XtremeSystems Forums
Reply
Old 09-06-2007, 08:39 PM   #1
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
D-Tek Fuzion GFX Vs. Swiftech MCW-60 Showdown - 8800GTX
Ok, so this is my first complete comparison of two blocks, so if you see something I should change in my process, let me know.
INTENT
Compare the following two blocks for both pressure drop and thermal performance on an Evga 8800gtx. BTW I paid for both of these blocks out of my own pocket, niether company supplied me with a full block.
Swiftech MCW60 with G80 adapter kit - $47 at Petra's
D-Tek Fuzion GFX - $50 at Petra's
INITIAL IMPRESSION
The swiftech MCW-60 is a solid performer and sort of leaves you with the impression you purchased a good solid block at a reasonable price point. It does come with plenty of mounting hardware, however it does not come with a backplate and it also does not come with metal barbs. I found the long plastic barbs it comes with make tubing removal difficult and I ended up turning the barbs trying to remove tubing. But overall, the base is nice and sturdy and the pins are solid and big enough for easy cleaning with a brush. The water block design is fairly simple in that water comes in one side (Not directly centered) and crosses the block through the diamond pin matrix to the outlet.
The D-tek fuzion GFX is a nicer looking block and more complex. The metal barbs that come with the block are the good high flow type and the o-ring is recessed into the barbs themselves...very nice. The rest of the block consists of three parts....the copper base with round pins, the middle center nozzle block, and the top acrylic top. This redirects the water from the side inlet to more of a direct jet so the intake water impacts the center base and runs out toward the perimeter through the pins. This ensures the coldest water gets good direct coverage in the center of the base and is very similar to the CPU block water flow. The only construction element to watch is the smaller copper pins that could be damaged by cleaning if you're not very careful.
Here is a closeup of the bases side by side, both of these blocks have been used previously:
And here is the bottom of both blocks, the GFX base that is stepped down and in contact is slightly larger than the MCW-60.
GFX = 30 x 30mm
MCW-60 = 27 x 27mm
The G80 GPU IHS is much larger than both of these, but I believe they cover the actual die under the IHS sufficiently, but I do like the fact that the GFX base is larger.
And this is what each block looks like installed on my card. In my setup I have some old Thermalright HR-03 plus memory sinks I've artic adhesived on there some time ago(Yes I've had many many coolers on this 88..). I do have to say the GFX is very nice looking and takes first in the coolness category..
Note: I used the same hardware and backplate to mount both blocks.
PRESSURE DROP TESTING & FLOW RATE
I already knew the GFX was a fairly restrictive block, and I had a previous curve I ran on the MCW-60. But I figured I run a curve on the GFX and compare it to the published curve. I did go ahead as I've been doing recently and subtracted out the pressure drop of my testing equipment. What I found was something close, but slightly less restrictive than the D-Tek published curve, and this is how several blocks compare in flow rate.
The GFX is a very restrictive block, and the MCW-60 is a very free flowing block. This just means if you are running multiple block loops, you need to ensure you have a strong enough pump if going with the GFX. This can typically be done with an pump equal to or stronger than the D5 or DDC series with top, I would only suggest that you should ensure you still maintain at least .9 to 1 GPM.
Here are some quick flow rate examples using each block:
GPU only Loop
-MCW60, D5Vario, 7' Tubing, T-line, MCR320 = 2.42 GPM
-Fuzion GFX, D5Vario, 7' Tubing, T-line, MCR320 = 1.56 GPM
CPU, NB, GPU loop
-MCW60, D-Tek Fuzion, MCW-30, D5Vario, 7' Tubing, T-line, MCR320 = 1.67 GPM
-Fuzion GFX, D-Tek Fuzion, MCW-30, D5Vario, 7' Tubing, T-line, MCR320 = 1.30 GPM
THERMAL TESTING
I'm still waiting for some final cure time on the artic silver 5 I used on the GFX, but I think it's settling down now. For my testing I used ATI tools to read GPU temps. I then used two digital thermometers with temperature probes to read the ambient air temperature into the radiator (MCR320 with Yate Loons), and one to measure the coolant temperature in my T-line. Note the coolant temperature is "AFTER" the blocks, so the actual water temperature entering the blocks would be very slightly lower.
Measuring all three allowed me to gather enough data to get an average delta for "Air to Water", and "Water to Core". With all of these I was then able to adjust for my variation in ambient temperatures to compare them against. This was my collected raw data:
And this is the comparison chart using 21C as the target ambient temperature entering the radiator.
