[MemoryReaction] G.Skill F2-8000CL5D-4GBPQ - Low in cost, high in speed!
Introduction:
The F2-8000CL5D-4GBPQ kit is a new product from G.Skill featuring a new Powerchip IC. The sticks boast an impressive speed and timing set for a 4GB kit while carrying an even more impressive price tag. The kit aims to bring value and performance together in a trend we're seeing more and more of these days as DRAM prices continue to fall. The only question I have for you as I lead you into this review is this...is DDR3 really worth it?
Overall an excellent set of memory both for the user on a budget, as well as the enthusiast. These sticks proved to be excellent overclockers, even though they may not be breaking any records any time soon. They also ran extremely cool, and could definitely be run without a fan even at 2.2v without getting hot to the touch.
The sticks are very picky regarding certain timings, and not so picky at all when it comes to others. They love loose tWTR, tRAS and tRFC especially, while tRP, tRTP, and even tRRD can get fairly tight while maintaining stability and overclocking headroom.
To sum it up, a fun kit of memory to play with, very stable with cool operating temperature, and fast; able to be ran at over 1100MHz DDR with 5-5-3 timings! Combine that with the fact that you're getting 4GB of memory for a $189 (now $49.99!) dollar price tag, and you can't help but get a smile on your face.
Thanks to G.Skill for the review sample. Thanks to you for reading.
Good result for a 2x2 kit is there any improvement in frequency with "relaxed" trp, EnJoY ?
None really from what I noticed. I actually relaxed timings all the way to 5-5-5-20-55-10-11-11-11 and saw only a 10MHz increase in overall stability. I maybe should that put that in my results..
good review man,you show mainstream users what they can except when u review ram.2.2volts,diff speeds,diff timings.right to the point,purfect lil review man.my buddy might grab these now u posted this review up,thanks.
sidenote:
i just got a ($80!)dfi 680i lt and ma cellshocks love it.800 4\3\4\10 1t 2.26v or 1200 at 2.3 5\5\5\13..the 1t 800 is way faster tho.
__________________
Stacker830 Watercooled
windows7 ultimate 64 bit!!!
DD MC-tdk on EO-e8400@4.1Ghz
1.24volt, 513x8,31c/load 55c,fsb term 1.29
Swiftech p655 pump,1\2 tygon,dd h20 nb 1.29
9x120 sunnons on lamptron fc3 controller,
triple 120mm rad. 3 x veliciraptor 150,s raid 0
biostar i45 mobo(this mobo is amazing)
xfi-xtrememusic,klipsch ultras, sen hd-570s
co0lermaster-1250 watt real pro p\s 99ampz!
Evga CO-0p gtX 295 on 22"Diamondtron p1230
Hi quality CRTS are built for gaming!!!O.L.E.D is the future,not Liquid Crap Displays!
cod4 @ 2048x1536 75hz/75fps
If you believe in Jesus Christ and are 100% proud of it, then put this in your sig
G@m3r 4 L1Fe!! http://service.futuremark.com/compare?3dm06=11372480
new e8400 EO stepping http://www.xtremesystems.org/forums/...d.php?t=224960
h20 pc pics-- gtx 295 http://www.xtremesystems.org/forums/...post3784384new
Got my kit also, the RAM looks impressive (to look at)...even at 2.1V they run very cool....much cooler then my Corsair DDR2-8500 2GB kit which ran 2.2V and hot super hot.
Right now i am just doing basic functionality testing using recomended timings and voltage, 5-5-5-15 set manually in bios, all sub-timings to auto, voltage at 2.1V in bios.
FSB ratio adjust to get 1000MHz, i ran the embedded Vista memory diagnostic tool, choose the advanced setting which takes several hour to complete and got a 100% pass.
More testing to go, i am hoping to get 1066MHz stable with this memory, Vista shows 3,582MB of memory
Guys...my kit is now stable at 1063MHz with 2.1V set in bios and manual timings of 5-5-5-15, all sub timings set to Auto in bios. I did a 10 hour Prime95 stress test using the latest 25.5 build, passed.
I'm hoping these sticks will get 1100MHz with 2.1V....has anyone tried to do this with just 2.0V?
But gues what?....the price has dropped $20 in the few days since i got it!
Tracers will be twice as expensive, but will likely clock a bit higher and/or offer tighter timings, but with higher voltages.
Well, it's only a $20-25 more expensive in the UK (more of a case of the G.Skills being more expensive, than the Crucial being cheaper). I think my biggest concern is any issues associated with filling 4 DIMMs.
Very nice to see these results...as I've got the exact same memory on order to pair up with a G0 Q6600 in my new Shuttle SP35P2 that's sitting empty on my desk!
Even with the shuttle and this chip I've seen 333x9 and above done quite easily...and to know that the memory should be able to handle it is comforting.
Thanks for the review...it'll be interesting to see what I can do with minimal timing options in the Shuttle.
__________________
• Intel Core 2 Duo E8400 @ 4.25GHz 1.424v
• DFI Lanparty JR P45-T2RS
• 2x2GB GSkill PC2-8000 @ 1,001MHz 5-5-5-15
• Asus ENGTX260 896MB @ 700/1,509/2,200
• Silverstone TJ08 mATX Case
• Silverstone Strider 750W Modular PSU
• Seagate 7200.11 500GB - SATA
Good review, I have been wanting to go 4GB for my Vista 64 for months, but my mem controller could not handle 4x1 at my overclock settings even with great cooling. This now solves that problem and its now $155 at Newegg
So I just got a pair, thanks again. I will start my testing next week on the QuadGT. Will see if I can do 5-5-4-12, which is what I am running now with the OCZ's but at 2.2V. If I can do the same at 2.1V I will be a happy camper.
__________________
E8400 @ 4.2 Ghz (525x8)
Gigabyte EP45-UD3P
Corsair Dominator 4GB (2 x 2GB) PC2 8500 2.1V
PowerColor 4870x2
150GB Western Digital Raptor
500GB Western Digital 5000AAKS
Westinghouse LVM-37w3 1080p Monitor
Vista64
Cooling: CPU-OCZ Vendetta2+Scythe S-FLEX SFF21F 120mm, Silverstone TJ09 case with 4 120mm yate loons.
I didn't have that luck with that Gskill kit... It doesn't Cas 5-5-4 2T even at 533Mhz 2.3V (or less V). So my max timings are 5-5-5 2T (also doesn't support 1T on my Maximus Formula SE). Using those timings also doesn't pass over 545Mhz, from 2V to 2.3V.
Edit: Funny thing... I was going to unplug the memory from the motherboard and I got the heatsink on my hands while the stick itself was still plugged in the mobo XD Looks like those "paper clips" doesn't make enough pression.
PD: ICs have this written: XBH373-AA3G any ideas of which chips could be that ?
__________________
|| Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
|| XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
