Results 1 to 14 of 14
Thread: Asus P5k Premium PCI-E 1x problem
    Feb 2004
    Denmark
    When im setting the fsb higher then 360, the pci-e speed gets down to x1 and my gfx performance sucks.
    I have tryed to 2 oficial bioses and the beta bios, but no change(at a point i could have x16 until 399, but can't remember when that was)
    i have also tryed setting the pci-e to 100 and 101 MHz with no change
    Other then me having this problem or a solution for me?
    Oct 2005
    Denmark
    try 400FSB and try to play with the SB and NB voltage. My P5B Deluxe was also getting the 1x bug, but 1,45 to the NB and 1,6 to SB and the problem was gone
    Asus Rampage II Gene - i7 920 D0 Lapped - Lapped Noctua NH12U-F
    Sapphire HD4870 X2 - 6GB Corsair Dominator GT@T1 - Windows 7 x64
    2 x WD Velociraptor 150GB Raid 0 - 500GB Samsung T166
    Antec ThreeHundred - Samsung A656 40"- TX650W
    Jan 2005
    Hamilton Scotland
    pci-e @100~101 may be too low people who i've seen with this issue have sorted it with >105 or so.
    • i7 920
    • DFI DK X58-T3eH6
    • G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
    • Crossfire 2x ATI HD4670 GPU 785 Ram 1060
    • Thermaltake Toughpower 1200w
    • Cooling: Water - EK Supreme
    • Lian Li V2000B+
    24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
    Official Gigabyte X48T-DQ6 Info Thread
    DFI DK X58-T3eH6 on Test
    Feb 2004
    Denmark
    How high can i set the pci-e before damageing anything? don't wana damage my 3 raid0 arrays
    Jan 2005
    Hamilton Scotland
    120 is about the max, so i'd say maybe 118. I run a 4x80gb raid & have run up to 115 without mishap.
    luck
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Feb 2004
    Denmark
    110MHz PCI-E and it boots with 16x every time.
    Thx alot.
    Final bug to get rid of now is just the sata2 problem with my 2 500GB disks
    May 2006
    argh... I have this problem too but I am not as lucky as GargaZol. I am at 110mhz PCIE and it's still 1x for me... the graphics totally licks. sometimes my system crashes when I play games at 1x and reboots at 16x no problem. why is that happening? and how do I fix problem? and does the sata2 problem only happen when you are doing raid or it affects ide mode?
    Main:
    E6600 Stock + Asetek LCLC + NF-P12
    Asus P5K Premium
    EVGA 8800GTS 320mb @ 681/1000 + TR HR-03 Plus
    Patriot Extreme Performance 2X1GB PC2-6400 DDR2-800 CL4-4-4-12
    36GB WD Raptor x2
    500GB WD SE16 x2
    Antec 1200
    Seasonic S12 600W
    RIP BOX:
    Dothan 730 @ 2.6ghz 1.6v
    P4P800SE
    EVGA 6800gs @ 400/1200
    OCZ Platinum EL Rev.2
    250GB Barracuda
    Antec P180
    FPS 450W
    Jan 2005
    Hamilton Scotland
    If your at 110 ther's another 8 steps that might get you right
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Feb 2004
    Denmark
    Quote Originally Posted by mono666 View Post
    I have only tryed raid, as it is what i wana use
    curently my 2 raid0 arrays, with 2 74gb raptors in each, works perfektly(as they use sata1), but my 2 WD5000AAKS errors(sata2).
    Im afraid it is a wery known bug that the board don't work with sata2 disks, and depending on the driver/bios, some modes work.
    Here is a link to a big thread at asus
    http://vip.asus.com/forum/view.aspx?...Language=en-us
    May 2006
    Quote Originally Posted by Supershanks View Post
    Thx Supershanks, I go the 16x lock at 115 and NB/SB set to auto. Now I can play games again
    Quote Originally Posted by GargaZol View Post
    GargaZol, I have almost the exact same setup as you but all 4 of my drives run in IDE mode and they seems to be running fine. But I want to raid the 2 rapters togather and at the same time 2 WD500AAKS togather too... seems like we have to wait for asus to fix this problem
    Main:
    Asus P5K Premium
    36GB WD Raptor x2
    500GB WD SE16 x2
    Antec 1200
    Seasonic S12 600W
    RIP BOX:
    P4P800SE
    250GB Barracuda
    Antec P180
    FPS 450W
    Feb 2004
    Denmark
    maby your board aint bugged, you can be lucky
    I "solved" the problem by jumping my 2 WD500AAKS, forcing the in to sata1 mode
    Jan 2005
    Hamilton Scotland
    Nice going , enjoy
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Jan 2005
    Hamilton Scotland
    @mono666
    Just out of interest after getting the pci-e back to x16 by going to 115 if you go back into bios & drop back to 100 or 101, does it retain the pci-e at x16. ??
    reason i ask is here Gfx only running at x1 I don't hav the issue but wonder if clunk's suggestion works :-
    Yeah, you dont want it to stay that high. Just put it back to 100 and it should stay at 16x. If not, try 101
    cheers
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Jun 2005
    Sweden
    I have also problem with my samsung HD...I see it in bios but not in Vista. How do you force it to SATA1 mode?
    i7 2600k @ 4.5GHz, 1.29V
    Asus Maximus IV Extreme-Z (bios 0706)
    8GB Ceil Corsa 2133MHz cl9
    Asus GTX580
    2x OCZ ve3 120Gb Max Iops (Raid0)
    1x WD Black 1Tb
    Asus Xonar Essence STX
    NEC 24WMGX3
    Corsair AX1200W
    Lian-Li P80 A.S