CONCLUSION
In the end I was a bit suprised to see the GFX win in the thermal category, but it did by a couple of degrees under load. The MCW-60 is clearly the pressure drop winner, but in my case I have a GPU only loop so the GFX is the better choice.
In cases where someone has a CPU and GPU (SLI) setup, they would have to weigh out what is more important to them. The reduced flow rate of chosing the GFX blocks would reduce flow rate enough that CPU temps may be higher by as much as .5C depending on the block.
You would just need to decide if .5C higher CPU temps are worth 1-2C lower GPU temps.
PRODUCT SUPPORT
One other note I would like to make is regarding D-tek and their product support. During my testing process I had inadvertantly broken a copper pin in the GFX by cleaning with a brass brush. At the time I didn't think I was being too forcefull, so I contacted D-tek about the broken pin situation I had. They are sending me out a brand new base free of charge, and were extremely helpful in the entire process. I have to give D-Tek a for product support, it's very refreshing to see that type of support.
BOTTOM LINE FOR MY SYSTEM
The MCW-60 has had a happy few months in my system and has done a nice job, but the D-Tek Fuzion GFX is doing a better job cooling, so it's taking over the G80 realestate...
Hope this is useful, I havn't done alot of thermal block testing yet, so go easy on me
If I continue to see gains by curing of this AS5, I'll repost a new table and chart later in the week. The MCW-60 was well cured, but the D-Tek only had a few days of cure time. I know for best results I would duplicate this effort over many mounts and remounts, but this was what I have currently.
Martinm210 is offline   Reply With Quote
Old 09-06-2007, 08:45 PM   #2
disruptfam
I am Xtreme
disruptfam's Avatar
Send a message via MSN to disruptfam
Very nice martin very informative
I have a mcw60 on my g80.But i ended up putting the gpu in its own loop so i probably been better off the with d-tek gfx
__________________
Originally Posted by skinnee View Post
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
disruptfam is offline   Reply With Quote
Old 09-06-2007, 09:23 PM   #3
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Thanks, they are both very good blocks, but since I have both and a GPU only loop, the choice is pretty easy for me.
I'm just happy I'm not loading at 83C anymore like I did with the stock cooler
Old 09-06-2007, 09:33 PM   #4
louie101086
Send a message via AIM to louie101086
damn i love ur reviews
__________________
MY RIG: BLUE DEVIL
CASE*BLACK SILVERSTONE TJ07-MODIFIED
MONITER*32-INCH SAMSUNG WIDESCREEN LCD TV
OS*MICROSOFT XP HOME EDITION SP3
MB*GIGABYTE P35-DQ6 F9B BIOS
CPU*INTEL E7200 3.6GHZ 1.3v
RAM*2GB G.SKILL PK PC8500**DEAD**
PSU*PC POWER&COOLING BLACK QUAD 750W
HD*SATA MAXTOR 150GB 8MB CACHE & SATA WD 250 GB 16MB CACHE
GPU*GIGABYTE HD4670 @ 811/1100
MY WATERCOOLING SETUP
CPU*SWIFTECH APOGEE GTZ
PUMP*SWIFTECH MCP 655
RAD*SWIFTECH MCR320 W/ 3 SCYTHE ULTRA KAZE MED. SPEED
RES*T-LINE
TUBING*DURELENE PVC
COOLANT*DISTILLED WATER & PT NUKE
WORKLOG-Blue Devil TJ07
WORKLOG-Project X
louie101086 is offline   Reply With Quote
Old 09-06-2007, 09:42 PM   #5
Grinch
Xtreme Cruncher
Grinch's Avatar
nice review!
__________________
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
Grinch is offline   Reply With Quote
Old 09-06-2007, 10:03 PM   #6
higgins
higgins's Avatar
great review man, was waiting for something like this. good job.
__________________
E8400@4Ghz 1.33v, P5B Deluxe, Crucial 2x1GB 475 4-4-4-12, XFX 8800GTX 675/1458/1000,
Seagate 320GBx2 RAID0, Stacker STC-T01, Samsung SyncMaster 226BW, Corsair HX620W |
D-TEK Fuzion, MCW60, Thermochill PA120.2, MCP655
higgins is offline   Reply With Quote
Old 09-06-2007, 10:05 PM   #7
aspms*
aspms*'s Avatar
Send a message via MSN to aspms*
Useful for me and very clear review!
