Results 1 to 14 of 14
Thread: Tweaking Barcelona via WPCREDIT.
    Apr 2006
    Vladivostok, Russia
    Hello.
    I would like to present an article about tweaking Barcelona via WPCREDIT. There are the main actions you should do to tweak almost any setting\timing in the Barclona and A64 in generaly integrated memory controller. And not only memory. The article is based on BIOS and Kernel Developer's Guide (BKDG) For AMD Family 10h Processors. There is a link to it in the article.
    Dec 2005
    sounds good. I'll be working with this.
    dave
    Heat: 50 - 0 - 0 under "Argus333"
    Xtreme Mentor
    Nov 2005
    Devon
    Good article!
    I learned something new today !
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Fused
    Dec 2003
    Malaysia
    if you guys lazy for this hex code modding. you still can use felix memset tool. search it on this forum you would find it. most memory timing of barcelona same as am2 timing.. give it a go!
    EDIT :
    MemSet is a memory tweaker for:
    -INTEL 815 845 855 865 875 915 925 945 946 955 965 975 & P35.
    -AMD A64 ddr&ddr2.
    -NVIDIA NForce2, NForce 650i & 680i.
    -VIA KT266/333/400/600.
    Here is the 3.3 version (for 2000 /XP /Vista 32&64 bits):
    Download Link:
    http://perso.orange.fr/Tweak-and-Coe...oad/MemSet.exe
    Apr 2006
    Vladivostok, Russia
    Lightman, thanks.
    tictac, this article has been written exactly because Memset has a limited set of timings\settings, and the WPCREDIT doesn't It can tweak everything in PCI registers that can be tweaked, of course.
    And I wasn't sure that it will work with a CPU that it doesn't know. Cause MCHbaredit (which has been written by the same guy, AFAIK) doesn't want to work on chipsets similar to supported ones, but with a different DevID. And that is a big minus for the program.
    Xtreme Legend
    Mar 2006
    France
    ->tictac: I just read datasheet for barcelona, and memset can work only if you use DDR2-800, not above.
    If you use DDR2-1066 or DDR3, values are wrong. I need to update it in version 3.4.
    If someone can send me a register dump with DDR2-1066 or DDR3, it's welcome.
    ->antinomy: MchbarEdit work only with Intel 9xx chipsets, I need to update it too, coming soon.
    c[_]
    Nov 2002
    Alberta, Canada
    any chance of 5000x chipset support comming? /ot
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Please check page 61 of BKDG (2.8.1). By default the CPU is running in "Unganged mode" and you need to program DCT0 and DCT1 individually.
    This means that if you want to change RAS to CAS (for example) you need to program BOTH: offset 088 (DCT0) and also 188 (DCT1).
    If you check the document it says "F2x[1,0]88" - here 0 is referring to DCT0 and 1 is referreing to DCT1.
    The current tools would probably program only DCT0.
    Fused
    Dec 2003
    Malaysia
    Code:
    ;Processor Memory Controller node 0 (Bus : 0 , Device : 24 , Function : 2)
    	dtl_add 	equ 08000C288h	; DRAM Timing Low address
    	dth_add 	equ 08000C28Ch	; DRAM Timing High address
    	dcl_add 	equ 08000C290h	; DRAM Configuration Low address
    	dch_add 	equ 08000C294h	; DRAM Configuration High address
    	odc_add 	equ 08000C29Ch	; Output Driver Compensation address
    	dcm_add 	equ 08000C2A0h	; DRAM Controller Miscellaneous Data address
    ;Processor Memory Controller node 1 (Bus : 0 , Device : 25 , Function : 2)
    	dtl_add1	equ 08000CA88h	; DRAM Timing Low address
    	dth_add1	equ 08000CA8Ch	; DRAM Timing High address
    	dcl_add1	equ 08000CA90h	; DRAM Configuration Low address
    	odc_add 	equ 08000CA9Ch	; Output Driver Compensation address
    	dch_add1	equ 08000CA94h	; DRAM Configuration High address
    	dcm_add1	equ 08000CAA0h	; DRAM Controller Miscellaneous Data address
    Apr 2006
    Vladivostok, Russia
    FELIX, let the BKDG help you there's everything on setting correct values on DDR2-1066 and DDR3. I don't think that anyone wiil be able to send you such a dump soon. Don't forget, that only B stepping will be able to work with DDR2 at more than 667 (800\1066). Better read the datasheet, IMHO.
    It doesn't work with all of the 9xx - thats the matter of fact so this is why I ask. Can the check be bypassed? I'll wait, but if you need some help with the docs...
    STEvil 5000X has PCI registers, so can be tweaked by WPCREDIT using the datasheet (it's available). But you can't change the timings by software though We've had a lot of discussion on Overclockers.ru forum on this theme.
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by FELIX View Post
    Phenom X4 dump
    Code:
    Host Bridge
    bus 0 (0x00), device 24 (0x18), function 2 (0x02)
    Common header
    	Vendor ID		0x1022
    	Model ID		0x1202
    	Revision ID		0x00
    	PI			0x00
    	SubClass		0x00
    	BaseClass		0x06
    	Cache Line		0x00
    	Latency 		0x00
    	Header			0x80
    PCI header
    	Subvendor ID		0x0000
    	Subsystem ID		0x0000
    	Int. Line		0x00
    	Int. Pin		0x00
    Dump
    	      0  1  2  3  4  5	6  7  8  9  A  B  C  D	E  F
    	00   22 10 02 12 00 00 00 00 00 00 00 06 00 00 80 00
    	10   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	20   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	40   01 00 00 00 81 00 00 00 00 00 00 00 00 00 00 00
    	50   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	60   60 3F 38 00 00 00 00 00 00 00 00 00 00 00 00 00
    	70   00 00 00 00 00 00 00 00 05 00 80 0D 00 00 00 00
    	80   02 00 00 00 00 00 00 00 24 CA 6A 5D 34 03 12 00
    	90   10 00 01 00 0A 00 48 6F 20 00 00 80 4D 00 50 00
    	A0   00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	B0   E0 D0 CC 4F 2E 00 00 00 23 2F 8C C0 FD 1C 29 DC
    	C0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    	D0   03 19 3C 14 09 C5 4F 90 05 68 92 AC 4E 6D 64 EA
    	E0   8E 49 11 9F 8E 71 2B 96 6C B3 DD 02 04 69 24 9D
    	F0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by Antinomy View Post
    Low level memory tyiming programming
    Code:
    macro MTT2 0,1,2			; For AMD Socket F (Set both memory Controller with same timing)
    {					; 0=address; 1=data set; 2=data location
    	mov eax,0			; copy register address
    	mov ebx,1			; copy register data
    	mov dx,address			; set port address
    	out dx,eax			; send address through the port
    	mov dx,data			; set port data
    	in eax,dx			; Receive data
    	and eax,2			; set data in eax
    	or eax,ebx			; increase data
    	mov ebx,eax			; copy memory timing to ebx stack
    	out dx,eax			; send timing to memory controller 1
    	or eax,000000800h	       ; set timing to memory controller 2 address
    	mov eax,ebx			; copy memory timing to eax
    	out dx,eax			; send timing to memory controller 2
    Jan 2003
    Ayia Napa, Cyprus
    This is why i love XS so much
    a few posts later.....
    Quote Originally Posted by tictac
    Phenom X4 dump
    everyone working to helping the community
    Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
    32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
    WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
    2 x Aquacomputer D5 | Eisbecher Helix 250
    EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
    Apr 2006
    Vladivostok, Russia
    tictac
    Phenom X4 dump
    Not good in programming though especially in ASM.
    mongoled,
    And that's great!
