Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: Xtreme Xterior Cooler
    Xtreme Cruncher
    Jun 2006
    On top of a mountain
    Talking Xtreme Xterior Cooler
    Check out this rig I built today. Fall is here in Northern Virginia and I have been waiting for this moment. With 10C ambients just outside the window it only made sense to mount the rad where it would do the job the best: outside the house
    Quote Originally Posted by CyberDruid View Post
    The first couple of times I fired up the pumps I got a quick jab of PSI on the gauge then nada. I kept diddling and filling until I got a solid 2.5 psi then fired up Black Knight and popped into BIOS ASAP. After boot PC Probe registered 19C (it is about 10C lower than Core Temp which won;t work in Vista 64bit))
    Using a 110VAC CCL UV lamp for leak testing. That was not a leak but a little spill when connecting the line to the Window Box. I used 1/2" barb to 3/4" hose ends (solid brass) and they are very handy if you need to part lines or whatever.
    Wish I could find a 0-5 PSI gauge...or even 0-10. But at
    least I can tell in a heartbeat if there is an issue with the loop. At about $12 this is cheap insurance.
    It's a very simple yet weatherprof set up. The aluminum seals the gap at the window and locks onto the lip and supports the unit at a nice angle when clamped to the sill by the window. I cut a stick to wedge the window tightly against the unit and locked that into position inside the house--this would also prevent anyone from breaking in.
    The camera does not do it justice--but the UV lamp makes the "Rams Horn" tubing glow brilliantly outside :p
    The db-1 pumps are supported by the tubing and grommets in the acrylic. I use stainless steel pinchclamps so it is very very secure and no chance of leaks.
    I used 3 pin to molex adapters and taped them completely in 3M electrical tape to prevent any corrosion and routed a custom made female to female molex through split loom to the Silverstone DA 750 where it plugs directly to the PSU with a shemale molex.o..O
    Db-1 pumps are 100% waterproof...you could run them submerged. The rad is copper and brass and painted in black oxide so no corrosion issue there and the Panaflo 86.5 CFM fan is completely under the acrylic shield and pushes air through the rad--so no chance of sucking rain into the fan. I love OUTDOOR COMPUTING!
    I used a T-line and made sure it was long enough to be a lot higher than the highest point of the loop (the waterblock). The loop is filled with Dasani purified water and about 1/2 oz of tracerline Clear UV Blue. Filling was very safe and easy... I held the filport over a bowl in case of drips or burps and found that I could run the pumps with the filport open--which really aided bleeding the loop.
    A single db-1 might have been up to the task--but due the length of the lines I wanted to use (in case I choose to relocate the PC) and the restrictive nature of the Stinger waterblock I chose two. I am very happy with the results.
    The ambient continues to drop: now at 11.7C PC Probe shows 34C. Earlier today using the Monolith cooler with 21C ambient I was getting 54C load temps.
    Those sorts of intake temps are usually found in a AC unit/rad rigs or perhaps in a chilled water loop. I have gained over 20C in headroom--which means I can crank the volts and see if I can get this rig to run a bit faster.
    If you are lucky enough to be living in an area with low ambients like this you should definitely give it a try.
    BTW my Wife LOVES this invention. She puts up with my Farm in the music room...but I know the noise of the Iwaki and 6 Panaflos does get on her nerves at times. This rig will allow you to run a virtually silent PC.
    20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
    May 2004
    I like it, the Enviros should too. Using the natural resources without concenquence.
    Asrock Extreme3 Gen3
    Intel 2500K @5.0 1.52V
    Thermaltake Frio
    4-4GB Kinston HyperX 1600's
    1-256Gb Crucial M4 SSD
    Xion 1000W (Made by Superflower)
    2-Evga GTX570 in SLI
    Antec DF-30
    Windows 7 pro 64 bit
    Just a regular guy, Not Xtreme!!
    If I sound STUPID!! it is because I am.
    Not everyone can be a Genius!!
    Xtreme Cruncher
    Jun 2006
    It's been in the 80's until yesterday. Looks like it will stay reasonably cool until next year..so I thought WTH.
    Xtreme Mentor
    Mar 2007
    looks really nice
    Sep 2007
    Hawt.
    Xtreme Cruncher
    Jun 2006
    Now I want to put one in every window of the house and run them all in series
    Aug 2006
    Great. You may want to incorporate somewhat better shelter. The snow drifts can get obnoxious and it doesn't just fall vertically lol
    Sep 2007
    lol..How about making it even more obnoxious;
    http://www.xtremesystems.org/forums/...postcount=4784
    Xtreme Cruncher
    Jun 2006
    True. It's a rapid prototype. Ideally Iwould like to make it from polycarbonate and skip the aluminum...this kind of Home Depot angle gets grotty after a while.
    I think I might take the huge Iwaki driven cooler apart and mount all that stuff outside the window too...it would probably work better.
