Hardware Used:
Intel Core2Duo E6700 (Batch#L626B092)
Gigabyte P35-DS3P (F4 bios)
TEAM Xtreem PC2-9600 C5 2GB Kit
DRY ICE Pot by Kayl
Cascade by Kayl
320MB 8800GTS
Western Digital 150GB Raptor-X
Coolermaster Real Power M1000
Ambients around 22-23C
CPU is now lapped!!!
Stepping
DICE (Dry Ice benches first):
i was confident with this CPU and didn't waste time (well i didn't have much in first place and just jumped straight for 4.5GHz boot and setfsb to 4.8GHz right away heh
4.8GHz 32M SuperPi run with 1.76v
4.9GHz 1M SuperPi 1.76v
4.9GHz 8M SuperPi 1.76v
4.95GHz 1M SuperPi 1.76v
5GHz 1M SuperPi 1.74v
5114MHz >> as you can see SetFSB use was not made for this mobo so i just experimented until i found a working one however i ran out of MHz there lol
5200MHz >> still on DICE >> after a bit of experimenting i found another PLL value that worked with the mobo so i was set to go higher which was a relief as i had better cooling to come still
Froze on me at 5240MHz
i have to thank kayl for rushing me to finish up with dice so i can start benching with cascade and then rushing me on cascade as well *slaps kayl snap heh >>> so don't go telling me why didn't you try this or why is your SuperPi timebla bla bla hehhehehe
