Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Thread: x264 video encoding benchmark
    Feb 2007
    I put together a self-contained x264 video encoding benchmark. Techarp kindly agreed to host the file and results at this URL.
    Basically, you run the test encode and it will report back frames-per-second values for your machine @ it's clock/overclock level. You can run it at your stock settings and at your overclock settings to see how your machine compares to others in the database.
    The database is small right now (as of 08-sep), but as you guys report in results, I will populate it. My goal is to have a representative set of data for many different chips and chipsets. Hopefully, we'll get some Penryn and Phenom data when they become available. Also, if anyone out here has some of the high end AMD chips, please contribute. Instructions and the file are at that url.
    Also, please report your results here in this thread. I will keep the data at that url to keep things simple.
    Thanks all.
    Jun 2007
    cool idea ill have to try it out on my media rig
    Apr 2007
    shouldn't this be in benchmark section? especially if you want Phenom results
    Feb 2007
    Dammit, I actually thought I posted to that section; maybe a mod can move this for me?
    Feb 2007
    As of 20-Sep-2007, we have data on over 100 Intel-based systems and on over 40 AMD-based systems. There are a few trends I picked-up on while browsing through the database. I put them into a single table and color coded them to make them easier to see. If you see a trend I missed, lemme know and I'll add it to the table.
    Request: we don't have a single example of a machine that has both WinXP and WinVista on it. If you have a dual-boot setup, it would be cool to see the difference the O/S makes. Another missing trend is a 32-bit O/S vs. the same O/S that's 64-bit.
    On to the table:
    Yellow: Nearly 1:1 increase by adding an additional processor to a dual-chip MB; Comparison of a Q9650 ES Yorkfield (45 nm quad) core chip to a Kentsfield (65 nm quad) core chip using the same RAM, MB, O/S etc. shows about 6 % boost and that's without using the SSE4 instructions. Two overclocked chips (e6600/q6600) both @ the same clock rate, you see a nearly 2x speed up out of the quad.
    Orange: Some operating systems seem to handle x264 more efficiently than others.
    Red: Insignificant or slight gains realized by upping the DRAM speed by 50 %.
    Blue: For the most part, these chips scale in a pretty linear fashion.
    Green: Tighter/looser memory timings have a pretty slight affect on performance.
    Purple: Keeping the same over-all clock speed using a different combo of multiplier and FSB can give pretty insignificant gains.
    Again, I only gave this a once-over look; please point out any trends you see that I missed and also don't forgot about the O/S request!
    Thanks again to all who contributed!
    I am Xtreme
    Nov 2002
    South FL, USA
    here are my results from XP Pro SP2
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 192.98 fps, 1850.94 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 193.67 fps, 1850.94 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 194.33 fps, 1850.94 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 194.01 fps, 1850.94 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 193.99 fps, 1850.94 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 54.44 fps, 1829.10 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 54.31 fps, 1829.07 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 54.21 fps, 1829.42 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 54.36 fps, 1829.27 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 54.39 fps, 1829.14 kb/s
    BIOSTAR TPOWER I45 UNOFFICIAL THREAD
    BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
    BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
    ABIT IP35 PRO HEATPIPE MOD
    ABIT IP35 PRO BIOS FLASHING PROCEDURE
    IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
    Hiding from the cops and people I ripped off
    Jun 2005
    In Bed
    Here are my 2..