    Oddly enough the Wife does not mind odd looking PC cooling apparatus hanging outside the house...I guess anything is better than listening to the Iwaki 24/7
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by Canadmos View Post
    Maybe something more like a garden sculpture Perhaps a cooling gnome
    Xtreme Cruncher
    May 2007
    Fairmont West Virginia
    hell i ran across a post somewhere where a guy used his swimming pool as a res and just used it's evaporative cooling power for 3 crunchers
    CPU Q6600 @ 3.15Ghz D-tek CPU Block
    GIGABYTE GA-EP45-UD3R 350Mhz FSB
    RAM G.SKILL F2-8500CL5D-2GBHK DDR2 1066
    GPU Nvidia 8800GT MCW-60 700Mhz Core 1.0 GHz Mem
    PSU Cooler Master realPower 550W
    Storage 3 500 GB WD Caviar SE16 in RAID 0 + 300gb WD
    Misc. CM stacker STC-T01 w/ Cross-flow fan, 2 MCR-320 Rads, DCC 355 W/ Petras Top, 12 YateLoon D12SL-12, ~12ft Tygon 9/16 ID tubing
    Crunching for [XS]
    Sep 2007
    Will this setup create some condensation problems when the temperature dips a bit further?
    Feb 2007
    If I lived in your area, I'd sneak into your yard and caress the PA160 every night.
    Quote Originally Posted by dengyong View Post
    Started life as a FTW and ended up as a WTF.
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by Grafton View Post
    Bong Coolers...Those are definitely better out than in...nothing worse than spilled bong water
    I doubt it. In the Winter the house is very dry. Right now ambient is 10C...no probs so far.
    Quote Originally Posted by YugenM View Post
    Last year I had 7 rigs on the porch crunching away all winter...destroyed 3 motherboards and two CPUs from corrosion. One of the benefits of living at the top of a mountain at the end of a long gravel road...no unannounced visitors...lol
    But that was before Quad! No way am I putting my Quads outside
    Nor my HD 2900 XTs
    Aug 2007
    Longview,WA
    cooling gnome ftw! i love the idea
    -TJ07
    -Core i7 920
    -Rampage II Extreme
    -EVGA 8800 Ultra
    -Corsair Hx1000w
    -Corsair 6GB DDR3-1600 Dominator
    -Intel 80GB SSD gen.2
    -WD 6400AAKS Raid 0
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by The[R]eaper View Post
    Or one of those ornamental Japanese style Spirit Houses...hmmmm
    Outdoor Computing...why not
    Sep 2007
    Love the idea, I may make an improved version of this design for my first watercooling rig Just in time for winter, I wouldn't even need a fan on the rad xD
  18. #18
    Jun 2006
    The O.C.
    Better build a scarecrow on it b4 it gets covered with bird droppings, lol...
    Very green and very cool though.
    i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
    Asus P8P67 Vanilla
    Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
    Diamond HD 7970
    WD 600GB Velociraptor
    Corsair TX750W
    CM 690 II Advanced
    Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
    G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
  19. #19
    Xtreme Cruncher
    Jun 2006
    If I see a shower of feathers I'll know the Panaflo just got another one
    That booger whacked me pretty good last night when I was trying to adjust something..drew blood lol.
    I could mount a UV light on and use it to control skeeters
  20. #20
    Apr 2005
    Wales, UK
    I love it - awesome work!
    Chilled PC UK - Watercooling Parts, Any Custom work undertaken including Laser Cutting (any parts, grills, side panels, brackets etc), Anodising, Powdercoating , Custom Spraying and Airbrushing, Fabrication, Watercooling Installs and more all done to the highest standard.
    International shipping no problem, even on Cases!
  21. #21
    Xtreme Cruncher
    Jun 2006
    10C ambient all night...gotta love that.
    I already have a much cleaner design in mind..lower profile...less materials...
    I still have three unused windows beside me
    I just realized this is the first installation of Windows that didn't try to update itself 6 times in one day
  22. #22
    Banned
    Apr 2006
    Portishead, Bristol, England
    I can get you a 0-10 PSI presure gauge but due to them being lowe presure reading there really costly which sucks!
    0-15PSI works fine i found, mines only a 40mm OD as well
  23. #23
    Jul 2007
    Florida
    Looking Great Cyber! Lov'in the thinking OUTSIDE the BoX!
  24. #24
    Jul 2007
    Wisconsin
    the people living next door must think your cooling meth
    still really cool (bad pun) I should do that, where ambients temps are 0F
  25. #25
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by Pete View Post
    Thanks for the offer! I imagine anything out of the mass produced norm would be high. Probably better places to spend that money like more aluminum and acrylic...
    Quote Originally Posted by XS_RoB View Post
    Ha Well thanks...
    Quote Originally Posted by KaptCrunch View Post
    CD
    only need to grease the cpu socket for extra caution
    No worry for condensation for -13c outside, ambiant 22c , my temps in canadian winter with rad only no fan with case fans keeps sweat to min, CD the shroud should be chalked an rad lowerd off the alu frame so the rejected heat can be exhausted proper...not recycled from plexiglas/alu frame. great handy work CD, i hope looking at picture of rad (front side)the left is the return and the right is input
    Yes indeed...I can bet a Canadian winter would almost be phase
    Yep the orientation of the pumps etc are all correct. I don't think there's much recycling going on...the air stream is pretty powerful...the Panaflo is running full tilt...but the next revision will enclooe everything a bit more and make it a better "package" to keep insects and other nuisances for infesting and otherwise dirupting the operation of the apparatus.
    For one I think I will stealth the tubbng so it isn't such an obvious "rig" and looks more like a litlte AC unit..stress on little..I don't want to hang twenty pounds of cooler off the window.
    Thanks for the advice
    Quote Originally Posted by The_Beast View Post
    Where I live it would not be an odd thing to be thinking...high power consumption...bright lights in varrious outbuildings at all hours of the night...
    We get a lot of helicopters patrolling these wooded undeveloped areas looking for the activites typical of rural Americe reefer plantaitions. stills, meth labs...
