Results 1 to 25 of 25
Thread: Q6600 Vcore for 3.6Ghz ?
    Da Goose
    Oct 2005
    Chicago
    Post what Vcore you needed to get your Q6600 to 3.6Ghz
    i7-860 Farm with nVidia GPU's
    Jul 2007
    B3.... 1.65 in bios just to get into windows, and I doubt that is load stable. this on a P5K Green.
    Oct 2005
    Mumbai, India
    3.6 Ghz @
    1.52 in BIOS.
    1.41v Real Loaded.
    3.7 Ghz @
    1.55 in BIOS.
    1.43v Real Loaded.
    3.8 Ghz @
    1.58 in BIOS.
    1.46v Real Loaded.
    G0, L724A
    CPU : E8400
    Motherboard : Abit IP-35 Pro
    Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
    Graphics Card : Palit HD4870 Dual Sonic
    Display : Dell E228WFP
    Storage & OS : 1TB | Windows 7 64bit
    Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
    Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
    Case : Coolermaster ATCS 840
    PSU : OCZ GamerXtreme 700W
    Mar 2005
    Alcácer do Sal - Portugal
    Prime stable@10m.
    3600MHz@1.3920Vcore
    Xtreme Cruncher
    Mar 2005
    Lancaster, PA
    B3 3.6ghz 1.51 real.
    A wolf in wolves clothing.
    Dec 2003
    Hong Kong
    BIOS=1.40V, 1.368V @ AIsuite, 24/7
    G0 Q6600, VID = 1.2875V
    CPU: XEON W3540 & Gulftown Q3FE
    MB: Asus Rampage III Extreme
    RAM: Corsair GT2000C7 2G X 3 ADATA XPG+ 2200+ 2G X 3
    SSD: Adata S596 120G
    Display Card: Asus EAH 5870
    WaterCooling:
    Laing D5 Pump + Koolance D5 Top
    Radiator: KP 120.3
    CPU Block: HeatKiller 3.0 + EK full MB Block
    PSU: Antec TPQ 1200W OC
    Case: SilverStone TJ-07BW
    Xtreme Cruncher
    Jun 2007
    SK, Canada
    G0 L724A 1.45v Bios, 1.41v real. Prime stable.
    i7 3970X @ 4500MHz 1.28v
    Asus Rampage IV Extreme
    4x4GB Corsair Dominator GT 2133MHz 9-11-10-27
    Gigabyte Windforce 7970 OC 3-way Crossfire
    Windows 7 Ultimate x64
    HK 3.0-MCP655-Phobya 400mm rad
    Corsair AX1200i
    Sandisk Exrtreme 240GB
    3x2TB WD Greens for storage
    TT Armor VA8003SWA
    Jul 2007
    With the specs being 1.100V-1.372V... you all seem to take it beyond... how dangerous is that ? Is that for getting a good oc or for running forever ?
    Xtreme Cruncher
    Jun 2007
    SK, Canada
    Moderate increases in voltage(~10&#37 are not dangerous at all provided you keep core temperatures under control. I don't think there's been a single documented case of anyone burning out a CPU while running moderately increased core voltage. It is highly debateable what is the absolute max safe voltage so it's up to the individual to decide what they are comfortable with.
    Naturally running any piece of equipment beyond spec will shorten it's life. But if the original lifespan of a CPU is 10+ years and your OC shortens it to 6, does it really matter? Not many people keep their hardware that long, especially overclockers.
    Corsair AX1200i
    TT Armor VA8003SWA
    Banned
    Aug 2007
    around 1.4v with B3 kentsfield
    Dec 2005
    mine needs 1.4375 set in bios..
    1.405 un-load / 1.392 on-load
    10h of Prime95 25.4
    L726A951
    Jan 2005
    daytona beach florida
    1.525 set in bios
    1.450 actual
    this is only game stable, not prime or orthos
    Q6600 L723A (400 x9)
    Evga 780i P02
    G.skill 8 GB
    Evga GTX 280
    Raptor X (3) 150's Raid 0
    Targen BZ 1100w
    Thermalright Ultra Extreme 120
    Vista Ultimate x64
    Xclio
    Dec 2005
    Quote Originally Posted by hornet View Post
    Prime stable@10m.
    you reckon this stable?
    Jan 2007
    Boston, Massachusetts
    1.5375 set in bios 1.45 in windows prime stable
    L724A760 on a quad gt with p965 chipset
    Codename [GOLIATH] - Lian-Li G70B
    Loop 1 [D-Tek Fuzion - PA120.3 - 3xSan Ace 1011 - DDC2 w/Petra's top] Loop 2 [MCW60 - EK ASUS NB 5 - EK ASUS 4 SB - BI GTX240 - 2xSan Ace 1011- D5]
    ASUS Maximus Formula - 8GB OCZ REAPER DDR2-8500 - Q6600 - EVGA GTX260 core 216 55nm - Silverstone ST75F
    Codename [Black-Dragon] - Lian-Li PC65B
    Loop [Dangerden TDX - BI GT240 Stealth - 2xYate loon SL - D5]
    DFI NF4 Ultra-D - 2GB Teamgroup Croonus(5BF)@260MHZ - Opteron 165 CCBBE0616XPMW@2.88 GHZ- ATI X1900xt - Corsair HX520
    May 2007
    Calgary, Alberta. Canada
    Q6600 B3 L644G361 1.500 bios / 1.475 Load. 60 deg load.
