Results 1 to 15 of 15
Thread: My Stacker Mod/H20 Project: DONE *56k = Eeekaboom!*
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Talking My Stacker Mod/H20 Project: DONE *56k = Eeekaboom!*
    Well, It had taken me a LONG time to finish this... But I'm finally done. (I Think)
    I modded my Stacker back in early June:
    http://www.xtremesystems.org/forums/...d.php?t=146735
    Then Lapped my XP-90:
    http://www.xtremesystems.org/forums/...d.php?t=147660
    Then spent all my money on a box of liquid cooling goodies:
    http://www.xtremesystems.org/forums/...p?p=2278796#21
    I made some mistakes as I modded, And had to redo/replace a few pieces along the way. But Today, After 20 Hours of straight work through the night, I have finished it!
    the bad part: No pics of the case until my camera is charged all the way, The battery is already pretty shot. Until then, I have some results and a question:
    Question: Coretemp says 28/41... Wtf? I've only used CT with C2D's prior to this, Does the chip monitor temps differently? I'm going to try to reseat the CPU block.
    Just wait for the pics... She's a Beaute.
    EDIT: LOL I have no idea why CPUZ says 3.3Ghz... I Wish!
    Data:
    Liquid Cooling:
    D-Tek Fuzion (With a 1/16" O ring and a home made nozzle similar to Martin's... Also Lapped and re-bowed)
    Swiftech MCW60 (Gonna replace the loose ramsinks later)
    DDC 3.1 w/ Petras Top
    Swiftech MCRES
    Swiftech MCR320
    Three Yate Loon SL's @ 5 volts
    Tygon 7/16" Tubing
    %100 D-Tek Hi-Flow barbs
    Breeze aircraft stainless hose clamps
    1:20 Ratio of water to G11
    Overkill amount of PTnuke
    Overkill amount of UV Blue Dye (I think i'm gonna add more to see if it'll do anything)
    Case:
    Interior painted with Rustoleum "Hammered" Bronze "Jet Black" Paint
    plexiglass added to Side Window and bottom grill (For noise and dust reduction)
    4 holes cut in Motherboard tray to cable organization
    3 Hard Drives vibration mounted Vertically
    2x Yate Loon SL's @ 5 volts
    Hardware:
    DFI LanParty SLI-D
    A64 X2 4200+ Mannchester 2.2Ghz @ 2.65Ghz
    2x Patriot DDR500 1Gb
    EVGA 7900GS @ 620 / 830 (Vmods soon)
    OCZ GameXStream 600w With 120mm Scythe S-Flex added
    2x WD740 10k RPM 74gb Raptors in Raid-0 formation
    1x WD 200Gb IDE
    Pioneer DVD-RW / DL (SATA)
    5x UV 12" CC's
    Use the power of your CPU and GPU to contribute to science! Become a member of one of the most competitive teams in the world of distributed computing, help find cures for diseases and various other charitable scientific causes. It's as simple as running a program! Go visit the World Community Grid and Folding at Home Forums for more information on these projects. CRUNCH 'N FOLD!
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Pictures at Day
    Pictures at night later
    Feb 2007
    Arizona, USA
    Dang! Nice work!
    That was a pretty tight fit for the chipset cooler, eh?
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    very nice awesome work.
    I like the colour's used similiar to my rig
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Quote Originally Posted by ColonelCain View Post
    Dang! Nice work!
    Yeah, No joke. It's got maybe 4mm of clearance!
    Sep 2006
    Surat, India.
    wow.. pretty impressive work there man .. I liked it a lot ..
    how did you mount the HDDs ??
    Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
    Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
    Xtreme Cruncher
    May 2007
    Fairmont West Virginia
    why didn't you have the rad closer to the back of your case?
