Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Asus P5K3 to Blitz to X38
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I will keep this short and hopefully help some of those of you who are looking at these boards and having a tough time making a decision.
    I started off the P5K3 Deluxe, this board is very strong overclocking and extremely stable for 24/7 under a vapochill. The voltages are just enough to keep the system safe for phase change but needs some modification for LN2 or cascade. The vcore maxes out at 1.7v with a vdroop option in bios. The memory voltage is more than enough for DDR3. I went through several bios updates without incident and used the windows util to update. The only problem I can dig up is the location of the bios reset being under the video card. I ran this board on stage at IDF as well as this was my personal gamer. Lots of good feedback on this board and the P5K line. This board is DDR3 only and I was able to reach 500FSB on several quad core processors. NB voltage maxed out at 1.7v and I only ran that high for benching, running 400FSB at stock voltage was no problem at all. This board runs 45nm parts with the current bios.
    The Blitz Extreme is based on the P35 w/DDR3 but I found it quite flaky and didnt trust it under the Vapo. The voltages are huge, far more than necessary in some places. There is LED's on the motherboard to indicate voltage and frequency, a nice feature to glance once you know what the different locations are indicating. The Frequency is based on the NB Strap speed not to the frequency range, meaning if you are at 266FSB strap and running 400FSB it will light up LED 2, where 333 strap at 400Mhz will light up LED 3 (going from memory). The LED post display that ships with the unit is very nice and doesnt display a code, rather words to indicate where the boot sequence is in progress. On my board the mobo reset and power switches didnt work and didnt always reboot, some intervention was needed most of the time when overclocked and I am not sure if this problem existed running at stock. Clearing Cmos, changing major options in bios or just rebooting from windows usually resulted in me having to reset or powering off from the PSU for a complete cycle of power. I ran this board for about a week, waited for bios update and tried it again. It can crank the memory and bus speeds but I felt with some stability loss once over 5Ghz with a quad core cpu. We have seen major cap mods done on this board by several of the top guys on this forum, I elected to move on to my next board. This board also comes with an add on sound card, I did not test it to see if it offloaded more from the CPU like other high end sound cards. This board also maxes out at 500FSB with quad core processors. I never connected water to the north bridge.
    This board also supports 45nm with current bios release. I had trouble pushing all four memory slots filled above 1600Mhz.
    The P5E3 Deluxe is my current board, it uses the X38 chipset and similar to the P5K3 board in voltages. It maxes out on at 1.7v with a droop option. This board is a worthy successor to the P5K3 board. I bumped up from 400FSB to 466FSB at stock voltage on the north bridge for 24/7 stability. The memory voltage available in bios is more than needed. EPU feature does work and lets the CPU run cooler, my display temps on the vapo have never been in the -50's before but they are now. The splash desktop is very cool and does let you go right to the web in a few second with a linux interface and correct driver set to start dhcp and go. USB doesnt work under splash so downloading drivers is not an option yet. I updated bios via the ALT-F2 option at boot and it picked the bios up off a USB drive. This worked correctly. Skype is also a boot option and a splash desktop option, I have not tested it yet. This board reboots fine with the Vapo and I trust it, it does power down with major changes are made in bios, like crossing NB straps, memory ratios, coming off "auto" to name a few. My only complaint is the location of the upper PCI slot being in line with the memory, I need both PCI slots accessible.
    AI Suite kinda works, its buggy on X38 but it works fine for PLL adjustments.
    Intel Extreme Tuning Utility does not work, I will know more after IDF.
    After working on the Intel X38 board, I know this board is capable of so much more.
    A small taste of what is possible, this is 24/7 stable on an unmodded board. just the Vcore and memory have been bumped to 1.7v/2.1v respectively with all memory slots filled.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2005
    Mumbai, India
    Thanks for sharing this wid us, Fugger.
    When is da date for final X38?? Anyone?
    Jun 2002
    Las Vegas
    NP, figured some of this info might help.
    Final X38? binned X48?
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    May 2006
    Cool!!! looks like we going to have another hype over X38 I just upgraded to p35 too ><
    Main:
    E6600 Stock + Asetek LCLC + NF-P12
    Asus P5K Premium
    EVGA 8800GTS 320mb @ 681/1000 + TR HR-03 Plus
    Patriot Extreme Performance 2X1GB PC2-6400 DDR2-800 CL4-4-4-12
    36GB WD Raptor x2
    500GB WD SE16 x2
    Antec 1200
    Seasonic S12 600W
    RIP BOX:
    Dothan 730 @ 2.6ghz 1.6v
    P4P800SE
    EVGA 6800gs @ 400/1200
    OCZ Platinum EL Rev.2
    250GB Barracuda
    Antec P180
    FPS 450W
    Nov 2004
    France
    Good explan Fugger!
