Results 1 to 20 of 20
Thread: 8800GTX and VF900
    Dec 2006
    8800GTX and VF900
    Hello Guys, just wanted to tell all the frustrated people out there, that its possible to put the VF900 from Zalman on a 8800GTX, the thing goes like this, i had some several problems with the stock cooler of this card, for some strange reason it started to give me some artifacts and stuff, so i decided as a last resort, to change the cooling, lucky me it fixed all my problems and now i can enjoy my video card.
    The process is very simple, i just had to remove the stock HSF, clean the card, mount the HS on the ram and other chips on the card, like the strange core on the front and the power thing's.
    Here I present some pictures, but before that let me tell ya, the temps are lowered.
    Stock HSF Idle: 60º C
    Stock HSF Load: 80-87º C
    Zalman HSF Idle: 50º
    Zalman HSF Load: 70º
    Pictures:
    Regards, and hope to see comments.
    Feb 2004
    Finland
    Strange that it gives that good temps. VF900 could barely handle my X1900XT...
    [i5 2500K, ASrock extreme3 gen3, Corsair Vengeance LP 8GB 1600MHz, Palit GTX570 Sonic Platinum, CM HAF932, Antec Truepower New 650w]
    May 2006
    UK
    I was going to say you'd have one toasted GTX but obviously i'm wrong...
    Anyone else tried this? I have to agree along the lines with Nazu, VF900 was pants with my X1900XTX, HR-03 could only tame this beast in both sound and temps.
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    May 2007
    The Zalman reduced my 7900GT temps by 20c.
    I was thinking of selling it along with the card as i've got a 8800GTS with stock cooler and didnt know if it would do any better as it looked such a beast. May consider swopping over now, looks aint everything I suppose.
    INTEL RIG: Q6600(G0)/Thermalright Ultra120 Extreme, GA-P35C-DS3R(r1.1), 2x2Gb OCZ PC6400, 2x36Gb Raptor (RAID0), 2xWD 250Gb SATAII, 8800GTS(320Mb O/C), 620w Corsair HX PSU
    May 2005
    Sweden
    I’m not surprised. 8800GTS (stock MHz) are not hotter than X19xxXT/XTX. So a VF-900 wouldn’t really have a problem to handle an 8800GTS. But if to overclock or put it on 8800GTX/ULTRA then it you would have some temp problems a think.
    EDIT:
    Oh ssh..I thought that it was a GTS not a GTX. Well then it makes everything more interesting.
    "The flames of freedom. How lovely. How just. Ahh, my precious anarchy.."
    Aug 2006
    San Nicolas, Buenos Aires, Argentina.
    what about that lonely chip on 8 series cards...the wathever is called core on the front of the card...how much heat that thing produces?
    Gigabyte EX58-UD5 // Intel Core i7 920
    SuperTalent PC3-12800 3x2gb
    ATI 4870X2 2gb
    Samsung 1TBx6
    Coolermaster Silent Pro Gold 1000w
    Coolermaster Cosmos
    Dell u3014
    Aug 2007
    Madison, TN
    Is it possible that you had bad contact with the stock cooler or that it was malfunctioning? You did say you had artifacts with it.
    Apr 2006
    San Gabriel, CA
    looks you didn't get all the mosfets, you might want to put a longer heatsink on them like the swiftech ones. other than that looks good
    you didn't have to mod the VF900, did you? straight bolt-on?
    i5 2500k @ 4.6GHz - Corsair A70 | Biostar TP67B+ | G.Skill RipJaws DDR3-1600 2x2GB | MSI HD7950 TF3 | X-Fi Titanium | WD 750GB Black | CM 690 II - Corsair TX850 | 2xDell 2407WFP A04/A03 | Win 7 Pro x64
    http://www.heatware.com/eval.php?id=48222
    May 2005
    Sweden
    It seems that he took away the plate around the core and the used the holes that where holding the plate for VF-900.
    http://www.pcstats.com/articleimages...8SMCD2_G80.jpg
    Xtreme Cruncher
    Sep 2006
    Canada
    what CPU hsf are you using? looks odd.
    Feb 2004
    Finland
    Quote Originally Posted by justin_c View Post
    Gigabyte 3D Rocket Pro.
    Sep 2007
    Noob to VGA cooling here. Any tips on removing stock cooler? I've removed all spring loaded and bracket screws (EVGA 8800GTS). Twist stock cooler to break surface tension? Pry away. I'm wary. Don't want to trash $300 card.
    Xtreme Guru
    Dec 2006
    Philly/NJ
    I would not call those temps good, i would call them just the same as they were with the stock cooler, the only reason you are seeing lower temps (by a small degree if that) is because the heatsink is no longer cooling the vram and gpu at the same time.
    Aug 2007
    Madison, TN
    Quote Originally Posted by Spawne32 View Post
    I agree, and you may be right about the gpu and vram, but I also think that he was having trouble with the stock cooler to begin with. Either bad contact or the fan not functioning properly. That's why he was having artifacts with the stock cooler. If he mounted a good stock cooler, I suspect, he'd get the same temps or better than the Zalman.
    Xtreme Guru
    Dec 2006
    Philly/NJ
    Quote Originally Posted by PhilDoc View Post
    Yeh i agree, alot of times i see these retail coolers come with missing thermal pads contacting certain areas of the card, few months back, guy i used to play GRAW with removed his retail cooler from his EVGA 8800 GTX to install an HR-03, to find that 4 of the thermal pads for the ram were missing completely, making no contact whatsoever.
    Xtreme Cruncher
    Sep 2006
    Canada
    Quote Originally Posted by bcmac46 View Post
    keep on wiggling it left and right (wiggle it by millimetres) for a few minutes. then put your fingers underneath the top edge and pry. suggest that you do this on a soft cloth as not to ruin the solder on the back.
    May 2007
    it wont be pumping hot air out of back of case anymore tho tbh i like the stock cooler and mine never goes over 60 so im fine
    Gaming Rig
    Intel E6300
    Intel Mobo
    2 Gig OCZ 800 (800 5,5,5,15)
    Saphire Ati 4870
    22inch LG Flatron W2230S
  18. #18
    Aug 2007
    Madison, TN
    I don't doubt it, some of these companies just don't care. One of the first things I do when I get a new card is to remount the stock cooler and make sure the fan works. If nothing else just to get rid of the mountain of goop they use.
  19. #19
    Sep 2005
    i should get a new cooler for my x1950xtx. and remember to use a small amount of goop. i always go mad on the gpu. is the whole of the chip the "chip" if you see what i mean. its not like a cpu where its actually a small die under the IHS
    Main PC || Sugo-Evolution || Intel C2D 4300 @2.8ghz || Gigabyte DS2R || Sapphire X1950XTX || 2GB Cellshock DDR2 || 500W Silverstone sc || 20" 2007WFP || Creative X-fi || 250Gb Seagate .10 || Optiarc || Sharkoon air cooling
    Sound || Sennheiser HD 595 || Marantz PM4001 || eltax monitor3 ||
  20. #20
    Dec 2006
    well guys, my card did not came with missing pads, i re-checked the cooling of all the components, re-applied thermal paste and did a overhaul-like job on the card, no positive results, it worked fine for about 1 month and then artifacts came to the scene...
    as of now, those other "chips" they actually look like mosfets, to the touch of the finger, no problems, not "that" HOT, i will consider a larger HS for those lower chips.
    As far as we go, no problems at all with the temperature of the card.
    If i have any trouble don't worry, i´ll let you guys know.
    PS: i just removed the "shim" of the GPU, the mounting holes fit correctly.