Looks like I'll grab that D-Tek block soon!
__________________
aspms* is offline   Reply With Quote
Old 09-06-2007, 10:18 PM   #8
virtualrain
Awesome review! Nicely written and presented.
It's interesting that the Fuzion CPU block is a flow monster while their GPU block is just the opposite... yet they both do their jobs very well.
I guess with your ram sinks stuck on like that we won't be seeing a temp comparison of the full cover blocks? That's a shame, I'd like to see how the EK and Stealth compare on temps to these two.
Does anyone know of a GPU block comparison with the EK?
virtualrain is offline   Reply With Quote
Old 09-07-2007, 12:38 AM   #9
migueld
migueld's Avatar
Send a message via AIM to migueld
Another quality piece of work; this should be the standard for reviews, great work Martin
migueld is offline   Reply With Quote
Old 09-07-2007, 12:45 AM   #10
noel82
noel82's Avatar
Send a message via MSN to noel82 Send a message via Yahoo to noel82
Nice job man!
A good review to read!
__________________
CPU: Q6600 G0 @ 3,6
MB: Asus P5K Deluxe
RAM: 4*1 GB Cellshock PC8000
STORAGE: 2x 80 Gb Samsung Raid 0
VIDEO: Asus 8800 GTX
POWER SUPPLY: Tagan Easyconn 700W
CASE: Cooler Master Stacker
LCD: Samsung 205BW
COOLING CPU: Tuniq Tower
noel82 is offline   Reply With Quote
Old 09-07-2007, 01:54 AM   #11
ranker
Send a message via AIM to ranker
Hey martin, great write up. I did a mini user review of both blocks a long time ago when the GFX block came out. My results were almost the same. In my testing, both blocks were almost identical in temps. Neither held more than a solid 1C advantage over the other. However, my testing isn't as strenuous as say you or Nikhsub1's.
Anyhow, it's good to see that my initial results weren't too far off. I love the visual aid and the work done on the pressure drop.
__________________
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
ranker is offline   Reply With Quote
Old 09-07-2007, 02:55 AM   #12
KaptCrunch
Banned
outstanding Martin thanks for your time an expertise
KaptCrunch is offline   Reply With Quote
Old 09-07-2007, 03:52 AM   #13
Sparky
Xtremely High Voltage
Sparky's Avatar
Send a message via AIM to Sparky
Thanks very much for the work, most helpful info on this block that I've seen
BTW, the MCW60 does come with a backplate, just not for an 8800 though. I'm using the plate with my MCW60 and X1950XT.
__________________
And put that GPU to work too! Fold for XS
Main PC: AMD PhII 955BE 3.2GHz, 4GB, Radeon 4870 - WCG + F@H
Crunch 1: Dual Sossaman 2GHz, 2GB, GeForce GTX260-216 - WCG + F@H
Family PC: AMD Athlon X2 4600+, 2GB - WCG
Sparky is offline   Reply With Quote
Old 09-07-2007, 04:01 AM   #14
aspms*
aspms*'s Avatar
Same thing with D-Tek block you can mount it on earlier cards too including that X1950xt!
__________________
Old 09-07-2007, 05:14 AM   #15
AndyM
AndyM's Avatar
Great review! I really like the pictures of the curves, easy to compare things.
__________________
C2D E8400 @ 4.4 Ghz
Asus P5K Deluxe
Nvidia 8800 GTS @ 648/900
2GB Ballistix
Dtek, Swiftech & EK blocks, 2x D5, PA120.3, 2, & 1.
WD Raptor X 150GB & Seagate 7200.10 320GB
X-Fi Prelude
Corsair HX620
Silverstone TJ07
Dell 2407 WFP
AndyM is offline   Reply With Quote
Old 09-07-2007, 05:23 AM   #16
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Thanks guys!
Glad it's helpful
My ramsinks are epoxied on with artic adhesive, so I can only try GPU only blocks on this particular card.
Someone provided this link where canucks did a GFX vx MCW-60 Vs DD block though. I didn't see it until after I finished my testing, but it appears they also had similar results between the two blocks:
http://www.hardwarecanucks.com/hardw...uzion-gfx.html
There was also this madshrimps review I had previously seen on the MCW-60 and DD:
http://www.madshrimps.be/?action=get...59&articID=554
I thought I saw an EK comparison somewhere too, but I can't seem to find it now. I thought it was also several degrees higher in temperature.
