Hi Gang,
I just installed a P5K-E/WiFi today with a QX6700.
My load temps are in the 60*C range at default speed and the CPU voltage set to 1.3v. I have a Zalman 9700 with the fan at full speed for cooling. There are a couple of settings in the BIOS that I am unfamiliar with...
1) CPU Voltage Reference
2) CPU Voltage Damper (enable: helps to minimize vdroop)
3) CPU PLL Voltage
I realize that CPU temps can be totally different from board to board, but I would like to mimimize my temps on the P5K-E.
Can someone explain these settings and the possible impact on CPU temps?
