As there is still strong interest in modded drivers for SLI on this forum I have decided to make the 84.29 SEDONA driver available here.
It's another modified driver for all of those with two 6x00/7x00 series cards (minus the 7950GX2) that allows SLI on Intel and ATI chipsets.
Unlike previous modified drivers this one has the new SEDONA control panel.
Note that the archive is password protected.
DOWNLOAD 84.29 SEDONA HERE
TO AVOID DRIVER CONFLICTS PLEASE UNINSTALL THE PREVIOUS DRIVER AND RUN DRIVER SWEEPER PRIOR TO INSTALLING!
Disclaimer: YOU USE THIS DRIVER AT YOUR OWN RISK!
Password:
chinobino1nf0h4lngbn50s5mmhx0j4mgj5mnhg05vzmchripn vnehvkrleppojqvpkc40nrmnoenkehzkenfkekihfihpoeipoj
NOTE: You will need to remove the space between the 'n' and the 'v' in the password above, the forum has a width limitation that I can't do anything about.
If anyone wants any of the other modified drivers you can access them from the same link above (they are not password protected).
Some photos of my test setup, 2 x 7950GT's in the ATI CFX3200 chipset;Code:GeForce PCI-e Cards with SLI support using these drivers; GeForce 7900 GTX GeForce 7950 GT GeForce 7900 GTO GeForce 7900 GT GeForce 7900 GS GeForce 7800 GTX GeForce 7800 GT GeForce 7600 GT GeForce 7600 GS GeForce 7600 LE GeForce 7500 LE GeForce 7300 GT GeForce 7300 GS GeForce 6800 Ultra GeForce 6800 GS GeForce 6800 GT GeForce 6800 GeForce 6800 XT GeForce 6800 LE GeForce 6700 XL GeForce 6610 XL GeForce 6600 GT GeForce 6600 GeForce 6600 LE GeForce 6600 VE GeForce 6500 Quadro PCI-e Cards with SLI support using these drivers; Quadro FX 5500 Quadro FX 4500 Quadro FX 4400 Quadro FX 4300 Quadro FX 4000 Quadro FX 3500 Quadro FX 3450 Quadro FX 3400 Quadro FX 1500 Quadro FX 1400 Quadro FX 560 Quadro FX 350 ^Quadro cards that are SLI capable that I haven't added; ^Quadro FX 4600 ^Quadro FX 550 ^Quadro FX 540
Here's some benchmark results too
3dmark06 (1280 x 1024) --> 10,032
3dmark06 (1600 x 1200) --> 8961
3dmark05 (1024 x 768) --> 15,236
3dmark05 (1600 x 1200) --> 14,145
AMD Opteron 175 @ 3003 (273 x 11)
RAM @ 166 Divider, 214.5MHz (2-2-2-10)
2 x 7950GT SLI @ 700-820
Using 84.29 SEDONA driver - not bad eh?
