OK, so I wanted to share some of the info from my new build. My new gear includes the G0 Q6600, a Gigabyte GA-P35-DS4 Rev.2.0, 4x1GB Crucial Ballistix RAM, and a Thermalright HR-03 Plus heatsink for my 8800GTX. Everything else is carried over from my old rig.
When I began, I noticed the Ninja was showing signs of convex base:
I lapped it with 240 -> 320 -> 400 -> 800 -> 1200 grit sandpaper to a relatively flat finish. It's not as smooth as it could be, but I'm not too concerned with apperances, just performance:
I stripped and cleaned my GTX to make way for it's new attire, a Thermalright HR-03 Plus I picked up in Akihabara yesterday:
I used Arctic Cooling MX-2 TIM for both the GTX and the Q6600:
I really like the layout of this mobo, everything fit together without any fuss:
Nice clean lines:
I built a duct/shroud for intake & exhaust air for the Ninja:
Intake is on the rear, and exhaust goes out the top. The CPU idles about 32C and gets up to about 72C with all 4 cores loaded:
The chipset cooling is quite effective as well, it idles about 38C and gets up to 44C at load:
I have a total of 8 fans in my P180b. 7 120mm 1350RPM Yate Loon fans; 2 in front for intake, 1 for CPU intake, 1 on the GTX 1 in front of the GTX, 1 in HDD/PSU tunnel, 1 in PSU. The 8th fan is the exhaust fan at the top, it's a 120mmx38mm 2000RPM Scyth Ulta Kaze and is thermally controlled according to CPU temps.
Any comments are welcome, thanks for looking.
Everything is set to it's stock values except the CPU and the RAM. I do have to point out one BIOS setting (version F7) that is missing...a 1:1 memory ratio. My plan from the start was to run my FSB @ 400MHz with DDR-800. The BIOS's lowest setting is 4:5, so 400MHz FSB will put my memory at 1000MHz DDR. Luckly for me, I picked out some good Crucial memory.
I was expecting to have to feed it some more voltage at these speeds, but it's doing just fine right here. I'll post an update when I get the other 2GB.
Unfortunately with any load my Ninja just isn't up to the task. So my highest stable setting right now is a 400x8 3.2GHz WITH ONLY 1.30V