    Running on XP Pro SP2
    encoded 1749 frames, 174.10 fps, 1850.94 kb/s
    encoded 1749 frames, 174.36 fps, 1850.94 kb/s
    encoded 1749 frames, 174.34 fps, 1850.94 kb/s
    encoded 1749 frames, 45.78 fps, 1829.44 kb/s
    encoded 1749 frames, 45.74 fps, 1829.13 kb/s
    encoded 1749 frames, 45.86 fps, 1829.18 kb/s
    encoded 1749 frames, 45.84 fps, 1829.00 kb/s
    encoded 1749 frames, 45.82 fps, 1829.32 kb/s
    Running on Vista x64 SP1
    encoded 1749 frames, 177.96 fps, 1850.94 kb/s
    encoded 1749 frames, 178.80 fps, 1850.94 kb/s
    encoded 1749 frames, 177.11 fps, 1850.94 kb/s
    encoded 1749 frames, 49.09 fps, 1829.48 kb/s
    encoded 1749 frames, 48.90 fps, 1829.06 kb/s
    encoded 1749 frames, 48.92 fps, 1829.30 kb/s
    encoded 1749 frames, 49.01 fps, 1829.48 kb/s
    encoded 1749 frames, 48.90 fps, 1829.10 kb/s
    Admin
    Feb 2005
    Ann Arbor, MI
    A nice 7.9-9.4% gain for Yorkfield over Kentsfield at 3GHz
    I am Xtreme
    Nov 2002
    South FL, USA
    Quote Originally Posted by njkid32 View Post
    Here are my 2..
    i thought this would be a good comparison between same OS, at the same cpu speed and memory speed to show the real time differences between Kentsfield and Yorkfield runs.
    11.5% difference between pass 1...
    7.2% difference between pass 2...
    significant results, i would say for video encoding!
    GO YORKFIELD!
Name:	kentsfield-yorkfield comparo.jpg
    Apr 2007
    Q6600 433x9 3900
    1:1 4-3-3-10
    Vista x64
    encoded 1749 frames, 192.64 fps, 1850.94 kb/s
    encoded 1749 frames, 190.03 fps, 1850.94 kb/s
    encoded 1749 frames, 193.64 fps, 1850.94 kb/s
    encoded 1749 frames, 54.16 fps, 1829.43 kb/s
    encoded 1749 frames, 54.56 fps, 1829.11 kb/s
    encoded 1749 frames, 54.90 fps, 1829.53 kb/s
    encoded 1749 frames, 54.82 fps, 1829.40 kb/s
    encoded 1749 frames, 54.66 fps, 1829.28 kb/s
    Feb 2007
    Thanks for the results, guys. Will update the table soon.
    @ace-a-rue: any idea what the chip name is on the ES Yorkfield? Also, any chance you can do the head-to-head comparison with it and a Kentfield (i.e. same board, same clock settings, same physical memory/settings, same O/S, etc.)?
    I am Xtreme
    Nov 2002
    South FL, USA
    that is not my yorkfield; it is Njkid32..i just borrowed his image to show the difference at the same cpu speed and memory...he probably got the yorkfield from intel to evaluate and thus, engineering sample (ES).
    Jun 2005
    In Bed
    I am Xtreme
    Nov 2002
    South FL, USA
    can't hear the tune...LOL
    Feb 2007
    Quote Originally Posted by Ace-a-Rue View Post
    My mistake.
    @njkid32: are you able to do the head-to-head w/ the two chips?
    Jun 2005
    In Bed
    Yes, I'll test both the Q6600 and the York at the same speed and multi's on the same machine I'll just swap cpu's.
    Jun 2005
    In Bed
    Both Tested At 7x430
    Same board, memory and OS..
