Results 1 to 23 of 23
Thread: A Detailed Comparison Between 680i SLI and 780i SLI
    Jun 2007
    Different from the 680i SLI, this engineering example did not use south bridge to north bridge heat pipe system. 780i SLI only have heat sinks+fans. The north bridge big heat sink are cover both SPP and BR04 chips.
    780i SLI use black PCI Express 16x slot. Different from 680i SLI's two black + one blue. We believe in the retail version 780i SLI will still using two black + one blue PCIe X16 slot and heat pipe design.
    Click to enlarge
    There is no difference between between nForce 780i SLI's power module and nForce 680i SLI's. Both of them are 6 phased. Every phase have one R50 and four Mosfet. Because of this, we once thought the 780i SLI mobo is only an another version of 680i SLI.
      though they really simaliar to each other, we also can find some difference if we look carefully.
    Click to enlarge
     1、Because of the BR04 needs room,so nForce 780i SLI is canceled one PCI Express 1x slot.
     2、 nForce 780i SLI using NF570-SLI MCP chip,but nForce 680i SLI is using NF590-SLI MCP chip,the only difference is their name. They have no huge difference in their functions. We will have a detail description in our later review.
     3、nForce 780i SLI using two one-digit-DEBUG LED,but nForce 680i SLI have one two-digit LED.
    DEBUG LED of the nForce 780i SLI
     4、The position of the front panel connector and clear bios jumper are different.
     5、nForce 780i SLI canceled one 4Pin D type 12v power connector beside the memory slot of the 680i SLI.
    Our review is coming, someone testing the mobo said that the 780i SLI's funtion are quite different from 680i SLI. Pls keep tuned.
    Original post[in chinese]: http://news.expreview.com/2007-10-02...1381d3826.html
    Jul 2007
    Kentucky, USA
    Wow, thank you very much.
    Banned
    Mar 2007
    In the land of Red....
    Still looks like a heap of foxconn crap.
    May 2007
    Well, lets see how the features go compared to the 680i
    The big thing is the 780i better be a whole lot more stable than the 680i was or else its a no go for me
    Aug 2006
    Southern California. USA.
    Unless I am missing something, this doesn't look like much of an upgrade at all! Why even give it a new name?!
    Banned
    Mar 2007
    Quote Originally Posted by kuhla View Post
    My thoughts exactly. I'm tired of these craptastic Nvidia chipsets.
    Wooooooo you added a 2nd chip by the NB, and gave it PCI 2.0.... please. The 680i is the most unreliable POS i've ever seen in my life. I've gone through 4 boards so far. And before you naysayers come out and say "you're just breaking your boards" shove it. The 780i won't be any different. Stick w/ p35/X38 unless you have to have SLI. For those of you who do need SLI, good luck.
    Jun 2006
    Florida
    The deletion of the 4 pin AUX power for the board is worrying. Or have they found a more efficient way of getting power to the chipset?
    As for you Baleful, seems you've had bad luck with them. I'm still on my original A1 board from early this year year. The only time it's been RMA'd was for the AR to A1 swap for the quad core fix, but the other board was technically fine.
    Core i7 3770K
    EVGA GTX780 + Surround
    EVGA GTX670
    EVGA Z77 FTW
    8GB (2x4GB) G.Skill 1600Mhz DDR3
    Ultra X3 1000w PSU PSU
    Windows 7 Pro 64bit
    Thermaltake Xaser VI
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    looks like nvidia is going to loose massive market share to the skull trail
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Just wait for benchmarks, who knows if they've done anything different to the silicon on the northbridge. Good thing I don't use SLI otherwise I'd be pissed
    Dec 2004
    Australia, Gold Coast
    Yeah doens tlook much , even looks as tho they kept the old design to save some dollars, we shall wait and see if it perfoms.
    Current Machine is my trusty Dell 8200 Lappy , while i make a decision
    Xtreme Mentor
    Apr 2007
    Idaho
    That's my thought on it.
    "To exist in this vast universe for a speck of time is the great gift of life. Our tiny sliver of time is our gift of life. It is our only life. The universe will go on, indifferent to our brief existence, but while we are here we touch not just part of that vastness, but also the lives around us. Life is the gift each of us has been given. Each life is our own and no one else's. It is precious beyond all counting. It is the greatest value we have. Cherish it for what it truly is."
    Oct 2006
    thousands of potentially awesome rigs owned by an average chipset?
    I am Xtreme
    Aug 2003
    Quote Originally Posted by [cTxP]Baleful View Post
    You do realize it's AN NVIDIA REFERENCE DESIGN, right? What does foxconn have to do with it? And I don't know wtf YOU'RE doing with your 680i boards, but my EVGA 680i ("heap of foxconn crap") board is lightyears more reliable than my p5b deluxe wifi and badaxe 2 ever dreamed of being. To bad 680i is so slow
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Banned
    Mar 2007
    Quote Originally Posted by afireinside View Post
    What i'm doing is using them. With a very mild OC to the processor, the boards usually last a month, then wig the hell out. Take settings back down to stock, still the same crap. RMA the deffective board, get the new one in, system runs fine for another month or so, then wigs the hell out again (constant restarts, freezes). Tell me, what the hell AM I doing wrong? No driver conflicts...... no excessive OCing...... What??? There are many others having the EXACT same problems with their boards as I am, but yah it's just me screwing the boards up right?
    Jun 2007
    Victoria, Australia
    Every one keeps saying that 780i has lost the extra PCI-E 1x but wasnt that just for the ty supreme FX, it is placed further back than the other PCI-E 1x on my 680i Thats also means hopefully theyre not sound card (onboard sound) anymore... Good idea lol. The heat pipe solution was useless to, hopefully they dont use that anymore.
    Oct 2006
    Austin, Texas
    meh im not going to upgrade boards until i need too, which is not now btw
    Media PC:[AMD x2 4800][MSI K9N-SLI][2x1gig Corsair DDR2 800][ATI 3650 AIW][Asus Xonar D2X][500gig Samsung SATA][Crap Antec Case and PSU]
    Aug 2006
    Perth, Australia
    Hopefully they're still on target for a November 12th release, as my DFI 680i just broke
  18. #18
    Banned
    Jun 2006
    Durham, NC
    Since when is a 680i board more reliable than a BadAxe2?
  19. #19
    Xtreme PSU Tester
    Jul 2006
    No mention of the implementation of ESA on the 780i?
  20. #20
    Xtreme Guru
    Dec 2006
    Philly/NJ
    can i join in on the fun with pictures guys?
    and i have to agree with baleful 680i was crap, and now it looks like no tremendous effort was put into 780i either, their just gona slap a high price tag on it and need 13 different revisions of the board to fix all the problems with it.
  21. #21
    Aug 2007
    Arlington VA
    I feel the same way. I ditched my intel 975x board for an asus striker because I wanted SLI.
    Well I do have SLI now, a stable computer far from it.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
  22. #22
    Xtreme Mentor
    Jun 2007
    Chicago
    The led should be increased in size to 3 letters/numbers.
    Also the following should be included..
    RMA
    LOL
    And of course instead of the double digits of death, it should be replaced with
    I absolutely hate these nvidia chipsets.. I have gone through so many boards and they are just pure garbage.
    The gfx cards are great but their motherboards are crap. I'm suprised these boards don't start with a wick and a match
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
  23. #23
    naokaji
    Guest
    Instead of the usual advertisment on the Retail Boxes they should just print on how the Rma process works and where you have to call (or directly put shipment address on it)
