Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: Multiplier issues
    Feb 2007
    Norway
    Multiplier issues
    My cpu/board don't recognize any other multipliers than 15(wich is stock). This happened gradually, just a few times in the beginning, but now I can't use any other multies. (real annoying as there is no use benchmarking anymore with ramspeeds at 800's).
    Anyone experiencing the same thing, and who's the sinner? I'm thinking the cpu, but it might as well be the board for all I know. Max volt the cpu have been running at is 1.65 for a few benchies (approx 1 hour alltogether), otherwise it's been running at "safe" volts under 1.6
    Jun 2007
    UK- Wales
    tried a cmos clear?
    MB : Asus Maximus Formula, Special Edition
    CPU : E8400 @ 4.3GHz
    RAM : G.SKILL PC.8000 4GB
    Hard disk : 4 x 500GB samsung, 1 x 400GB WD
    GPU : 2x sapphire 4870HD
    PSU : Corsair HX1000W
    Cooling
    MOSFET - Thermalright HR-09U
    Radiators : PA120.2, Black ICE GTS stealth 360
    CPU Block : D-TEK Fuzion
    NB Block : Swiftech MCW30
    Pumps : 2xLaing DDC 18W
    Feb 2007
    Norway
    Yes, I've tried "everything" but rebuilding my whole system from scratch...
    Actually the multi is recognized at low speeds like below stock, but as soon as I start pushing it, my board reads it as x15 multi.. Therefore I'm thinking it should be possible to fix..
    Anyone know where the multiplier lies, so that I know where to troubleshoot?
    I upped the ref voltages for the ddr termination etc with + 50mv earlier, but I don't do that anymore, could that be it? Makes no sense...
    Mar 2006
    Livingston, Scotland
    Im having the same issue, try to change FSB and Multi's, FSB changes fine but multi's lock at 15x. Crosshair issue?
    I aint touched this so unsure if thats what could cause it.
    < MB / CPU > Asus X99 Pro / Intel Core i7 5820K
    < MEM / GFX >Corsair Vengeance 16GB DDR4 / EVGA GeForce GTX 780 Ti SC ACX
    < PSU / HSF > OCZ Z-Series 1000W / Phanteks 140PE
    < CASE / OS > Phanteks Enthoo Primo / Windows 7 Home Premium x64
    < STORAGE > Samsung 840 EVO 120GB - Samsung 840 250GB - 2 x Seagate Barracuda 3TB - Intel Intel X25-M 80GB
    Feb 2007
    Norway
    Seems like it, I know of one other Crosshair owner who's got the same problem.
    I've posted a question about it at the Asus motherboard forum, so hopefully I'll get an answer.
    Mar 2006
    Nice. Ill keep an eye on that thread, hopefully itll shed some light.
    In the mean time, Ill dig around on the vast knowledge base that is Google and see if its cropped up elsewhere!
    Banned
    Nov 2006
    BEYOND THE SUN - SCOTLAND
    A BIOS reflash may be in order. I haven't encountered such an issue on this GIGABYTE GA-MA69G-S3H.......yet.
    Feb 2007
    Norway
    Biosflash didn't help much I'm sorry to say. Neither did reinstalling XP (kinda my last straw of hope fixing it) Just hoping it's the cpu that causes it and not the board.. (Or maybe an excuse needed for buying a AM2+ board when it comes)
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    what about flashing a lower bios
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Feb 2007
    Norway
    Flashed from the 0502 bios to the 0702, same fault on both of them. Quite sure it's on the 0602 too. And, mind you, it happened gradually, first a couple of times, then more and more often, and only at high freq's. Makes me believe it is the cpu thats faulty. Maybe too much juice? 1,45v -1,55v and a couple of times over 1,6v. Board has a vdroop of .05v too.. Will have to run it at 3405@1,5v(1,45load) with crappy ramspeeds
    Mar 2006
    I seem to have corrected this. Currently running 267x12. HT multis all at 5x, vcore at 1.44v ish. Nothing else been changed I think.
    5-5-5-15:2T timinigs (wont boot at 1T), trc is 24, max async 8ns.
    Feb 2007
    Norway
    Hmm. Strange..
    I'll have to play a little more with my ram, if it is my ramsettings that's causing it. Have you loosened up your trc setting from last time (when your multi were "locked")?
    Maybe I'll have to eat my words to gOtVoltage...
    Mar 2006
    Possibly changed trc from auto to 24 (after reading gOtvoltage post). I think it was the 1T to 2T change though. My RAM is 8500 and it wouldnt boot at 250x12 in 1T. Still doesnt.
    Feb 2007
    Norway
    Well I don't think they're (officially) supposed to work at 1t above 800MHz on AM2 rigs. My PC6400 boots at 850MHz 1T but unstable as heck unless I use too high voltages for my liking
    Jan 2007
    Brisbane, Australia
    that's an odd problem lix.
    As noted in some other threads the only issue i've had with this board is higih RAM clocks, I've thrown all sorts of CPUs in and out and had no multi issues.
    What happens when you use CBId to change multi on the fly?
    does CnQ work?
    Feb 2007
    Norway
    Hm haven't tried cbid yet, will have to test it tonight. cool'n'quiet... aint using that Don't think x2 6000+ support it either as far as I remember. But I got an old X2 3800+ rev F2 maybe I'll check that one out again, don't think I had any problems with it. Then I can rule out the board in any case. It's oc abilities is another sad story though...
    Jan 2007
    Brisbane, Australia
    6000+ sure does support it, I've seen it first hand honking along @ 1ghz and 1v in vista on a machine
    I only remember because it was the first time I'd noticed vista's ability to CnQ all by itself after a fresh install
    I've found the board OC's well, it's just the RAM clocking issues, I just get it to play ball with the ballistix (no pun intended)
  18. #18
    Mar 2006
    I havent tweaked my RAM settings much above stock, so cant really comment. Its defo stable with RAM running at 1068MHz.
  19. #19
    Feb 2007
    Norway
    Well well. After testing my memory a little yesterday. I'm sure it's not my memory oc thats causing the problem. Then it is the cpu itself or the board. Anyone dare to make an educated guess? I'm guessing the cpu..
  20. #20
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Make sure that CoolnQuiet is off in the BIOS and all power settings in Windows are set to Always On.
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
  21. #21
    Mar 2006
    Id guess it would be a CPU issue as well. Only difference we have is that I have 2gb RAM and you have 4. Worth dropping down to 2x1gb and using settings equiv to mine to test?
  22. #22
    Feb 2007
    Norway
    Cool'n'Quiet is disabled and power settings is on. There is no difference if I drop 2gb of ram. Weird problem... And F***ING annoying.
  23. #23
    Mar 2006
    Running a mem divider when upping the FSB? And yes this problem is annoying heh.
  24. #24
    Jan 2007
    Brisbane, Australia
    I just had a thought..
    Mine was showing similar symptoms.. i.e only some multi's would allow high RAM clocks, regardless of the fact the same divider may have been in use (it seemed) But seems you're having issues at any ram clock?
  25. #25
    Feb 2007
    Norway
    Not sure im getting your point mAJORD? The cpu/board don't recognize other multipliers than 15 when I start pushing the HTT. At low HTT speeds it recognizes every multiplier. The limit seems to be at around 235htt (Wich is about as far as it goes at multi*15) I'm running it at 227*15=3405MHz 1,5V, no problem, but when I run it at 284*12 or 310*11 (315*11 ran no prob earlier..) it reads as 310*15= 4650(wich it don't boot at for some strange reason ...)
