Q6600 SLACR
FPO/Batch: L725A903
Version: E10342-001
Pack Date: 07/31/07
System:
- Intel Core 2 Quad Q6600 L725A903 7/31/07 pack date G0
- CPU cooling = Swiftech G4 Storm/Thermochill 120.3/MCP655
- NB chipset cooling = Radiical Chipset Block/Corsair Cool single 120mm fan Rad/MCP350
- Asus Blitz Extreme 0804 bios
- 128MB Gainward FX5200 PCI
- 2x1GB OCZ PC3-14400 Platinum - DDR3-1800 rated at 8-8-8-27 at 1.9v
- 500GB Seagate 7200.10 SATA on SATA1 Port
- LiteOn 165H DVD Burner
- Sony FDD
- 1KW OCZ ProXStream
- WinXP Pro SP2
I originally booted up the Q6600 L725A903 system with Asus Blitz Extreme 0702 bios and it was fine. But decided to flash using in bios Ez Flash2 and USB drive to latest 0804 bios before doing any further testing.
Booting up at stock and using both Coretemp 0.94 and 0.95.4 beta and Asus PC Probe2 you can see the reported cpu idle and load temps are probably not correct considering my room ambient temperature right now is between 22C to 23C.
@2405Mhz - 9x266FSB at 1.25v bios set = 1.224v idle/1.216v load
Q6600 L725A903 VID = 1.25v
Idle
Prime95 Idle
Prime95 Small FFTs Load
