HI All,
Recently installed a G0 Q6600. Am wondering if anyone can recommend me some decent settings for OC'ing my system. What bios settings and bios revision would you recommend?
Cheers![]()
HI All,
Cheers![]()
use the search button, theres a really good thread about the striker with a q6600
Intel q6600 g0 3.4ghz
P5N32-E Sli
XFX 8800ultra
2x WD caviar SE
I just got my Striker Extreme last weekend and am still benching with my Q6600. Have a look at this thread http://www.xtremesystems.org/forums/...d.php?t=159457
You want the 1303 bios, do not, I repeat, do NOT use the 1305 bios. I'm priming stable at the moment at 3.6. I did boot into windows at 4.0g but soon as I tired P95 it crashed.
HUGE thanks to GameGuru,
Applied the bios settings he recommended and used bios 1301.
System is fine at 3.6GHz now.
Good stuff lads![]()
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
Hi !
i am new and any help is welcome.
this is my rig :
Q6600 G0 air cooler| Asus Striker Extreme (1301 bios) | Crucial Ballistix Tracer 8500 4x1GB (DDR-1066) |1 x Asus 8800GTX | Raid 0 with 4 x 250 seagate hdd | PSU: NEO HE 550W
my rig is similar to GameGuru (cpu,ram ,mobo),so if u can shre your settins will be great.pls help with this :
FSB - Memory Clock Mode:
x FSB - Memory Ratio:
FSB (QDR), Mhz: (means FSB)
Actual FSB (QDR), Mhz:
MEM (DDR), Mhz: (means mhz speeds)
Vcore Voltage:
Memory Voltage:
1.2v HT Voltage:
NB Core Voltage:
SB Core Voltage:
CPU VTT Voltage:
DDRII Controller Ref Voltage:
DDRII Channel A Ref Voltage:
DDRII Channel B Ref Voltage:
tCL (CAS Latency):
tRCD:
tRP:
tRAS:
Command Per Clock (CMD):
Advance Memory Settings
tRRD:
tRC:
tWR:
tWTR:
tREF:
tRD:
tRFC:
Async Latency:
CPU Spread Spectrum:
PCIE Spread Spectrum:
MCP PCIE Spread Spectrum:
SATA Spread Spectrum:
LDT Spread Spectrum:
CPU Internal Thermal Control:
Limit CPUID MaxVal:
Enhanced C1 (C1E):
Execute Disable Bit:
Virtualization Technology:
Enhanced Intel Speedstep Tech:
LDT Frequency:
PCIEX16_1 Frequency (Mhz):
PCIEX16_2 Frequency (Mhz):
PCIEX16_3 Frequency (Mhz):
SPP<->MCP Ref Clock, Mhz:
and one question : neo he 550w is ok or i need more power for my cpu @ 3,4Ghz ?
sorry my english.
These are Linflas settings mate, worked good for me till up to 425FSB, keep ram in sync with FSB do not try to force more ram mhz as it will make the OC unstable... I hope it works out for you as some boards just don't cut it... plz make sure the heatpipes get enough cooling as running them without added cooling will surely hinder ya OC
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
Set CPU multi to 8x if you want 3400mhz
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1700
Actual FSB (QDR), Mhz: 1700
MEM (DDR), Mhz: 850
Actual MEM (DDR), Mhz: 850
Vcore Voltage:1.625 for actual of 1.52
Memory Voltage:2.05
1.2v HT Voltage:1.75
NB Core Voltage:1.5
SB Core Voltage:1.65
CPU VTT Voltage:1.5
DDRII Controller Ref Voltage: auto
DDRII Channel A Ref Voltage: auto
DDRII Channel B Ref Voltage: auto
tCL (CAS Latency): 4 -- try 5 if no boot or unstable
tRCD: 4 -- 5
tRP: 4 -- 5
tRAS:12 -- 15
Command Per Clock (CMD): 2
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 101
PCIEX16_2 Frequency (Mhz): 101
PCIEX16_3 Frequency (Mhz): 101
SPP<->MCP Ref Clock, Mhz: 201
On the Antec PSU I cannot comment as I never use them in a high specced system, I'm a trusty follower of Enermax and OCZ...
hi ! and tks for atention.
i tried your settings and dont boot.At x8 boot only in 1500 FSB ,and i changed at x9 and after many ,many restrats (very hard this striker ) i find this settings:
@3,15, 30 grade CPU idlle
AI Tuning: Manual
LinkBoost: Disabled
FSB (QDR), Mhz: 1400
Actual FSB (QDR), Mhz: 1400
MEM (DDR), Mhz: 900
Actual MEM (DDR), Mhz: 900
Vcore Voltage:1.350
Memory Voltage:2.05
1.2v HT Voltage:1.55
NB Core Voltage:1.55
SB Core Voltage:1.55
CPU VTT Voltage:1.5
tRCD: 4
tRP: 4
tRAS:12
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
LDT Frequency: 5x
is ok FSB/mem ?
Quad QX9650 rev C0 with air cooling| GA-EP45-UD3P (rev. 1.6) bios FE | 2X2 8500C5DF-1066Mhz|Club3D 5850 | Raid 0 with 2 x hdd | PSU 750W
you on 1301 or 1303 Bios mate ? Well each board behaves differently did it boot with only 2 dimms in it ? what was the error on the lcd ?
bios is 1301,i boot only with 4 dimms and i dont have a error becouse dont boot (black screen)![]()
and now i changed "MEM (DDR), Mhz: 900" in 850 becouse i recevie bluescreen after 30 min with prime95.
there should be an error on the LCD poster at ya backplate: cpu init, det ram, det ide,...
and also a black screen no boot means you are in an FSB hole, meanign you have to up the FSB eg 12mhz and try again...
try eg 1660 FSB ( 415FSB) with 830mhz on the ram always try to keep these in line with a quad, if you are gonna force them you migth get instabilities... if it doesn't boot try 1672 and 833 on the ram till it boots...
ok,tks mate,i will try .
