well it's been tempting before but i just never got around to it
thought i'd freshen up my OCs and show something a little different:sweatdrop
ON THE TEST BENCH TODAY
Sony VAIO VGNFZ15G Laptop LOL!
• CPU: Core2 Duo T7100 (1.80GHz) 2MB L2 Cache
• System Bus: 800MHz
• RAM: 1GB DDR2 SDRAM single stick 5-5-5-x timings (cannot change in bios)
• HDD: 120GB SATA, 5400rpm
• GFX: NVIDIA GeForce 8400M GT 383MB Stock Clocks: 450MHz Core; 600MHz RAM
• 15.4" Wide
• OS: Windows Vista Home Premium 32-bit
NO SPECIAL COOLING nor fan settings....just as it is at stock
22C ambient
it's a shame that i could not get setFSB to work under vistaso CPU was at stock
same goes for RAM system RAM timings>> memset not happy with Vista either
3DMARK01
Stock Run >> 13602 points
450/600 stock clocks
bump in clocks17143 points
bump in clocks17971 points
18064 points![]()
looks at the overclock here
Stock core 450MHz >>> OC 756MHz ~68% overclock
Memory stock 600MHz >>> OC 999MHz ~67% overclock >> Fark me 1GHz on memory on a laptopEEK
3DMARK03
Stock Clocks 5491 points
450/600 clocks
bump in clocks6961 points
bump in clocks7096 points
bump in clocks7394 points
bump in clocks8004 points
bump in clocks8363 points
FINAL RUN 8391 points
3DMARK05
Stock run 3366 points
Overclocked run 5010 points
3DMARK06
Stock run 1596 points
Overclocked run 2421 points
Aquamark3
ran out of time so OC run only
PCMARK05
I also tested a HP DV6500T which has a GS card but the thermal design on HP was so much worse.....i was getting massive slowdowns/low point scores with really small OCs
Sony laptop has a killer thermal design....and i could not hear any fans either EEK >> the LCD screen is still one of the best ones i've seen and continues to be great and follow the footsteps of FE series laptops :thumb:. Lowest amount of reflection on glossy screen and some great brightness and colours.... it just looked awesome. HP was so reflective i could see myself in the freaking screen >>> how annoyinglol
off to HWBOT to collect some much needed points now too
:sweatdrop
so CPU was at stock
17143 points
