The stock timings of the 8800GT are somewhere between 1.0ns and 1.1ns spec. They are 1.0ns, but run DDR1800 (1.1ns speed) at 1.8v +-0.05v instead of the recommended 2.0v +-0.05v.
__________________
Blue Reviews:
Blue Guides:
Old 11-02-2007, 06:20 AM   #9
GregUMR
Ah, thanks for the clarification. I assume I should use nvflash 5.50?
Old 11-02-2007, 09:38 AM   #10
alexio
The Blue Dolphin
alexio's Avatar
Yes and use this command: nvflash -4 -5 -6 new_bios_name.rom
Make sure to have a PCI card at hand or you'll have to flash back blindly to recover the card if anything goes wrong. The chance is small but this is an untested bios. I've heard from other people that the 1.05v->1.1v vcore mod doesn't work, it won't bother you though. Please test it just for the timings
__________________
Blue Reviews:
Blue Guides:
Old 11-02-2007, 09:44 AM   #11
GregUMR
I used to flash vid cards all the time but its been a few years. Whats the backup current bios command and is there a nice cd/floppy image available for booting dos? I'm sure I can google it when I get off work and fine one. Do you know if it is even possible to get the voltage on a nvidia card to be increased through the bios? Man I'd love to get 1.1 or 1.15 volts on that core. I currently have 740/1836/1020 stable on atitool. I'm pretty sure with those volts I could get 775/1890/1020 stable. I don't have a pci card unfortunetely, but I can always boot blind as long as I've got a nice floppy or cd, I've done it before. I do hope your bios isn't unstable tho!
Old 11-02-2007, 10:00 AM   #12
alexio
The Blue Dolphin
alexio's Avatar
nvflash -b backup.rom
http://www.abitfaq.it/files/drdflash.exe
I don't think the 8800GT has the required circuity. Older cards like the 6800GT and 6800U could supply up to 1.5v (or even 1.6v?) from 1/3/1.4v stock.
__________________
Blue Reviews:
Blue Guides:
Old 11-02-2007, 03:23 PM   #13
GregUMR
I just tried to use nvflash and it claims that it can't detect any nvidia adapters. A quick nvflash -a returns the same message. I've only got the 1 evga 8800gt in my computer. I checked my dfi lanparty sli-dr nf4 board and set the init display first to pci-express. This changed nothing. Anyone got some ideas?
I was using nvflash version 5.50. Does that not support the 8800gt or something?
Old 11-02-2007, 05:23 PM   #14
alexio
The Blue Dolphin
alexio's Avatar
*nvflash -4 -5 -6 new_bios_name.rom* didn't work?
Latest nvflash (5.57): http://www.mvktech.net/component/opt...4d0315a358280/
__________________
Blue Reviews:
Blue Guides:
Old 11-02-2007, 06:37 PM   #15
GregUMR
Well I didn't want to flash without first successfully backing up the bios I'll try this new version.
Old 11-02-2007, 06:43 PM   #16
alexio
The Blue Dolphin
alexio's Avatar
Nibitor can do this too, in windows. Latest version: http://www.mvktech.net/component/opt...19ab25724cb04/
Open Nibitor->tools->Read BIOS->Read into File
__________________
Blue Reviews:
Blue Guides:
Old 11-02-2007, 06:52 PM   #17
GregUMR
Ok, flashed successfully now as the new 5.57 recognized my 8800gt fine. I just reinstalled the drivers, loaded up rivatuner, 1050 mem ( which crashed on me before ) and atitool scan for artifacts....instant green artifacts and hardlock. I'll let ya know if I get any improvements in core or shader speed.
Old 11-02-2007, 06:54 PM   #18
dinos22
dinos22's Avatar
can you undervolt the GFX card
NOW that would also be worth flashing for for many
__________________
Team.AU
Got tube?
Old 11-05-2007, 03:18 PM   #19
winbond
i haven't tried your bios but i made a custom one and tried it out,
voltage 1 and 2 set to 1.1v
voltage 3 and 4 set to 1v
this didn't help , my overclock on the core got worse, i haven't tried shaders
custom ram timings with default voltage: top-down, left-right,
40,52,30,16,16,12,12
it didn't help at all for the ram oc, looks like really crappy ram
winbond is offline   Reply With Quote
Old 11-09-2007, 03:45 PM   #20
JKDC
Edit through NBitor and give it 1.2 volts. 1.15 should work too but I haven't tried it. This DOES work. I left specifics in the 8800GT volt mod thread. It looks like you raised idle and dropped 3D voltage. Edit the voltage table to give 1.2 volts and put 1.2 in extra and edit the VID for 1.2 for Extra and 3D.
JKDC is offline   Reply With Quote
Old 11-10-2007, 09:48 AM   #21
F@32
I am Xtreme
F@32's Avatar
Anyone tried setting 2D clocks/voltages and 3D clocks/voltages in BIOS?
I currently have 1.1V in Extra and 750core/1825shader/1000mem 15min AtiTool stable... Will try 1.2 next and see where she goes from here. 50C under water.
Found a thread where 2D/3D voltages were set separately. Wonder if anyone can confirm BIOS mod with DMM?
__________________
Spectre x32BV-Full HD // GA-EP45-UD3P F8F // C2D E8400 stock //
Buffalo Micron D9 DDR2 4x1Gb // HD4890 1GB // Intel Pro 1000PT PCIe //
Creative X-Fi // Intel x-18M 2x80Gb // WD1001FALS // TRUE-120 //
Antec Quattro 850W // Win7
F@32 is offline   Reply With Quote
Old 11-10-2007, 10:34 PM   #22
Hazaro
Hazaro's Avatar
What is stopping you from putting 1.4V in the BIOS? The chip?
Hazaro is offline   Reply With Quote
Old 11-10-2007, 10:56 PM   #23
metro.cl
Xtreme X.I.P.
metro.cl's Avatar
Send a message via MSN to metro.cl
can you explain more how exactly you set over 1.1v with nibitor? i only see 1.1v as max available.
__________________
metro.cl is offline   Reply With Quote
Old 11-11-2007, 01:49 AM   #24
GAR
Xtreme Guru
Send a message via AIM to GAR
Tried the bios vmod, didnt work for me, no gain on OC.
__________________
GAR is offline   Reply With Quote
Old 11-11-2007, 05:17 AM   #25
F@32
I am Xtreme
F@32's Avatar
I don't think that soft mod will feed more than 1.1v. We need someone to verify it with DMM.
First you need to edit voltage table: Tools -> Voltage table editor (change entry 4 "VID 03" to 1.2v)
Next, update Voltages, VID mode first: Set 1.2v for "Voltage 4".
And lastly update Voltages, Exact mode "Extra":
I have set it to 1.2 and there is no difference in my OC from 1.1. I'm afraid volt mod is needed to get above that.
Next I will try to set 2D and 3D clocks. EDIT: I guess 8800GT has only Extra and no 3D, Throttle, 2D clocks in BIOS
MKVTECH.NET
Well it is not possible, in fact since we had only some GeForce 8800 GT BIOS's we just introduced the Extra setting as the GeForce 8800 GT doesn't have 2D, Thrtl and 3D at all. It uses a new structure with a 4th performance level which is new and only that one is active. So in the next version we might just hide the 2D, Thrtl and 3D in NIBiTor for the GeForce 8800 GT as those are no longer used nor valid and will never work. And no don't blaim us... This is NVIDIA that made this change on the BIOS structure and logic.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
