Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Opteron 170 LCBQE 0722RPAW - 3564Mhz - new WR
    Nov 2006
    Vienna
    Hey everybody,
    thought it would be worth a new topic
    This was the setup. Regular watercooling with 10°C ambient and about 14°C water temp.
    And the achievement:
    http://valid.x86-secret.com/show_oc.php?id=238914
    This means that WR goes to .......................... Hungary
    If I had a chiller, I could use the CPU at 3200Mhz with default voltage ...
    And here's a pic of my rig:
    Xtreme X.I.P.
    Oct 2006
    Nice OC! Very nice!
    But it must scale pretty badly if you can't "even" get it to 3.6.
    My 175 would be stable at 3.2 with 1.4v and chilled water (it's ALMOST stable with normal water temps, at least), but I only needed 1.58v to get it to 3555 MHz.
    That thing LOVES lower temps benched it at night with chilled water, gained 10C and about 80mhz (same voltage).
    May 2006
    Safe Switzerland
    openair overclocking is always a big fun! congratz....
    Nov 2006
    Vienna
    Thanks. Will try more in winter. -10°C ambient will be much better
    Wanna hit the 3,6Ghz ...
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    great work man... 939 is not dead
    what voltage did you use to get the WR ??
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Nov 2006
    Vienna
    Yeah! And it will never die!
    @question
    Just klick on the link in my sig [1.77V in BIOS]
    Aug 2007
    made in indonesia
    nice WR ... but why the waterblock not using ice?how about the temperature?
    Nov 2006
    Vienna
    Ice? How? Don't understand what you mean.
    The ambient temp was 9°C ... and the water temp about 14°C.
    May 2006
    Safe Switzerland
    ice in the watertank
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by gianni-gt View Post
    yeah that or put the rad in a separate container and fill that with ice... or you could try this : http://forums.vr-zone.com/showthread.php?t=179554
    Nov 2006
    Vienna
    Yeah i'll do that when i have some time .. i mean, i wanted to try 3200Mhz with normal ambient temp in the room and then asked the boys @ hwluxx: should i go outside? it's quite cold. They said yes ... why not! (and make some pics).
    i did'nt want to make a WR .. oh gott, that was my last thought!
    May 2007
    There's no place like 127.0.0.1, Brazil
    awesome results buddy, nice to see 939 alive...Congratulations!
    Xtreme X.I.P.
    Oct 2006
    What batch # is your chip btw?
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by knopflerbruce View Post
    Look at the topic mate LCBQE 0722RPAW
    Nov 2006
    Vienna
    Z768954g70190
    Jun 2005
    Luxembourg
    lucky bastard what a nice cpu you have
    I love Extreme Overclocking
    Xtreme X.I.P.
    Oct 2006
    Quote Originally Posted by Peter Burg View Post
    Z768954g70190
    OT: You're crazy if you run your Ballistix @ 2.84v Can't imagine how hot they must be...
  18. #18
    Feb 2007
    Slovakia - heart of europe
    i have 4200+ LCBQE 939. OC 2.8GHz with 1.35V. Cooler freezer 64 PRO and Apacer RAM
  19. #19
    Nov 2006
    Vienna
    Acitve cooling. They are ment to be to run at 2.8V.
  20. #20
    Xtreme X.I.P.
    Oct 2006
    I had a 2gb kit once. Very nice sticks, but i could only run them @ 2.77v because of the heatspreaders getting so HOT.
    2.84 with active cooling is OK I guess.
  21. #21
    Nov 2006
    Vienna
    Look at my first post, there you see how i cool them.
    Withou the fan i burn my fingers
  22. #22
    Nov 2006
    Vienna
    Today or tomorrow a new Opteron 170 should be here, can't wait to see which stepping! Hopefully it goes as well as this one, if yes, this WR CPU is ready to be sold Anyone interested to test it under DICE or LN2?
  23. #23
    Apr 2006
    Barack Hussein Obama-Biden's Nation
    I got the exact same stepping: LCBQE 0722RPAW and it can only do 2.9 GHz at 1.475v @ 47 degrees with my Big Typhoon VX, and 2.95 GHz at 1.525v @ 55 degrees... it's a hot CPU that makes my motherboard's PWM heat up like 25 more degrees than with my other CCBBE stepping that can do 2.9 GHz at 1.550v, 53 degrees core and PWM at only 63 degrees. 3 GHz is not stable and 1.55v with this LCBQE would make my mobo's PWM go into the 80 degrees red-zone.
    So, does it make your mobo PWM heat up a lot more? I've tried like 6 different Opty 170's so far, and one that could do over 3 GHz actually made my PWM go to 100 degrees C! Of course, I care about my precious Abit Fatal1ty AN8-SLI mobo more than the CPU.
    My theory is that the "freak" overclockers suck up electricity like crazy from the mobo. Even if it's cooled very well, with the best air or water cooling around, it's still gonna suck the bejesus out of the poor motherboard.
    Perhaps it's the mobo that cannot handle the tremendous PWM currents as well as DFI motherboards can?
    --two awesome rigs, wildly customized with
    5.1 Sony speakers, Stereo 3D, UV Tourmaline Confexia, Flame Bl00dr4g3 Fatal1ty
    --SONY GDM-FW900 24" widescreen CRT, overclocked to:
    2560x1600 resolution at 68Hz!(from 2304x1440@80Hz)
    Updated List of Video Card GPU Voodoopower Ratings!!!!!
  24. #24
    Xtreme X.I.P.
    Oct 2006
    Give it less juice, and see if it helps. Try to see how far it goes with... say 1.25v. If it still sucks, then you just got a bad chip.
  25. #25
    Apr 2007
    Right on 939s are still my fav next to Bartons Ultra-D I love that board
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