    CPU Q6600 @ 3.15Ghz D-tek CPU Block
    GIGABYTE GA-EP45-UD3R 350Mhz FSB
    RAM G.SKILL F2-8500CL5D-2GBHK DDR2 1066
    GPU Nvidia 8800GT MCW-60 700Mhz Core 1.0 GHz Mem
    PSU Cooler Master realPower 550W
    Storage 3 500 GB WD Caviar SE16 in RAID 0 + 300gb WD
    Misc. CM stacker STC-T01 w/ Cross-flow fan, 2 MCR-320 Rads, DCC 355 W/ Petras Top, 12 YateLoon D12SL-12, ~12ft Tygon 9/16 ID tubing
    Crunching for [XS]
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Quote Originally Posted by ANP !!! View Post
    I used 3 of these:
    http://www.petrastechshop.com/scahddst2for.html
    And jerry-rigged them into some un-coneventional locations:
    I did that several reasons:
    A- So it would fit amongst the Radiator input/output, the res, And the Fill-Line.
    B- The raptors get airflow from the radiator
    C- There are no vibrations!
    Quote Originally Posted by Grafton View Post
    So it would not hit the Motherboard tray:
    It was a pain since I had to put the DVD drive on the bottom, But on my desk, It's actually nice!
    The drive tray opens over my keyboard and monitor stands, And I don't have to get up for a second to put a disk in on the top
    Anyone know what's up with coretemp? (First post, bottom)
    Sep 2006
    Chicago, IL
    Quote Originally Posted by kevinbo03 View Post
    Man I have no idea but I have the same prob with core temp. Room temp is 24C but core temp on idle is giving me 39C for Core 0 and 16C for Core 1. I don't know about you but I have tried several versions of core temp an all had the same results. I'm not sure if there is a solution, but for now my solution is to use Smartguardian for temp monitoring, it doesn't show the core temps but it seams fairly accurate. At least the cpu diode temp isn't below ambient.
    Motherboard: Asus Maximus II Formula
    CPU: Q6600
    Memory: 2x2Gb G.Skill 1066
    Graphics: Sapphire HD 5850
    Power Supply: Corsair 620HX
    Audio: Auzentech X-Fi Prelude
    W/ Sennheiser HD 555 & Klipsch ProMedia 2.1
    Display: Asus VW266H
    Cooling: Apogee XT, EK FC-5850, MCP-655, TFC 360, EK Res
    Sep 2006
    Chicago, IL
    KaptCrunch I think you need some coffee or something to wake you up. The loop is in the proper order and nothing is reversed, the flow order is (from what I can tell) Res>Pump>Rad>CPU>GPU>Res.
    CPU: Q6600
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Easy there... But yes the flow is correct and that's the order (Res>Pump>Rad>CPU>GPU>Res). No air bubbles i dont think, I turned this thing around 360 degrees multiple times to clear them out. It's *Possible* there is one in the CPU block, But I highly doubt it, And I will give it a tilt tomorrow to be sure.
    I re-seated it 3 times already... Not gonna waste any more MX-2, Its obviously something specific to this motherboard's readings.
    I'll edit this into my post:
    Liquid Cooling:
    Swiftech MCRES
    Swiftech MCR320
    Tygon 7/16" Tubing
    Case:
    Hardware:
    DFI LanParty SLI-D
    1x WD 200Gb IDE
    5x UV 12" CC's
    Banned
    Jun 2006
    in a Red Rage D....
    very nice and roomy in there.
    could use some more raptors i'd say...
    btw why vertical mount raptors? you could have done all HDs horizontal.
    or just personal preference...
    I am Xtreme
    Oct 2005
    Sweet Stacker, quite a bit of work and looks great.
    If you have not already, would you mind adding just a few pics and hardware description to the Stacker Slacker thread in the CASE section. If you don't know this already I have a thread dedicated to Stacker owners and would appreciate you adding just a few pics.
    Thank you.
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Yep, I was gonna do that as soon as I get my camera back and take some Night pics.
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    And lastly, some night pics...
    Hopefully I'll be able to replace the chipset fan, find a way to mount some front fans, isolate the pump a bit more, And work more on cable organization.
    Then, It's 8800GTS / Equivalent. After that... I'm going to wait a bit before getting a whole new system, And migrate the raptors/DVD/H20 over to the new rig.
    But I digress, I'm looking at 6-8 months before all this, If that.
    Cheers