    Q6600 G0 L723A891 1.600 bios / 1.580 Load. 60 deg load.
    Voltage Damper enabled.
    Both 8 hours prime stable.
    Rig 1
    CPU: i7-990X. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS Rampage III Formula. RAM: 12GB Mushkin DDR3 1600 CL7. GFX: EVGA GTX 580's x 2. SLI. HDD's: 1.5 TB Seagate, 1TB WD Sata III. Monitor: Samsung 25". PSU: Corsair AX 1200W. Win 7 64 Bit
    Rig 2.
    CPU: i7-2600K. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS P8P67 Deluxe. RAM: 4 GB GSkill Ripjaws X DDR3 1600 CL6. GFX: EVGA GTX 580. HDD: 1TB WD Sata III. Monitor: Samsung 23". PSU: Corsair AX 1200W. Win 7 64 Bit.
    Apr 2007
    Quote Originally Posted by crossg View Post
    Thats interesting that the G0 requires quite a lot more voltage than the B3.
  18. #18
    May 2007
    Quote Originally Posted by antonfrompresto View Post
    I think it's just my G0 is not as great a clocker as I had hoped for. But as the saying goes you pay your money and take your chances.
    Rig 1
    Rig 2.
  19. #19
    May 2006
    SP, Brazil
    L719B SLACR, 3600 @ 1.368 after droop
    Rbs.
    Sorry for my bad English
    GA-X38-DQ6 Vdroop moded
    Ballistix Tracer PC8500 @ DDR1188 5-5-5-15 2.08v
    Q6600 L737B 475x8 - 3800Mhz @ 1.39v
    8800GTS G92 @ 830/1945/2200 36ºC idle, 39ºC full load (no mods for now..)
    MCR320 | MCR120 | MCP355 + OCLabs XPtop | MCR-RES | FuZion + washer | MCW60
  20. #20
    Apr 2007
    Quote Originally Posted by rbsmontemor View Post
    Rbs.
    Is that Prime Small FFTs stable? How long?
  21. #21
    May 2006
    SP, Brazil
    You don't need to believe if you dont want. Small FFTs, 63-63-58-58 full load with TR Ultra-120.
    Rbs.
  22. #22
    Nov 2006
    I put 1.45 in the Bios and it clocked to 3.6.
  23. #23
    Nerdy Powerlifter
    Jul 2007
    Down in the Bayou
    I played around w/ 3.6ghz, but honestly don't remember the voltages.
    I'm prime stable @ 30 minutes (which is NOT technically stable, but looks like it will be fine) @ 3.7 ghz (411x9)
    I'm running 1.5175 in the bios, 1.4720 via AI suite.
    I've run 400x9 with almost everything on auto and i booted 3.6ghz to vista. You can see what vista reports, then just drop the voltage till you are not prime stable/can't post.
    Hope this helps...
  24. #24
    May 2007
    I actually got lucky and talked to the guys at my computer shop and said the L723A891 (VID1.300v) I just bought a day ago was a horrible overclocker and they said no problem we will swap it for you. Swapped for a L726A850 (VID1.2625v) and this chip is way better so far. Just installed it and did a quick test @ 360 FSB Auto vcore 1.3360v under prime large FTT's then set to 1.4750v and 400fsb in Bios ran large FTT's for around 40 min 1.4480 under load. Going to drop the vcore a couple of notches and work up. Maybe I can get away with less vcore.
    Edit: Dropped to 1.4250 vcore(1.4080 Load) and ran large FTT for 34 min. Guess I need to drop to 1.3xxxv and see where it fails within a couple of minutes then go up from there. Then do a real stability test. Pretty happy so far.
Name:	G0 3600 1.4750 vcore.PNG
ID:	63517   Click image for larger version.
Name:	3.6 @ 1.4250 vcore.PNG
    Rig 1
    Rig 2.
  25. #25
    Oct 2003
    Hi,
    Q6600 G0 L728A VID=1,2625v aircooling U120e with 2 fans @ 1500 rpm
    1,26v real (DMM) = 3300 with IP35 pro
    1,36v real (DMM) = 3600 with IP35 pro 54°c max ( average of 52°c)
    1,49v (under load) = 3800 with P5L Deluxe
    P5E Deluxe x38 @ Rampage Formula (Bios 0802) || E8600 @ 4500mhz @ 1,38v || Ultra 120 Extreme + 2 Yate Loon D12sl + IFX-10 || 2 GB Cellshock PC8500 D9GMH @ 600 (2.3v) 5/5/5/15/2T || 4 x 640gb WD sata II || HD4870 @ 775 - 1000 || CM Stacker STC-01 + 4 Yarte Loon D12SL || Enermax modu82+ 625W || Audigy2 ZS || Logitech Z-5500D || Lacie Electron22BlueIV 22"
