Results 1 to 21 of 21
Thread: Q6600 B3 Overclock Session
    Oct 2007
    Today I will be overclocking my Intel Core 2 Quad Q6600 B3 on AIR to the soundtrack composed mostly of Black Sabbath. I will be updating this thread periodically as the day goes by and my overclocks get higher. All temperature readings will be taken using CoreTemp and stability will be tested using SuperPi 1M.
    Patriot Extreme Performance 2GB PC2-9600
    DFI LANParty UT NF680i LT T2R
    EVGA GeForce 8800GTX
    Western Digital Raptor X
    PC Power & Cooling Silencer 750W Quad
    Thermalright IFX-14
    Oct 2007
    FSB
    Frequency
    Sep 2007
    New Jersey
    What kind of cooling are you benching with? using that watercooling setup? Any particular clocks you are going for??
    E8400 @4.3 | Asus Maximus SE | 2x2GB G.Skill PC2-8000s | Radeon X1950XT | Raptor X, Barracuda 7200.10 320GBs
    Oct 2006
    Nice OC
    but i can't see anything on those pictures, they're way too small
    Oct 2007
    I will get bigger ones up. I just hit 3800MHz.
    Sep 2007
    New Jersey
    Quote Originally Posted by Jigsaw View Post
    I haven't been able to get higher that 3.82ghz on air. Anything after resutled in a BSOD.
    Oct 2007
    Volts and temps?
    Sep 2007
    New Jersey
    Volts and temps?
    I'm not too sure as I'm at work now. I won't be home until tomorrow either. I think it do to my DS3R. It doesn't like anything over 425 with a 9x and even with 7x i can't even get close to 500 FSB. Any ideas? Where you able to have better luck past 3.8?
    Oct 2007
    Not yet. I have to update the BIOS so I can lower my Multi.
    Oct 2006
    I'm also trying to get my Q6600 (B3) working at 3800 (3825 actually), 425x9 but so far, i had no luck at all, only bsod.
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Why in first shot is COreTemp VID 1.1625, and after 1.325?
    Oct 2007
    I have no idea. Probably because I lowered the voltage.
    Oct 2007
    Sep 2007
    New Jersey
    Quote Originally Posted by Zone_of_Enders View Post
    What motherboard do you have?
    3.85 is nice. I wonder if you get it up to 3.9?
    Oct 2007
    Not on air. I will go on water next week. The mobo is listed in the first post.
    Sep 2007
    New Jersey
    Oh, I was asking Zone_of_Enders what mobo he we using. Sorry about the confusion.
    May 2007
    Quote Originally Posted by cadaveca View Post
    VID isn't current voltage.
    VID is the stock voltage set by Intel.
    What voltage are you pushing into the chip?
    I have a Q6600 on water, and at 3700MHz @ 1.425v (which it is not stable), it reaches temps much higher than your Q6600 on air.
    What were your ambient temperatures during these tests?
    Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
  18. #18
    Oct 2006
    Quote Originally Posted by mXpS View Post
    I'm using an ASUS P5K Deluxe WiFi, 0601 bios. At the moment 3720 MHz is the best i can squeeze from it, not entirely stable but i could run 1 SuperPI on that speed.
    Gotta do a couple of more tweaks to get it working at 3825 MHz before going to 3.9 GHz hehehe (by the way, everything on air, Thermaltake BigTyphoon)
  19. #19
    Oct 2007
    I am up to 1.56v (BIOS) at 3700MHz + and nothing above 3600MHz is Orthos stable. My ambient temperatures are around 65F. The processor is lapped and so is the IFX-14. All the temperatures you see are idle.
  20. #20
    Oct 2007
    Europe
    Tight overclocking the B3 mate! Great work. How do you like the IFX-14? It is one hell of a cooler and it challenges pretty much of the aftermarket watercooling setups. And if it is coupled with 2 140mm high flow fans, it will make wonders!
  21. #21
    Oct 2007
    It is awesome! I am going to put two 250mm fans on it tonight
