Hey,
After looking through the Wc case gallery awhile back,i got the inspiration to do my 1st watercooling rig.I'm very new to all this and all your messages and reading through all your posts have been invaluable.cheers![]()
Ok....
I'm just starting to get all my components together now and this is what i have,Not as extreme as most people on here but it's a start.
System components:
Lian li v2000b + ( due to arrive 27th august )
Q6600 b3 (have)
Evga 680i A1 (have)
2gb ocz 1066 sli ready ram w/ocz ram cooler (have)
xfx 8800 gtx stock (have)
150gb raptor and 400gb wd hd's w/zalman heatpipe coolers(have)
samsung 18x dvd burner (have)
thermaltake 850w psu (have)
Zalman fan controller(have)
(supplied by www.itsdirect.com.au)
Watercooling gear:
D-tek fuzion cpu block (have)
Radiical 3x rad (have)may get a 2nd depending if it will fit internally in case.
Radiical 2x rad (have)to be replaced by 3xrad if fits.
mcw60 gpu block (have)
Swiftech ramsinks (have)
Radiical chipset block (have)May get 2nd for sb
2x acrylic resevoirs (have)
laiing d5 (have)
swiftech mcp350 w/ radiical turbo head(have)
10 metres excellon tubing (have)
6x antec tri-cool fans 3x blue 3x green (have)
d-tek blue dye and d-tek green dye (have)
8 litres on dimeneralized water (have)
Anti corrosion and anti algae mix(have) supplied by radiical
(supplied by www.radiical.com.au)
1st loop layout:
3xrad >fuzion>nb>res>d5
2nd loop layout:
2xrad >mcw60>res>mcp350w/radiical top
Ok that's all my gear atm.I'm just missing the my case,so i can't really start until received.During this process if you see me doing anything incorrectly please let me know
Will post pics of my gear soon......
