Hello Xtreme liquid members.
Quick question for those of you that have worked with the Iwaki RD30.
First, Iwaki rates the noise level at 40db which seems rather loud, but I'm assuming it's running at the fully rated level at that point and most likely with a 24v powersupply.
Second, I would like to have a variable powersupply from 12v to 24v for this unit and to have it wired to be triggered by the case. Has anyone found a solution for this?
If it's too loud then I don't want it.
If I can't have it automatically triggered by the computers on switch then I won't do that either.
Thanks.
PS, I searched for a solution and pm'd a member without any results.
