Results 1 to 22 of 22
Thread: GSKILL F2-8000CL5D-4GBPQ (2x2GB) Test & Overclocking CL4!
    Bandwidth Freak
    Dec 2003
    Today I got the opportunity to test a new DDR2 product from GSKILL, the F2-8000CL5D-4GBPQ. This box contains two modules of 2GB each with an operating speed of 1000MHz 5-5-5-15 2.0~2.1v advertised speed.
    Test setup:
    - Intel Core Duo E6400 Air
    - Asus P5B-Deluxe b1215
    - 750Watt OCZ Gamestream
    Here are the test I did on this memory.
    Stock test:
    Overclocking: 516MHz (1033MHz) 5-5-5-15 2.0v:
    400MHz CL4-4-4-12:
    500MHz CL4-5-4-15 2.2v:
    Note:
    This memory has little overclocking headroom, but is flexible with the latencies between 800~1000MHz. For 2x2GB this is really fast enough.This memory can easily run 1000MHz CL4-5-4-15 without adding too much voltage. The memory reacts best between 1.9~2.15v.
    Kakaroto,
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    A nice write up, as always from you Kakaroto.
    Formerly XIP, now just P.
    INTEL inside
    Oct 2004
    Québec, Canada
    nice review !
    they need a fan over them ? or they run cool ?
    retired computer enthusiast
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by Supertim0r View Post
    nice review !
    my set runs cool... at 2.0V they definitely dont need a fan. Definitely an awesome value for under 200.
    CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Zippy 700W (fan modded of course)
    Feb 2007
    1000 cas4 @ 2.2v for 2GBx2 set, not bad at all
    Bandwidth Freak
    Dec 2003
    nice review !
    Thanks! No they definitely don't get hot at all!
    Jul 2006
    Quote Originally Posted by superray View Post
    provided that it's a CL4 boot, not a CL5->CL4 change using memset
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    Quote Originally Posted by mach82 View Post
    You can't change the CAS-latency in Windows using MemSet.
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Jul 2006
    oh yes you can - with older versions of memset. Of course this will be just a "virtual" change, not a physical one.
    May 2007
    Munich, Germany
    Yeah, that's right...
    Apr 2005
    Calgary, AB
    GJ kakaroto
    MB Reviewer for HWC
    Team OCX Bench Team
    I am Xtreme
    Feb 2003
    Netherlands
    Nice one mate.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Guru
    Aug 2005
    Burbank, CA
    any results using the Asus Maximus SE, i will have my board monday, and my ram on tuesday.....if anyone with this kit can test this combo i would appreciate it.
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by GAR View Post
    I don't have an Asus Maximus SE mainboard, but I am sure it will perform better on a X38 then on my 965 mainboard. For example take a look at Dennys, Eva2000 review, they used an P35 mainboard. I think the results will be quiet similar on a P35/X38.
    Aug 2007
    im testing this kit on a IP35 PRO and now i am @ 450 fsb x 1.2 multi = 1080 ddr without problems of stability.
    Super memories in my opinion.
    I will post images as soon as posible
    Xtreme X.I.P.
    Nov 2002
    Shipai
    so was it cas4 or cas5?
    Dec 2006
    Memroy: Gskill GBHZ 1gb x 2 and Transcend PC8500 1gb x 2 kit
    I installed both kit togethr on Asus Maximux Formula SE(bios 0401) as both kit are using D9 GMH chipset
    600mhz@4-4-4-12@2.66vdimm with pi16mil and 06
    http://i234.photobucket.com/albums/e...vPi32mil06.jpg
    600mhz@4-4-4-12@2.66vdimm with pi16mil and 03
    http://i234.photobucket.com/albums/e...mmpi32mil0.jpg
    600mhz@4-4-4-12@2.66vdimm with pi 16mil and 01SE
    http://i234.photobucket.com/albums/e...i32mil01se.jpg
    600mhz@4-4-4-12@2.66vdimm with pi16mil and 05
    http://i234.photobucket.com/albums/e...vpi32mil05.jpg
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    memory, why are you posting those results here?
  19. #19
    Jun 2006
    Quote Originally Posted by memory View Post
    lol..ok
  20. #20
    I am Xtreme
    Aug 2003
    What ICs do these use? I just ordered a set because I'm sick of my microns dying...
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  21. #21
    May 2005
    Edmonton, Alberta, Canada
    Powerchips.
    Gigabyte X58A-UD3R | i7 930 @ 4 GHz | Corsair H50
    G.Skill RipJaws 4x2 GB @ DDR3-1600 7-7-6-24-1N | HIS Radeon HD 5870
    3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
    Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  22. #22
    Jun 2006
    Croatia, Europe
    which 2x2GB kits use Micron ICs anyway? is there a list for this somewhere? thnx
    DFI ICFX3200 07/30 w/ MCW30
    E6600 L632A407 w/ EK Supreme
    Powercolor HD3870 w/ MCW60
    OCZ Reaper 2x2GB CAS4
    WD Caviar Black 1TB
    Silverstone Strider 750W
    MM U2-UFO Extended CYO
    CPU & NB loop = PA120.3, DDC 18W w/ Petra's top, 7/16''
    VGA loop = PA120.2, DDC 18W w/ Petra's top, 7/16''
    10 fans on 7V, PX-750A, all on SM 930BF
    " Having a DFI board is like having a hot girlfriend thats a total b1tch" ...