    Q6600-
    encoded 1749 frames, 160.84 fps, 1850.94 kb/s
    encoded 1749 frames, 164.40 fps, 1850.94 kb/s
    encoded 1749 frames, 163.67 fps, 1850.94 kb/s
    encoded 1749 frames, 161.56 fps, 1850.94 kb/s
    encoded 1749 frames, 42.96 fps, 1829.22 kb/s
    encoded 1749 frames, 42.99 fps, 1829.41 kb/s
    encoded 1749 frames, 42.78 fps, 1829.23 kb/s
    encoded 1749 frames, 42.50 fps, 1829.46 kb/s
    encoded 1749 frames, 42.76 fps, 1829.42 kb/s
    Yorkfield-
    encoded 1749 frames, 171.42 fps, 1850.94 kb/s
    encoded 1749 frames, 171.71 fps, 1850.94 kb/s
    encoded 1749 frames, 171.96 fps, 1850.94 kb/s
    encoded 1749 frames, 169.61 fps, 1850.94 kb/s
    encoded 1749 frames, 45.65 fps, 1829.18 kb/s
    encoded 1749 frames, 45.78 fps, 1829.17 kb/s
    encoded 1749 frames, 45.78 fps, 1829.51 kb/s
    encoded 1749 frames, 45.76 fps, 1829.21 kb/s
    encoded 1749 frames, 45.72 fps, 1829.12 kb/s
  18. #18
    I am Xtreme
    Nov 2002
    South FL, USA
    so...it is lower than what i came up with (board difference)...your test figures with the same board, memory and at the same speed, i come up, after averaging the numbers and then dividing:
    PASS 1: 5.1%
    PASS 2: 6.8%
    not as good as i first figured but still a nice increase without taking advantage of the SSE4 set of registers.
  19. #19
    Jun 2005
    In Bed
    Ace, I'm wondering if Vista x64 is a result of slower results
  20. #20
    I am Xtreme
    Nov 2002
    South FL, USA
    vista is like a wrench in the spokes! ...most likely the reason...i installed 32 bit vista and 64 bit and i swear 32 bit feels far more peppier...have you experienced that?
  21. #21
    Jun 2005
    In Bed
    The only reason I'm using x64 is for crunching it does quite well. I have not tried x86 vista yet though.
  22. #22
    I am Xtreme
    Nov 2002
    South FL, USA
    it just seems quicker in the 32 bit version although benches would be about the same in results.
  23. #23
    c[_]
    Nov 2002
    Alberta, Canada
    2x Woodcrest 5120 (266mhz stock, BSEL modded to 333mhz) @ 7x333 (2335mhz)
    4x 1GB FB-DIMM's @ 333mhz 5-5-5-15 (stock)
    Supermicro X7DAL-E
    encoded 1749 frames, 117.33 fps, 1850.94 kb/s
    encoded 1749 frames, 117.09 fps, 1850.94 kb/s
    encoded 1749 frames, 117.34 fps, 1850.94 kb/s
    encoded 1749 frames, 117.08 fps, 1850.94 kb/s
    encoded 1749 frames, 116.96 fps, 1850.94 kb/s
    encoded 1749 frames, 32.38 fps, 1829.41 kb/s
    encoded 1749 frames, 32.38 fps, 1829.53 kb/s
    encoded 1749 frames, 32.43 fps, 1829.18 kb/s
    encoded 1749 frames, 32.31 fps, 1829.00 kb/s
    encoded 1749 frames, 32.45 fps, 1829.34 kb/s
    2x Woodcrest 5120 (266mhz stock, BSEL modded to 333mhz) @ 7x386 (2706mhz)
    4x 1GB FB-DIMM's @ 386mhz 5-5-5-15
    Supermicro X7DAL-E
    encoded 1749 frames, 134.86 fps, 1850.94 kb/s
    encoded 1749 frames, 135.03 fps, 1850.94 kb/s
    encoded 1749 frames, 135.51 fps, 1850.94 kb/s
    encoded 1749 frames, 135.68 fps, 1850.94 kb/s
    encoded 1749 frames, 37.46 fps, 1829.49 kb/s
    encoded 1749 frames, 37.55 fps, 1829.41 kb/s
    encoded 1749 frames, 37.54 fps, 1829.54 kb/s
    encoded 1749 frames, 37.47 fps, 1829.32 kb/s
    encoded 1749 frames, 37.57 fps, 1829.09 kb/s
    All along the watchtower the watchmen watch the eternal return.
  24. #24
    Feb 2007
    @njkid32 - very cool man. thanks for taking the time to do this. Looks like a change of 6.3 % when you compare the total encoding time of the two. I'll update the tables shortly.
    @STE - thanks for the data.. which o/s?
  25. #25
    c[_]
    Nov 2002
    Alberta, Canada
    XP-64, sorry