Anyhow full coverage wasn't an option for me, but I probably would still go with a GPU only block because they perform better and cost less.
Old 09-07-2007, 06:46 AM   #17
p8ntslinger676
p8ntslinger676's Avatar
Very nice VS. read, and very informative too. this changed my mind of what gpu block im buying for my 88
__________________
Media PC:[AMD x2 4800][MSI K9N-SLI][2x1gig Corsair DDR2 800][ATI 3650 AIW][Asus Xonar D2X][500gig Samsung SATA][Crap Antec Case and PSU]
p8ntslinger676 is offline   Reply With Quote
Old 09-07-2007, 09:04 AM   #18
Snyxxx
Banned
Snyxxx's Avatar
Nice work as always Martin. I compared a MCW60 to an EK FC8800 in the thread below awhile back. Maybe this was what you were remembering.
http://www.xtremesystems.org/forums/...d.php?t=137935
Snyxxx is offline   Reply With Quote
Old 09-07-2007, 09:09 AM   #19
RockfordFosgate
RockfordFosgate's Avatar
Great Review
__________________
Intel Core i7 920 D0 | Gigabyte EX58-UD4P | 3x1Gb OCZ 1600mhz | Gigabyte 8800GT Turboforce 820/2010 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi|N97
Watercooling & Case mod soon...
Hardwarena Overclock Team
RockfordFosgate is offline   Reply With Quote
Old 09-07-2007, 10:37 AM   #20
leo_bsb
leo_bsb's Avatar
Send a message via MSN to leo_bsb Send a message via Skype™ to leo_bsb
great review.
The only issue with Dtek GFX is the flow rate. Using it at the same loop with Fuzion with nozzles should make a major hit on the flow.
leo_bsb is offline   Reply With Quote
Old 09-07-2007, 11:19 AM   #21
Linus@ncix
Linus@ncix's Avatar
Something I've noticed about the FuZion CPU, however is that it's not nearly as flow dependent as most of the other blocks out there. If you check out that Hardware Canucks review, they point out how little the FuZion CPU's performance is affected by putting a FuZion GFX in line with it compared to everything else. The results may surprise you.
Edit: Great review Martin. I thoroughly enjoyed it, and it fully supports my results (MCW60 +1C over FuZion GFX), so now we have HWC, you, and me all agreeing on this
__________________
Please note: I am not here to provide any kind of official NCIX support on these forums.
For faster (and official) service please contact me at Linus@ncix.com, or please contact our customer care team at wvvw.NCIX.com (Canada) or wvvw.NCIXUS.com (America)
Heatware: http://heatware.com/eval.php?id=25647
Linus@ncix is offline   Reply With Quote
Old 09-07-2007, 12:43 PM   #22
Sparky
Sparky's Avatar
Maybe I should have gotten the fuzion gfx instead of my mcw60 so my loop would bleed easier lol
__________________
Old 09-07-2007, 01:32 PM   #23
weescott
Send a message via MSN to weescott
Interesting.
My loop:
8800 GTX XXX (630/1000 stock) with Fuzion, 18w DDC with OClabs top and a PA 120.1 and Yate Loon fan. Same ambient. But only 3c hotter than a MCR320????
__________________
weescott is offline   Reply With Quote
Old 09-07-2007, 02:34 PM   #24
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Originally Posted by weescott View Post
Interesting.
My loop:
Yeah I'd believe it, the PAs are good rads and a PA120.2 is about equivalent to an MCR320 with yate loons on it.
I do have a few things differen though, one of them being that I also have an MCW30 in this loop cooling the 680i north bridge. I gained about 1C GPU temps by adding the NB cooler in there. Also that DDC is a stronger pump than the D5 "Basic" (especially if it's a DDC2 or 1) than I used in this test. The Basic model is stuck at setting 4 which is a fair amount weaker than the D5 Vario model.
Old 09-07-2007, 03:17 PM   #25
weescott
It's the DDC 1 plus T euro version, blue impeller that I amd using.
I tested this on a Pk deluxe.
I'm testing SLI GTX XXX's on a PA120.1. In theory it shouldn't work. But so far it seems to cope just fine. But, I'll start my own thread for that one.
On Topic again. I doubt that the heat dump difference from the pump you and I are using would have any effect on the temperatures of the GPU, surely the power (head pressure etc) would be negligable given that the pumps are so similar? Would usng a stronger pump perhaps be more benificial to one block over the other? That's maybe another test though. :p
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
