XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 10-20-2007, 03:56 PM   #1
messerchmidt
P35C-DS3R VDroop and Vcore mods here!
hey all. i found this picture @ madshrimp.
the voltage between point 1 and 6 is 22.33k ohms (according to my fluke 25 MM) - I used a 50k ohm VR/POt between the points. Set it to 20k ohm and started down from there slowly. With trial and error, I have gotten the drop down to less than .01V, almost .0v drop - soildering this is a b*tch, esp point 6, not for novices!
For the vCore mod (RED DOT), I used another 50 ohm VR/POT @ about 46.6k ohm to ground for the vCore mod.
Using the latest f4 bios
Finally figured out the %^&#$@%#$% vdroop and vcore mods P35C-DS3R - so far its working for me!
messerchmidt is offline   Reply With Quote
Old 10-20-2007, 05:21 PM   #2
ceemic
ceemic's Avatar
Send a message via MSN to ceemic
I used the "red" dot to measure Vcore:
BIOS 1,3625V - 1,353 idle/1,357 load
BIOS 1,4000V - 1,392 idle/1,395 load
BIOS 1,4500V - 1,442 idle/1,445 load
Is it possible that my board doesn't have vdroop It overvoltages 0,003V at load? CPU-Z shows ~0,03V droop and idle voltage is also lower than applied in BIOS...
go figure...
__________________
Vmods - what can possibly go wrong? ©
ceemic is online now   Reply With Quote
Old 10-20-2007, 05:56 PM   #3
messerchmidt
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