    I actually have a P5K3 and i trade my P5E3 for a Maximus formula because i have a really big vdrop issue on it (on the maximus a pencil mode had solve it)
    Do you have the same issue on yours?
    You talk about daily use, great it's exactly what i searching for but what about performance clock to clock, did you test it?
    Thanks a lot for you description because it's exactly what i thought of those boards except for the blitz (only own the formula version)
    i7 3960X@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC19200C8, Corsair force GT 240go, 2XGTX Titan, MM Ascension, Seasonic X-serie Gold 1250W, Watercooling
    i7 3930K@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC17000C9, OCZ Vertex 3 120go, GTX670 DCU2 Top, MM Pinnacle, Corsair AX850, Watercooling
    Jun 2002
    Las Vegas
    I passed on the formula as I dont plan on going back to DDR2.
    I dont have droop issues on the P5E3.
    No on the clock for clock vs the other boards, I been all over the place with clock speeds.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Nov 2004
    France
    So you have a "special" bios because every body who own the card have this drop issue! You have a 1.02G right?
    Jun 2002
    Las Vegas
    0503 bios on the P53E-D
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Nov 2004
    France
    "we" have only the 0502 version, is it possible to share it?
    Mar 2006
    Hastings, England
    nice one Fugger. Got a P5K dlx at the moment, X38 next i think
    If you are really extreme, you never let informed facts or the scientific method hold you back from your journey to the wrong answer
    Jun 2002
    Las Vegas
    Bios 0503 for P5E3 Deluxe
    http://fugger.netfirms.com/P5E3D-0503.ROM
    Test at your own risk,.
    I then booted with ALT-F2 menu, it saw the USB drive and file. Update went perfect.
    This bios was to fix 4x memory slots filled and running high speeds.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Nov 2004
    France
    thanks!
    Nov 2003
    europe - germany - cologne
    Quote Originally Posted by pinto View Post
    i have bios 0503 + 1.02g and the droop.
    between idle and load the vcore droop is 0,015 Volt.
    my old p5k deluxe only have 0,008 Volt droop.
    Sorry for my bad english...
    System1
    System2
    Nov 2004
    France
    Are you sure you have a 1.02g board webwilli?
    I comme back from the shop to buy a new P5E3 and it's a 1.03g. Let me instal it this evening with the 0503 to see if the vdrop issue is still present...
    Nov 2003
    System1
    System2
    Dec 2006
    Vegas ,NV
    thanks for sharing fugger
    I am Xtreme
    Nov 2002
    South FL, USA
    Quote Originally Posted by webwilli View Post
    that drop is better than what i have on my Abit IP35 Pro board!...i have to deal with 0.04 to 0.05v vdrop...i would say that you still have it pretty good!
    BIOSTAR TPOWER I45 UNOFFICIAL THREAD
    BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
    BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
    ABIT IP35 PRO HEATPIPE MOD
    ABIT IP35 PRO BIOS FLASHING PROCEDURE
    IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
  18. #18
    I am Xtreme
    Nov 2002
    South FL, USA
    Quote Originally Posted by FUGGER View Post
    is your server off because i cannot grab the file?
  19. #19
    Jun 2006
    smyrna, TN
    Quote Originally Posted by Ace-a-Rue View Post
    works for me
  20. #20
    Banned
    Apr 2006
    NYC
    Saw an interesting comment yesterday: http://www.xtremesystems.org/forums/...49#post2481749
  21. #21
    Nov 2005
    Peak District - UK
    Nice comparison Fugger.
    I got some decent results with the Blitz Formula tbh, maybe the extreme aint so good:
    I was thinking of jumping on the X38 wagon but from what I've seen so far I dunno if its worth it.
  22. #22
    May 2006
    UK
    hiya fugger whats the spacing like between the 2 main graphics slots is it about the same as on the p5w-dh , i see on the maximus there is more space between them, going the ddr3 route myself not sure whether to plump for this board or wait for the maximus extreme, thanks for any input, from past exploits it seems the deluxe boards always fare well up to the rog boards as with p5b deluxe etc
    thanks
  23. #23
    Apr 2006
    Italy
    hi
    this is my max fsb on Blitz extreme but it's very difficult
    With my old P5K Del I do 495/500 Mhz with low Nb/fsb voltage, I hope the P5E3 is the same....I want buy it
  24. #24
    Jun 2002
    Las Vegas
    I dont have a board in front of me to measure but the spacing, might be able to find an image on asus.com
    does the blitz formula share the same caps as the extreme?
    485FSB is pretty standard on quad core processors. Its not the board, its the chip.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  25. #25
    Apr 2006
    Italy
    yes ,but with the blitz extreme is more difficult
