Results 1 to 10 of 10
Thread: Q6600 + 8800Ultra + DFI LanParty UT P35-T2R @ 19290 3dmark06
Hybrid View
    Feb 2005
    Team MXS - GA,Atlanta
    Talking Q6600 + 8800Ultra + DFI LanParty UT P35-T2R @ 19290 3dmark06
    Q6600 @ 4500MHz , 500x9.0 , 1.69V
    Mouse Pot Rev.3 @ LN2
    2x1024Mb Corsair C3DF , 500MHz @ 4-4-4-9 , 2.49V
    Win XP SP2 , FW 163.71 WHQL , RT 2.05
    8800Ultra @ 900/2160/1215MHz , ~ 1.55V GPU
    Powered by Mouse Pot Rev.4 @ LN2
    3DMark06 : 19290
    http://service.futuremark.com/compare?3dm06=3259188
    Master of nebulah frost
    Dec 2004
    Dolomites(Italy)
    Wow!!!
    This is a good score!!
    Congratz!!!
    Battlefield 3: Nachthymnen666
    Oct 2006
    istanbul
    good score
    Liquid Nitrogen -196c
    THE POWER
    Jun 2006
    Nice job Gorod. What happened to your QX6850? I take it you're fsb limited on the proc.
    Feb 2005
    nachthymnen , EXPANDER Thank you guys
    nachthymnen when you phase unit going to be ready m8 ?
    Quote Originally Posted by Stapler View Post
    Thank you my friend
    QX6850 has 2 broken cores unfortunately , can use it only in dual core mode So i had to use Q6600 for 3d06
    And you are right , its fsb limited ~ 500MHz for 3D (511MHz max. for super pi 1m) , i used 1.69 vcore just to make it more LN2 friendly , much easyer to bench this way
    About the Ultra , it's a bad card realy , hates cold a lot , cold bugs with DI so ln2 is the only choise , but need to keep it in -25-35 C range loaded so it wont cold bug while switching betwin tests , very tricky to bench with that card
    Dec 2004
    Dolomites(Italy)
    I think in 2 or 3 weeks the new SS 1HP will be ready
    Champion
    May 2006
    Bangkok, Thailand
    Great ! Nice score Gorod
    Congrats
    Sorry For My English
    OverclockZone Team
    THAILAND
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    that score is friggin phenomenal! Congrats!
    You have even more to find with a good card @ higher clocks and better settings on the RAM, which is scary!
    20K single card?! only 2 guys above ya! Ranked 3rd on HWB for single card....niiiccceeee!
    you sigged that?
    why?
    ______
    Feb 2005
    K404 thx I hope it can get 20K too , but wont be easy as it seems the card wont do anything higher then 900MHz for 3d06 , tryed 936 and 918MHz and no go - freezes in first test Like i mentioned - i cant get it too cold while idle or it will throttle to low power 2D , thats why i can bring it down to only -50-60C while in windows and when Proxycon starts it jumps quickly to -25C loaded and freezes before i get a chance to pour some more LN2 . My 8800GTX was way more cold friendly than this Ultra , i guess bad luck ... oh well Maybe should try 2900XT next time
    ZoLKoRn Thx m8 !
    Next monday or tuesday will try that Ultra with 3d01/03 and 05
    nachthymnen hope you get it soon bro
    Oct 2005
    Virginia
    Wow 900Mhz on the Ultra! Can you take pics of your setup i love seeing LN2 up and running. Great score!
    Previous cards: Radeon 32MB PCI - Geforce 2 GTS 32MB - Radeon 8500PRO 64MB - Radeon 9600XT 128MB
    X800PRO 256MB - X800XT:PE 256MB - X1800XL 256MB - X1900XT 512MB - HD2900XT 512MB
