Results 1 to 7 of 7
Thread: Has that asus + D9 no boot issue been solved?
    xtreme energy
    Oct 2004
    Europe, Latvia
    This is ridiculous
    When my Cellshock pc8000 4-4-4 sticks were new they booted just fine on asus p5b dlx and p5k-e. Now after some time they simply wont boot after oc reset or clear cmos. I have to set like 2.3V with value ram and change back
    Cellshock support said RMA sticks and I did so. But guess what happened after awhile. Same problem. They wont boot at stock, have to set 2.3V manually.
    This is really annoying cause I cant shut down PC and every time oc fails I have to change sticks
    Ofcourse I tried latest bios. Sticks were fed 2.2V daily and 2.4V for some light benching
    Dec 2005
    Any updates about this problem?
    I think the same thing is happening to me.
    It's like the board is dead. It doesn't respond when power button is pressed. Need to clear cmos and hope it starts. If "save defaults" is chosen in bios, it freezes.
    Asus p5k-e/wifi
    Mar 2004
    Toronto, Ontario Canada
    What psu are you using?
    Dec 2005
    Antec true control II 550W.
    It didn't do that from the begining.
    edit: could it be corrupted spd? like the UTT once upon a time?
    xtreme energy
    Oct 2004
    Europe, Latvia
    SPD seems fine
    P5K-E new beta bios is out, will try it today
    I remember this problem has been posted in Gskill section (with p5b deluxe) a long time ago but without a solution. Interesting but original p5b deluxe bios worked just fine wheras any other newer bios did not
    Feb 2006
    Australia
    how long did it take before the new sticks didnt boot @ default voltage? it seems from what you have said, the sticks are slowly suffering from electromigration and are no longer able to run @ default speed @ default volts (hence your need to increase voltage to 2.3v for stability. Try running a lower vdimm 24/7, dont push them over 2.4v for benching, and use a fan over them. If you wanna always be safe, keep a set for 24/7 use & never go over ~2.2v with them and always use a fan. have another set for benching so you can push them as hard as you like.
    Xtreme Cruncher
    Feb 2007
    I just flashed my P5B DLX bios and it doesn't boot anymore. I have the Cellshock c4, 1000mhz. They used to work at default voltage when new but apparently not anymore. I have been running them at 2.15v
    Tomorrow I'll try some stick that works at 1.8v
    EDIT
    It works when I booted with the cheap stick of ram
