Results 1 to 7 of 7
Thread: DFI UTP35-T2R and Galaxy 1KW no GO
    Feb 2004
    PT - Fig Foz
    I've used the search but didn't find anything about this here, i've only find some info in a Italian forum.
    I've tried all the hardware with diferent components and all work fine, but the combination of DFI and Enermax i couldn't get to post, all the components start even vga fan spins, but the psu stays in protection mode, and the motherboard didn't post.
    Anyone with the same problem here?
    Could any bios solve this problem?
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Are you plugging in the floppy power connectors? Don't.
    A few other motherboards have this issue. If you must use floppy power(dunno why,unless DFI board is peculiar), then use 8-pin cpu converter that goes to molex, and then use molex to floppy adapter...or make your own adapter...
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    You are not the First Person I have seen posting issues of incompatibility with the Gallaxy and the DFI P35
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Feb 2004
    PT - Fig Foz
    Quote Originally Posted by cadaveca View Post
    No, in my NF4 i used to that for stability, but in this one i didn't plug.
    The motherboard boots with a crapy psu, but no go with Galaxy 1000 DXX, but the psu it's ok, i plugged it to a asus and works fine.
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Well, in that case, it's a no go..i have run into this with a few boards and this psu, over time.
    Aug 2004
    Scotland
    I seem to recall seeing various 680i boards having this problem with the Galaxy too.
    abit IP35 Pro, E6600, HD3870, FSP FX700-GLN
    abit AB9 QuadGT, E6400, 7900GTO, FSP FX600-GLN
    abit AX78 x2
    Asus P5N-E SLI, E6600, 8800GTS, Tagan 530W
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Hey guys, I have found the source of this issue for some Galaxy users...
    MJRL, if you have the time, take a look at your Enermax psu. Note which yellow wires go where, and what colours they have been coded with.
    Yellow=12v1
    Yellow/Black=12v2
    Yellow/Blue=12v3
    Yellow/Green=12v4
    modular connectors=12v5
    So...take a look at tyour 24-pin motherboard connector. there are two pins side by side with yellow wires in them...which of the above is in your 24-pin connector?
    12v3???
    there are quite a few of these psu's wired improperly. the 24-pin connector should have 12v1 connected to it, but mine does not, and has issues with some boards. Motherboard/cpu need to have the same power source, in some boards, and do not in others, however, I am sure that the way this PSU is wired may account for the 4 dead boards I have sitting here at my feet....and the boards that do not owrk right with this psu work just fone with psu's that power the board and cpu from the same line.
    Poor quality control here, for sure! If anyone asks you what PSU to buy, never say Enermax!!!!
