Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: G5 on the Test Bench :)
    Unoriginal Macho Energy
    Dec 2002
    Well, after a long hiatus from testing, I finally got around to pulling the G5 out of my Green rig. I replace the G5 with a shiny new bowed and nozzled Fuzion I can tell you that I don't have high hopes for the G5 beating the GTX or the Fuzion but we will see. I also plan to test the new Enzotech block and the Thermalright block. I think I will have to purchase the Thermalright block but apparently Enzotech is sending me a sample so that is good. I have emailed Marci to send me his source excel file from which he made that awesome graph of all the blocks and each mount. This way I can continually add to it as blocks get tested
    Anyhow, just a quick update. I'm back on the horse.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    May 2006
    Dominican Republic (Caribbean)
    how much does a nozzle really improve? ncix has them real cheap...i think i'm going to get one...
    when does the enzotech arrive?
    Jun 2007
    Canada, eh?
    NCIX also won't have stock until the same time they arrive from everyone else...
    Please note: I am not here to provide any kind of official NCIX support on these forums.
    For faster (and official) service please contact me at Linus@ncix.com, or please contact our customer care team at wvvw.NCIX.com (Canada) or wvvw.NCIXUS.com (America)
    Heatware: http://heatware.com/eval.php?id=25647
    Jul 2006
    YAY, I can finally see how my G5 compares to some modern-day blocks
    Let me know if you need anything from a fellow G5 owner
    465 Watts of Computing Power....Running Off the Sun.
    **w00t for solar panels**
    Hamster Powered
    Apr 2006
    Virginia, USA [Krunching since 2001]
    Excellent news nik, looking forward to the test results.
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
    Oct 2006
    Will be intresting to know!
    Core 2 Duo(Conroe) was based on the Intel Core Duo(Yonah) which was based on the Pentium M(Banias) which was based on the Pentium III(Coppermine).
    Core 2 Duo is a Pentium III on meth.
    Jul 2006
    any updates?
    Xtreme Legend
    Nov 2002
    Melbourne, Australia
    Scott, I put the G7 in to the machinists for them to fix it, and that was 6 weeks ago. I've reminded them a few times, but they're not being good to me.
    Curious to know how the G5 goes.
    Xtreme Cruncher
    Jun 2005
    Lakeland,FL
    Quote Originally Posted by Cathar View Post
    me too...
    750W Thermaltake Modular PSU
    DFI UT X58-T3eH8
    Core i7 920 @ 20 X 200 1.325V
    CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
    768 MB EVGA 8800GTX
    1 X 36GB WD Raptor
    2 X 150GB WD RAPTORS
    1 X SpinPoint P Series SP2504C 250GB
    1 X Maxtor 6L300S0 300GB
    16 X NEC DVD Burner
    7 120mm Yate Loon LED Intake Fan
    4 120MM Yate Loon Exhaust Fan
    28" HANNSPREE Monitor
    Watercooling Loop:
    1 X PA120.3
    1 X PA120.2
    2 X Laing DDC's w/EK-DDC Dual Turbo Top
    7 X Yate Loon Blue LED Intake Fans
    4 X Yate Loon Blue LED Exhaust Fans
    1 X Swiftech GTZ
    1 X GPU EK Fullcover Waterblock
    1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
    Apr 2005
    Same...
    Does that mean you're gonna test indie blocks as well as the big stuff? I have a reason for asking...
    Dec 2002
    Sorry dudes, nothing yet, was my birthday today (well the 6th) and it has just been HOT here, too hot to test... perhaps tomorrow I can get a run or two in.
    Apr 2005
    Happy birthday!!!
    looks like we got the best month for birthdays...
    Xtreme Cruncher
    Jun 2005
    Lakeland,FL
    yep..mines the 12th
    DFI UT X58-T3eH8
    768 MB EVGA 8800GTX
    1 X 36GB WD Raptor
    16 X NEC DVD Burner
    Watercooling Loop:
    1 X PA120.3
    1 X PA120.2
    1 X Swiftech GTZ
    Apr 2005
    20th.
    I may have a surprise for everyone else though...
    Dec 2002
    Hmm, another oddity. Just did first run of the G5 and it posted the WORST numbers yet - of ANY block . Something is amiss here. I did a quick remount, except i rotated the block 90 degrees so the inlet/outlet are vertical rather than horizontal. Seems to have made quite a difference although it was just a quick 'check and see'. I'm done for the day, I hope it is just a weird mount issue with caps on the board or something but the paste imprint looked good etc. Will know more next week.
    Jul 2006
    huh, check you jets--mine get plugged about every month from miscellaneous junk that jets that gets dislodged. This is definitely just an issue with the G5 (or mine specifically), as the same loop (thoroughly cleaned out multiple times, and every time I change a piece of hardware) with my three past Swiftech G4's never ever ever got plugged.
    Dec 2002
    Quote Originally Posted by TheJollyFellow View Post
    Block was disassembled, checked and cleaned before put on test bed. Do you think I'm new?
  18. #18
    Oct 2004
    Tampa, FL
    Quote Originally Posted by nikhsub1 View Post
    Maybe....
    My Heat
    i5 2500k @4.5ghz Raystorm
    Asus P8Z68-V Pro/Gen3 16gb(4x4) G.Skill PC12800 Ripjaws X
    x1900xt MCW60
    Rad: Thermochill PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
    Corsair 120gb Force GT SSD/ 1TB WD Black Caviar SATA
    X-Fi music/SH-203B/H62L/LH-20A1L
    Corsair HX620w /Acer AL2223W/modded TJ07
  19. #19
    Dec 2002
    Quote Originally Posted by nealh View Post
    Maybe....
    Haha! Guess i walked into that one!
  20. #20
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    Happy Late Bday Scott!
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
  21. #21
    Oct 2004
    Tampa, FL
    I was of course joking...I like many XSers really appreciate all your time and effort on your excellent testing methods...
    Oh yea Happy Belated B-day
    My Heat
    x1900xt MCW60
  22. #22
    XS News
    Dec 2003
    North Carolina
    Niksubh I have to say that my temps with my G5 have not been very good. I would not be surprised if it didn't perform all that well here.
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
  23. #23
    Dec 2002
    Quote Originally Posted by chunkylover77 View Post
    But no doubt it should spank the G4... not be worse??
  24. #24
    Dec 2002
    Quote Originally Posted by NaeKuh View Post
    Thx d00d!
    I know you were joking! And thx2u2! wewtlarz!
  25. #25
    Oct 2004
    Tampa, FL
    The G5 is a great block with unsurpassed performance for its production time..it came out like 2yrs ago or so..cpu were very different..it has stood up well....
    I bet the "bad temps" are 2C or so
    My Heat
    x1900xt MCW60
