These are all just preliminary results. You guys need to give me a few days to play around. But so far, I am very happy with my new X38. The Gigabyte DQ6T-ddr3 does 515 FSB right out of the box so far. I did not have to change MCH or southbridge voltage at all and no tweaking was required. C1E, TM2, and all CPU options have been disabled in the Phoenix Bios. I must say this is the first motherboard that I have ever used that was simply plug and play to a 515 MHz FSB. Even the P5B required major tweakage for 515 personally. This board is a pleasure to work with. My first initial test after installing Vista was trying out 7 X 515 @ 1.4vcore. Everything worked out great and vista was browsable and functioning great.
After trying out the initial FSB test I am now currently running the system COMPLETELY stock 9 X 333, and the memory is at 1300 mhz 9-9-9-20 (well below its rated 1866). The reason for this is because I would like to get some preliminary STOCK crossfire results.
RIG:
Gigabyte DQ6-T
E6850
2 X 1GB Patriot DDR3 1866mhz rated 9-9-9-20 (1.9 volts)
2 X Sapphire HD 2900 XT's in Crossfire with all 32 lanes!!!
The packaging of the board was exceptional. All shiny and perty:
Here are some pictures after adding the crossfire 2900XT's. I was surprised to see plenty of air and space between the two 2900XT's. I was expecting a crossfire sandwich and was pleased to see a little more space than expected. As you can see, each card comes with a single dongle to connect to its CF counterpart:
I just finished setting up cooling for my rig. I have a slightly modified Koolance EXOS2 with short access tubing directly to the CPU. The waterblock I currently chose for this setup is an Apogee GT. Bios CPU idling temps at 1.40 vcore = 29*C.
Some pictures of the Phoenix bios provided by Gigabyte for the X38:
