Best I can do was 4.45GHz - I think I need better memory. Anyhow the specs are the following:
Gigabyte P35-DQ6
Scythe Infinity
Corsair DDR2 800 4-4-4-12 1GBX2
Any suggestions or recommedations?
Gigabyte P35-DQ6
Scythe Infinity
4450 on air is still nothing to sneeze at
These chips are looking really nice!
EVGA z68 FTW
i7 2600k @ 4.8
8gb DDR3 1600
3x GTX 580 3gb HydroCopper2
Silverstone Strider 1500W
Areca 1880i w/ 6x intel x25m
On water
Is that true that the QX9650 is TDP 130W ?
|Asus Maximus 4 Extreme B3_ Bios 1904 / 3202
|Intel i7 2600K / 3770K Corsair H80
|G-Skill F3-18400CL8D-4GB PIS @ 2133mhz 6-9-6-24- 1T 1,71v
|MSI Lightning 580GTX 1,5GB
|OCZ vertex_60Gb FW_1.6
|Corsair 750W AX
[testing...] "Dude, BSOD is something that... doesn't suit me!"
Great result The only problem that stands out to me is the difference in core temps at idle. 33 - 47c.
RLM
QX9650@4.5ghz Vapochill LS
E8600 (Boxed)
Rampage Extreme
OCZ Gold DDR3 (8500) 1680 7-6-6-20-2T
4870x2 Vmodded + Ek Nickel
9800GX2 Vmod + EK H20 (Stored)
Thermaltake TP 1000W
Lian Li P007 Case
he's using a scythe infinity heatsink...not the best.
BIOSTAR TPOWER I45 UNOFFICIAL THREAD
BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
ABIT IP35 PRO HEATPIPE MOD
ABIT IP35 PRO BIOS FLASHING PROCEDURE
IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
There are a lot of these processors around here already. I hate you all haha
Seriously, it was a nice clock for what you were working with. If you had a better heatsink and RAM, i wonder how high you could push it.
E8400 @4.3 | Asus Maximus SE | 2x2GB G.Skill PC2-8000s | Radeon X1950XT | Raptor X, Barracuda 7200.10 320GBs
I have better coolers and new water kit but too lazy to open up the other computer or mess with the water. Also, if you put 2 fans on the Infinity, I think it cools better than Tuniq.
Anyhow, I think I found the everyday sweet spot for this setup.
4.2GHz @ 1.44V running very cool and +5 hours orthos thus far.
very nice !..imagine performance on wc,it would be very impressive.
P5K Pre | Q6600@3600Mhz 1.4v | 4G Crucial PC8500 | EVGA 8800GTX | Raid 0 RaptorX 150g | Silverstone OP1000 | LIAN-LI PC-V1200B Plus II
Heatware
i was waiting to trap someone...you'll do...LOL
excellent review by Spawne32.
http://www.xtremesystems.org/forums/...d.php?t=158187
Nice one, get some serious Wc and try more :P
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
Cooled by:
Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
First and foremost let me say that you have one very nice CPU there.
As for suggestions or recommendations, tighten up those memorytimings or get yourself some decent sticks of RAM!
With some tight memtimings i think you'll be knocking on the 9 seconds door for 1M if not breaking into 9 seconds territory.
All X9650 cpu's we've seen so far seem to be able to run 1M at 4.5GHz on either air or water.
More and more ES chips come floating around it seems, if Intel is looking for someone to put one of these Yorkies through it's paces i'll be more than glad to volunteer.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
OK!
I will order some new memory on Monday. Any recommedation on good DDR2 sticks?
anyone have a retail chip on air to compare?
retired AMD64 Opteron 170 Toledo CCBBE 0615EPMW 3.1GHz 1.52V with removed IHS
Intel Q9650 L827A 4.2GHz (467*9) 1.288v
G.Skill 8GB F2-8000CL5D-4GBPQ
ASUS P5Q Deluxe BIOS V1406
eVGA GeForce 8800GTS SSC 512MB
3x Western Digital 640GB Black RAID 0+5
Creative SB X-Fi XtremeGamer
Swiftech H2O-220 Compact 35C/58C
Cooler Master Real Power Pro1000 RS-A00-EMBA 1000W
Dell 2405FPW 24" WUXGA
Antec Twelve Hundred
Heatware iTrader eBay
Just FYI - Im no expert on OCing. Im sure others will have much better results than me. One thing for sure, this CPU is the best I ever tested for OCing.
still, you are doing a darn fine job.
You're doing fine for a non expert, if you really want to know the limit of this CPU, send it to me.
If you want to know what good overclocking RAM modules are, have a look here: http://www.xtremesystems.org/forums/...d.php?t=114977
