Initial numbers from the 8800GT in my machine, I maxed out the FSB and ran the initial benches with the video card at stock speed and LOD 0. The card is basically out of the box and load driver. I did tune for best performance in the ntune display performance tab.
What interests me in this card is the changes in the core as well as the new process for overclocking, I run a 24/7 machine so reduction of heat output from the new card I can notice.
The card is much smaller than the GTX/Ultra in physical dimensions and it only takes one PCIE power connector. The card is also a single slot card and with the fan at full speed it is noticeable.
The bolt pattern is different from the GTX/Ultra and I cannot confirm it matches the GTS or previous generation bolt patterns yet but chances are it does.
I used the newest Rivatuner to overclock the card with the stock cooler installed. I was able to push the core to 750Mhz pretty easy and the memory to its rated speed of 1Ghz.
Anyway, here is the card at stock speed in my rig and the overclocked scores below that.
Intel Yorkfield @ 4.8Ghz
Asus P5E3 480FSB 1:2 7-6-5-15-1t
Nvidia 8800GT stock
Corsair Dominator 1800C7 @ 2.2v
Enermax Galaxy 1000
Vapochill LS -50c
Validation link;
http://valid.x86-secret.com/show_oc.php?id=260903
Kicking over to 2008 Server 64 bit at the same cpu speed. Timing is 7-7-7-15-1t
Crysis benchmark GPU
Crysis demo CPU
8800GT overclocked to 750/1000 for all tests below. Dialing in more
For those of you with card heat issues then this is the card for you, this card runs much cooler in the case than the Ultra. The price seems decent for the performance. If it was clocked any higher it would price out the GTX too much. The new process is running fine and it will be interesting to see what these cards can do with more voltage.
retired AMD64 Opteron 170 Toledo CCBBE 0615EPMW
(CEO of Nvidia)
), Juan J. Guerrero
