Results 1 to 18 of 18
Thread: DDR3 is VERY strong > Corsair 4GB DDR3 + E6700 + Gigabyte P35T-DQ6 superpi & 3D tests
Threaded View
    Xtreme Legend
    Mar 2005
    Australia
    Talking DDR3 is VERY strong > Corsair 4GB DDR3 + E6700 + Gigabyte P35T-DQ6 superpi & 3D tests
    TEST SETUP
    • Gigabyte GA-P35T-DQ6 (DDR3 only) Motherboard >> updated to latest F3 bios
    • 4GB kit Corsair 1600MHz 7-7-7-20 DDR3 RAM
    • Intel Core 2 Duo E6700 L626Bxxx CPU
    • PCI nvidia MX400 GFX card
    • Nvidia 8800GTS 320MB PCIe GFX card
    • Corsair Nautilus 500 Watercooler
    • 80GB SADA MAxtor HDD
    • 620W Corsair HX620 PSU
    • Windows XP Pro 32-bit
    Keep in mind that these superpi results were obtained with 333 strap , no transaction booster control , Performance Level = 8, 2T Command Rate, and not fully tweaked yet >>> and it was still mighty fast close to efficiency of DDR2 600MHz 4-4-4-x
    ^^^^ incidentally these are the suggestion aside from a couple of others i've asked Gigabyte engineers to implement in a bios
    SHOCK AND HORROR >>>> You guys will not believe me if i told you that this is REAL COPPER!!!! zOMG LOL no more aluminium painted crap WOW
    3.6GHz SuperPi Tests
    1M 823MHz 7-7-7-20 2T 1.93v
    tightened timings 1M 823MHz 7-6-5-20 2T 1.93v
    32M 823MHz 7-7-7-20 2T 1.93v
    tightened timings 32M 823MHz 7-6-5-20 2T 1.93v
    another run bit faster 32M 823MHz 7-6-5-20 2T 1.93v
    dinos22
    Team.AU
    Got tube?
    GIGABYTE Australia
